CeraNetworks网络延迟测速工具IP归属甄别
查看: 7533|回复: 7
怎么知道自己的VPS在那个KT机房.那些线路.
发表于 2009-12-15 11:30:32 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
RT.
我租用了2个KT的VPS,这几天速度都不大一样.有一个延时到300多毫秒.
应该怎么才能知道在那个机房,线路,
线路可换不?
发表于 2009-12-15 11:43:20 | 只看该作者
tracert IP
 楼主| 发表于 2009-12-15 13:01:51 | 只看该作者
路由
Tracing route to CUSTOMER.VPLS.NET [66.186.37.*]
over a maximum of 30 hops:
  1     *        *        *     Request timed out.
  2     *        *        *     Request timed out.
  3     *        *        *     Request timed out.
  4     *        *        *     Request timed out.
  5     *        *        *     Request timed out.
  6     *        *        *     Request timed out.
  7     *        *        *     Request timed out.
  8     *        *        *     Request timed out.
  9     *        *        *     Request timed out.
10     *        *        *     Request timed out.
11     *        *        *     Request timed out.
12     *        *        *     Request timed out.
13     *        *        *     Request timed out.
14     *        *        *     Request timed out.
15   204 ms   189 ms   233 ms  CUSTOMER.VPLS.NET [66.186.37.*]
Tracing route to CUSTOMER.KRYPT.COM [98.126.20.*]
11   570 ms     *      189 ms  CUSTOMER.KRYPT.COM [98.126.20.*
Trace complete.
分别是什么线路的?
发表于 2009-12-15 13:25:07 | 只看该作者
回复 1# 的帖子
98.126大部分走的是tiscali线路。
你给的路由跟踪不完整,无法得知,有IP的话我帮你路由跟踪看下。
发表于 2009-12-15 13:52:24 | 只看该作者
你家的路由器不支持路由追踪
直接拨号或者换个路由器
发表于 2009-12-15 13:56:16 | 只看该作者
回复 5# 的帖子
直接接猫
 楼主| 发表于 2009-12-17 23:09:03 | 只看该作者
第一个
1  phonoscope-204-2-20-028.phonoscope.com (204.2.20.28)  0.462 ms  0.318 ms  0.263 ms
2  xe-3-3-0-127.bar2.Houston1.Level3.net (4.59.126.17)  0.971 ms  1.015 ms  0.988 ms
3  ae-0-11.bar1.Houston1.Level3.net (4.69.137.133)  1.005 ms  1.016 ms  1.002 ms
4  ae-13-13.ebr1.Dallas1.Level3.net (4.69.137.138)  14.721 ms  16.873 ms  18.027 ms
5  ae-93-98.ebr3.Dallas1.Level3.net (4.69.146.92)  14.595 ms  17.215 ms  17.817 ms
6  ae-3.ebr2.LosAngeles1.Level3.net (4.69.132.77)  43.592 ms  38.574 ms  50.494 ms
7  ae-14-60.car4.LosAngeles1.Level3.net (4.69.144.6)  38.995 ms  38.411 ms  38.532 ms
8  VLAN4059.BR1.LAX1.VPLS.NET (4.71.128.118)  52.282 ms  52.951 ms  52.075 ms
9  VLAN2093.BR2.LAX2.VPLS.NET (74.222.141.22)  52.347 ms  53.755 ms  62.471 ms
10  VLAN2099.BR1.LAX3.VPLS.NET (67.198.200.18)  58.013 ms  51.892 ms  51.261 ms
11  CUSTOMER.VPLS.NET (209.11.241.*)  51.772 ms  53.066 ms  52.893 ms
第二个
1  phonoscope-204-2-20-028.phonoscope.com (204.2.20.28)  0.399 ms  0.313 ms  0.290 ms
2  xe-3-3-0-127.bar2.Houston1.Level3.net (4.59.126.17)  1.110 ms  0.992 ms  0.941 ms
3  ae-0-11.bar1.Houston1.Level3.net (4.69.137.133)  1.000 ms  1.005 ms  0.968 ms
4  ae-13-13.ebr1.Dallas1.Level3.net (4.69.137.138)  5.545 ms  12.185 ms  18.036 ms
5  ae-3-80.edge4.Dallas3.Level3.net (4.69.145.141)  6.052 ms  6.180 ms  6.230 ms
6  xe-6-0-0.dal33.ip4.tinet.net (77.67.71.221)  5.917 ms  6.341 ms  6.171 ms
7  xe-0-0-0.lax20.ip4.tinet.net (89.149.185.178)  38.363 ms
    xe-1-0-0.lax20.ip4.tinet.net (89.149.185.217)  37.878 ms  37.860 ms
8  vpls-gw.ip4.tinet.net (77.67.68.98)  51.955 ms  62.689 ms  51.984 ms
9  VLAN2099.BR1.LAX3.VPLS.NET (67.198.200.18)  54.938 ms  51.286 ms  51.241 ms
10  CUSTOMER.KRYPT.COM (98.126.20.*)  50.940 ms  51.337 ms  51.796 ms
[ 本帖最后由 wian1314 于 2009-12-18 11:26 编辑 ]
发表于 2009-12-18 02:22:37 | 只看该作者
回复 7# 的帖子
两个都是在洛杉矶机房,不过走的线路不大一样,
一个是Level3直接连到机房,一个是Level3连到tiscali再到机房。
GMT+8, 2026-4-27 06:39 , Processed in 0.061935 second(s), 10 queries , Gzip On, MemCache On.
