查看: 4077|回复: 33
cc双十一换了个节点,跑分到了2000
发表于 2020-11-12 11:28:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
昨晚删了好几cc的双十一,一直是s55,s59节点,cpu频率是2599.998Mhz,但是硬盘读取只有400+,跑分单核600+ 多核1000+。
发工单要求换到了s67,cpu没变,硬盘读取到了1G左右。跑了几次分,都是2000分左右。
  1. Dhrystone 2 using register variables       31201664.0 lps   (10.0 s, 7 samples)
  2. Double-Precision Whetstone                     3851.2 MWIPS (9.7 s, 7 samples)
  3. Execl Throughput                               4341.2 lps   (30.0 s, 2 samples)
  4. File Copy 1024 bufsize 2000 maxblocks        775136.0 KBps  (30.0 s, 2 samples)
  5. File Copy 256 bufsize 500 maxblocks          226906.3 KBps  (30.0 s, 2 samples)
  6. File Copy 4096 bufsize 8000 maxblocks       1662278.4 KBps  (30.0 s, 2 samples)
  7. Pipe Throughput                             1490894.3 lps   (10.0 s, 7 samples)
  8. Pipe-based Context Switching                 195431.8 lps   (10.0 s, 7 samples)
  9. Process Creation                               7525.7 lps   (30.0 s, 2 samples)
  10. Shell Scripts (1 concurrent)                   5900.1 lpm   (60.0 s, 2 samples)
  11. Shell Scripts (8 concurrent)                   1161.6 lpm   (60.0 s, 2 samples)
  12. System Call Overhead                        1947425.4 lps   (10.0 s, 7 samples)
  13. System Benchmarks Index Values               BASELINE       RESULT    INDEX
  14. Dhrystone 2 using register variables         116700.0   31201664.0   2673.7
  15. Double-Precision Whetstone                       55.0       3851.2    700.2
  16. Execl Throughput                                 43.0       4341.2   1009.6
  17. File Copy 1024 bufsize 2000 maxblocks          3960.0     775136.0   1957.4
  18. File Copy 256 bufsize 500 maxblocks            1655.0     226906.3   1371.0
  19. File Copy 4096 bufsize 8000 maxblocks          5800.0    1662278.4   2866.0
  20. Pipe Throughput                               12440.0    1490894.3   1198.5
  21. Pipe-based Context Switching                   4000.0     195431.8    488.6
  22. Process Creation                                126.0       7525.7    597.3
  23. Shell Scripts (1 concurrent)                     42.4       5900.1   1391.5
  24. Shell Scripts (8 concurrent)                      6.0       1161.6   1936.0
  25. System Call Overhead                          15000.0    1947425.4   1298.3
  26.        ========
  27. System Benchmarks Index Score                                        1271.1
  28. ------------------------------------------------------------------------
  29. Benchmark Run: Thu Nov 12 2020 10:43:31 - 11:11:40
  30. 2 CPUs in system; running 2 parallel copies of tests
  31. Dhrystone 2 using register variables       60699770.2 lps   (10.0 s, 7 samples)
  32. Double-Precision Whetstone                     7705.7 MWIPS (9.8 s, 7 samples)
  33. Execl Throughput                               7289.2 lps   (30.0 s, 2 samples)
  34. File Copy 1024 bufsize 2000 maxblocks        896997.1 KBps  (30.0 s, 2 samples)
  35. File Copy 256 bufsize 500 maxblocks          248933.8 KBps  (30.0 s, 2 samples)
  36. File Copy 4096 bufsize 8000 maxblocks       2405669.8 KBps  (30.0 s, 2 samples)
  37. Pipe Throughput                             2848246.6 lps   (10.0 s, 7 samples)
  38. Pipe-based Context Switching                 483620.1 lps   (10.0 s, 7 samples)
  39. Process Creation                              16918.6 lps   (30.0 s, 2 samples)
  40. Shell Scripts (1 concurrent)                   9471.8 lpm   (60.0 s, 2 samples)
  41. Shell Scripts (8 concurrent)                   1321.8 lpm   (60.0 s, 2 samples)
  42. System Call Overhead                        2875864.8 lps   (10.0 s, 7 samples)
  43. System Benchmarks Index Values               BASELINE       RESULT    INDEX
  44. Dhrystone 2 using register variables         116700.0   60699770.2   5201.4
  45. Double-Precision Whetstone                       55.0       7705.7   1401.0
  46. Execl Throughput                                 43.0       7289.2   1695.2
  47. File Copy 1024 bufsize 2000 maxblocks          3960.0     896997.1   2265.1
  48. File Copy 256 bufsize 500 maxblocks            1655.0     248933.8   1504.1
  49. File Copy 4096 bufsize 8000 maxblocks          5800.0    2405669.8   4147.7
  50. Pipe Throughput                               12440.0    2848246.6   2289.6
  51. Pipe-based Context Switching                   4000.0     483620.1   1209.1
  52. Process Creation                                126.0      16918.6   1342.7
  53. Shell Scripts (1 concurrent)                     42.4       9471.8   2233.9
  54. Shell Scripts (8 concurrent)                      6.0       1321.8   2202.9
  55. System Call Overhead                          15000.0    2875864.8   1917.2
  56.        ========
  57. System Benchmarks Index Score                                        2068.1
发表于 2020-11-12 19:23:16 | 只看该作者
这个节点性能是还可以,但是网络老炸,一个小时炸好多次
发表于 2020-11-12 11:28:44 | 只看该作者
发表于 2020-11-12 11:29:21 | 只看该作者
s67 cpu 不是2194频率的吗
 楼主| 发表于 2020-11-12 11:33:21 来自手机 | 只看该作者
taryn 发表于 2020-11-12 11:29
s67 cpu 不是2194频率的吗
原来在s59节点上,发工单换的 ,不知道为什么CPU没变
原来是这个分2000,我们的评分标准不一样,哈哈哈  发表于 2020-11-12 19:12
发表于 2020-11-12 11:34:54 | 只看该作者
都是虚的吧,我最开始买的s67,cpu就是2194的
发表于 2020-11-12 11:34:55 | 只看该作者
可惜我手里有个1H2G40G的 要不这个两核的就买了,
发表于 2020-11-12 11:36:12 | 只看该作者
不错 现在还能买 签名直达
 楼主| 发表于 2020-11-12 11:39:40 来自手机 | 只看该作者
llmwxt 发表于 2020-11-12 11:28
帮顶,这个不错啊!
我的三周年才200
之前买的300
 楼主| 发表于 2020-11-12 11:41:25 来自手机 | 只看该作者
可能是 。我回头重新一下系统再试试
发表于 2020-11-12 11:44:15 | 只看该作者
CC:下一步计划,将针对各种测试作出进一步的优化,以提高用户测试体验
GMT+8, 2026-4-19 07:39 , Processed in 0.074240 second(s), 12 queries , Gzip On, MemCache On.
