查看: 1851|回复: 6
servarica 可以选择切换至G口
发表于 2020-9-9 13:24:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
总的来说十分鸡肋
4个选择
1.固有100mbps 无限流量
2.前4TB是1gbps 后面降至10M
3.每月加2刀并且工单申请  前4TB是1gbps 后面降至100mbps
4.工单申请  前4TB是1gbps 后面  2刀/TB 仍维持1gbps
We are happy to inform you that clients 1gbps VM ports are up and ready
You can now switch to the new 1gbps by going through the client area and follow these instructions
https://servarica.com/clients/knowledgebase/12/How-to-Switch-to-1Gbps-Port.html
Once you switch your VPS will be able to use 1gbps port to the internet (It does no mean you can get full 1gbps to any destination as that depend on routing and congestion of the routes between our uplinks and the destination but you will definitely get better results than 100mbps to most destinations )
Basically, for Bandwidth we have now 4 options
1- Unlimited 100mbps (the one you are using now) (free)
2- 1gbps for first 4TB used (up and down counted) then it will revert to 10mbps unlimited (you can switch to this option from the client area as shown in the instruction link)
3- 1gbps for first 4TB then switch back to 100mbps unlimited (2$ extra per month) (you need to open ticket to switch to this option) (free)
4- 1gbps for first 4TB then you pay 2$/TB extra while remaining on 1gbps (you need to open ticket to switch to this option)
For the month of September you can switch back and forth between option 1 and 2 from your client area
once the month finish you will remain on what ever option you choose last (need to open ticket if you want to switch at start of the month to other option after the end of this month)
If you have any questions please reply to this email or open a ticket
Thanks
servaRICA team
发表于 2020-9-9 15:04:50 | 只看该作者
好消息啊,差点出了
发表于 2020-9-9 16:48:57 来自手机 | 只看该作者
还是 100m 无限流量比较香
发表于 2020-9-9 17:13:27 | 只看该作者
车呢?                   还有车没?
 楼主| 发表于 2020-9-11 19:49:44 | 只看该作者
a5582323 发表于 2020-9-9 17:13
车呢?                   还有车没?
没货了 不过这家性价比还是比不上OP加拿大
GMT+8, 2026-4-24 09:21 , Processed in 0.061735 second(s), 10 queries , Gzip On, MemCache On.
