查看: 4371|回复: 29
[不限流量] 开了个CC三周年15刀
发表于 2020-8-23 08:56:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Benchmark Run: Sun Aug 23 2020 00:21:57 - 00:50:14
1 CPU in system; running 1 parallel copy of tests
Dhrystone 2 using register variables       19188383.8 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     2969.1 MWIPS (10.0 s, 7 samples)
Execl Throughput                               1885.1 lps   (29.5 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        190709.6 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks           49307.3 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks        605439.9 KBps  (30.0 s, 2 samples)
Pipe Throughput                              323834.1 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                  64195.0 lps   (10.0 s, 7 samples)
Process Creation                               4995.4 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                   2536.7 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                    341.5 lpm   (60.1 s, 2 samples)
System Call Overhead                         265428.6 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0   19188383.8   1644.2
Double-Precision Whetstone                       55.0       2969.1    539.8
Execl Throughput                                 43.0       1885.1    438.4
File Copy 1024 bufsize 2000 maxblocks          3960.0     190709.6    481.6
File Copy 256 bufsize 500 maxblocks            1655.0      49307.3    297.9
File Copy 4096 bufsize 8000 maxblocks          5800.0     605439.9   1043.9
Pipe Throughput                               12440.0     323834.1    260.3
Pipe-based Context Switching                   4000.0      64195.0    160.5
Process Creation                                126.0       4995.4    396.5
Shell Scripts (1 concurrent)                     42.4       2536.7    598.3
Shell Scripts (8 concurrent)                      6.0        341.5    569.2
System Call Overhead                          15000.0     265428.6    177.0
System Benchmarks Index Score                                         443.7
======= Script description and score comparison completed! =======
Superbench.sh -- https://www.oldking.net/350.html
Mode  : Standard    Version : 1.1.7
Usage : wget -qO- sb.oldking.net | bash
CPU Model            : Intel Xeon E312xx (Sandy Bridge, IBRS update)
CPU Cores            : 1 Cores 2099.998 MHz x86_64
CPU Cache            : 16384 KB
OS                   : CentOS 7.6.1810 (64 Bit) KVM
Kernel               : 4.19.8-1.el7.elrepo.x86_64
Total Space          : 1.8 GB / 59.0 GB
Total RAM            : 48 MB / 1989 MB (604 MB Buff)
Total SWAP           : 0 MB / 0 MB
Uptime               : 0 days 0 hour 42 min
Load Average         : 1.48, 3.30, 2.21
TCP CC               : bbr
ASN & ISP            : AS35916, Multacom Corporation
Organization         : Multacom Corporation
Region               : California
I/O Speed( 1.0GB )   : 130 MB/s
I/O Speed( 1.0GB )   : 151 MB/s
I/O Speed( 1.0GB )   : 152 MB/s
Average I/O Speed    : 144.3 MB/s
Speedtest.net    61.02 Mbit/s      37.76 Mbit/s        34.51 ms
Fast.com         0.00 Mbit/s       82.4 Mbit/s         -
Nanjing 5G   CT  58.67 Mbit/s      13.29 Mbit/s        134.24 ms
Guangzhou 5G CT  67.94 Mbit/s      2.84 Mbit/s         213.72 ms
TianJin 5G   CU  64.48 Mbit/s      8.76 Mbit/s         214.57 ms
Shanghai 5G  CU  55.89 Mbit/s      10.50 Mbit/s        204.38 ms
Tianjin 5G   CM  55.57 Mbit/s      90.40 Mbit/s        202.01 ms
Nanjing 5G   CM  8.79 Mbit/s       6.84 Mbit/s         176.04 ms
Finished in  : 4 min 28 sec
Timestamp    : 2020-08-23 08:56:19 GMT+8
Results      : ./superbench.log
Share result:
· https://www.speedtest.net/result/c/0e628802-96fc-420c-93a1-d796dd9aec07
· https://paste.ubuntu.com/p/XtKMspRnPT/
是不是很垃圾?
发表于 2020-8-23 09:03:01 | 只看该作者
绑定,紫薯布丁
 楼主| 发表于 2020-8-23 09:16:29 | 只看该作者
绑定啥
发表于 2020-8-23 09:17:18 | 只看该作者
sas的盘不感兴趣 至少得ssd才能用啊
发表于 2020-8-23 09:39:31 | 只看该作者
还没卖完呢
 楼主| 发表于 2020-8-23 09:46:58 | 只看该作者
看样子卖不完
nico 该用户已被删除
发表于 2020-8-23 09:49:23 | 只看该作者
发表于 2020-8-23 10:34:27 | 只看该作者
mjj不积极啊
GMT+8, 2026-4-25 03:52 , Processed in 0.072723 second(s), 11 queries , Gzip On, MemCache On.
