查看: 2786|回复: 5
[翻译] 大家帮我看看thrustvps给我发的这封邮件是什么意思?
发表于 2011-9-3 17:35:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
今天早上起来发现我在thrustvps购买的VPS被关了,官方给我发了一封邮件,貌似告诉我被封的原因,大家帮我看看到底是怎么回事?万分谢谢!
邮件的原文如下:
  1. abuse-ticket@quadranet.com Posted on: 01 Sep 2011 8:59 PM
  2. ================================================================
  3. There has been a report of abuse on your server.
  4. Per our policies, we require that all our clients respond to abuse notices as they come in. Failure to do so within a timely manner (within 24 hours) will result in a suspension of services until the server administrator has time to resolve the issue.
  5. The initial complaint is attached to this ticket. If you don't see it under my signature, please log in to your billing interface and view the ticket there.
  6. We will await your response indicating that you have complied with the order, dispute it, or require a reasonable extension of time to resolve the issue.
  7. Awaiting your timely response,
  8. --
  9. Viktoriya Andrienko
  10. Support Engineer
  11. -------------------------------------------
  12. From: Andrew Ramsey[SMTP:ANDREW.RAMSEY@GLOBALCROSSING.COM]
  13. Sent: Thursday, September 01, 2011 8:24:50 AM
  14. To: abuse@wbsconnect.com; Kate Gerry
  15. Subject: infected customer report
  16. Auto forwarded by a Rule
  17. The following is a list of IP addresses on your network which we have
  18. good reason to believe may be compromised systems engaging in
  19. malicious activity.  Please investigate and take appropriate action to
  20. stop any malicious activity you verify.
  21. The following is a list of types of activity that may appear in this
  22. report:
  23.     BEAGLE      BEAGLE3    BLASTER    BOTNETS    BOTS        BRUTEFORCE
  24.     DAMEWARE    DEFACEMENT  DIPNET      DNSBOTS    MALWAREURL  MYDOOM
  25.     NACHI      PHATBOT    PHISHING    ROUTERS    SCAN445    SCANNERS
  26.     SINIT      SLAMMER    SPAM        SPYBOT      TOXBOT
  27. Open proxies and open mail relays may also appear in this report.
  28. Open proxies are designated by a two-character identifier (s4, s5, wg,
  29. hc, ho, hu, or fu) followed by a colon and a TCP port number.  Open
  30. mail relays are designated by the word "relay" followed by a colon
  31. and
  32. a TCP port number.
  33. A detailed description of each of these may be found at
  34.    https://security.gblx.net/reports.html
  35. NOTE: IPs identified as hosting botnet controllers, phishing websites,
  36. or malware distribution sites (marked with BOTNETS, PHISHING, or
  37. MALWAREURL respectively) may be null routed by Global Crossing
  38. following a separately emailed notice.  We will make every effort
  39. to avoid taking action which will impact legitimate services on
  40. your network, and we will now send notices of botnet controllers
  41. within one hour of their detection.
  42. This report is sent every day.  If you would prefer a weekly report,
  43. sent on Mondays, please contact us by replying to this email to
  44. request it.  We would prefer, however, that you receive and act upon
  45. these reports daily.
  46. Unless otherwise indicated, time stamps are in UTC (GMT).
  47. 29761 | 109.169.60.119 | 2011-08-31 01:21:15 cbl SPAM | OC3-NETWORKS-AS-NUMBER
  48. - OC3 Networks & Web Solutions, LLC
  49. 29761 | 212.38.176.120 | 2011-08-30 02:32:46 445/tcp SCANNERS |
  50. OC3-NETWORKS-AS-NUMBER - OC3 Networks & Web Solutions, LLC
  51. 29761 | 212.38.176.126 | 2011-08-30 03:46:53 445/tcp SCANNERS |
  52. OC3-NETWORKS-AS-NUMBER - OC3 Networks & Web Solutions, LLC
  53. 29761 | 216.45.55.126 | 2011-08-30 05:33:09 445/tcp SCANNERS |
  54. OC3-NETWORKS-AS-NUMBER - OC3 Networks & Web Solutions, LLC
  55. 29761 | 96.44.168.108 | 2011-08-30 01:20:47 445/tcp SCANNERS |
  56. OC3-NETWORKS-AS-NUMBER - OC3 Networks & Web Solutions, LLC
  57. --
  58. Get in touch: 推特 @thrustvps
  59. If you have any concerns or comments please feel free to ask for your ticket to be esculated to management.
  60. Ticket Details
  61. ===================
  62. Ticket ID: EIK-922817
  63. Department: Abuse
  64. Priority: Low
  65. Status: Awaiting Customer Reply
发表于 2011-9-3 17:46:12 | 只看该作者
abuse-滥用
 楼主| 发表于 2011-9-3 18:07:34 | 只看该作者
是不是被扫描了呢?
发表于 2011-9-3 18:10:01 | 只看该作者
是你的机器扫描他人的。
http://www.loc.qiche.eu.org/thread-74840-1-2.html
发表于 2011-9-3 18:12:27 | 只看该作者
abuse-ticket@quadranet.com发表于:2011年9月01日下午08:59
有被滥用您的服务器上的报告。
按照我们的政策,我们要求我们所有的客户回应滥用通知,因为他们英寸未能及时(24小时内)内,将导致暂停服务,直至服务器管理员有时间来解决问题。
最初的抱怨是连接此门票。如果你没有看到它在我的签名,请登录到您的计费接口,并查看机票。
我们将等待你的回应,表明你有遵守秩序,纠纷,或需要一个合理的时间延长到解决问题。
等待您的及时响应,
Viktoriya Andrienko
技术支持工程师
安德鲁拉姆齐[SMTP:ANDREW.RAMSEY @ GLOBALCROSSING.COM]
发送时间:2011年年9月01日(星期四),上午8点24分50秒
abuse@wbsconnect.com;凯特格里
标题:受感染的客户报告
自动转发规则
以下是您的网络上的IP地址列表,我们有
充分的理由相信可能会受到影响的系统从事
恶意活动。请调查,并采取适当的行动
停止任何恶意活动验证。
以下是活动类型清单中可能出现的
报告:
猎兔犬BEAGLE3 BLASTER僵尸机器人暴力破解
DAMEWARE污损DIPNET DNSBOTS MALWAREURL MyDoom病毒
NACHI PHATBOT网络钓鱼路由器SCAN445扫描仪
SINIT地狱垃圾邮件Spybot的TOXBOT
打开代理和开放邮件中继,也可能出现在本报告。
打开代理指定的两个字符的标识符(S4,S5,WG,
HC,何,胡,或FU),其次是一个冒号和一个TCP端口号。打开
邮件中继指定字“接力”,后跟一个冒号
一个TCP端口号。
其中每一个详细的说明,可能会发现在
注:确定为托管僵尸网络控制器,钓鱼网站的IP地址,
或恶意软件分布网站(标记与僵尸网络,网络钓鱼,或
MALWAREURL分别)可能是空环球电讯的路由
我们将尽一切努力后,分别通过电子邮件通知。
避免采取行动,这将影响合法服务
您的网络,我们现在将发送僵尸网络控制器的通知
其检测一小时内。
本报告是发送的每一天。如果你希望每周一次的报告,
星期一发出,请回复此电子邮件与我们联系
请求。然而,我们希望,您收到并付诸行动
每天这些报告。
除非另有说明,在UTC(GMT)的时间戳记。
29761 | 109.169.60.119 | 2011年8月31日1时21分15秒CBL垃圾| OC3网络,AS - NUMBER
- OC3网络与网络解决方案,有限责任公司
29761 | 212.38.176.120 | 2011年8月30日2时32分46秒445/TCP扫描器|
OC3网络AS - - OC3网络及网络解决方案,有限责任公司
29761 | 212.38.176.126 | 2011年8月30日3时46分53秒445/TCP扫描仪|
29761 | 216.45.55.126 | 2011年8月30日5时33分09秒445/TCP扫描器|
29761 | 96.44.168.108 |二○一一年八月三十日1点20分47秒445/TCP扫描器|
与我们取得联系:推特@ thrustvps
如果你有任何问题或意见,请随时要求您的机票要esculated管理。
票务详情
票务编号:EIK - 922817
部:虐待
优先级:低
状态:等待​​客户回复
发表于 2011-9-3 18:16:08 | 只看该作者
部:虐待
参与人数 1威望 +19 收起 理由
Poison + 19 SM
GMT+8, 2026-4-26 08:54 , Processed in 0.076797 second(s), 14 queries , Gzip On, MemCache On.
