查看: 3850|回复: 25
[不限流量] 【更新了UnixBench测试】cloudcone家H4节点,IO太低了,头石盘?
发表于 2020-7-20 17:16:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
上了cc家年付15刀的车,原来是在H44节点的,173段全球丢包严重,简直不能忍。
发工单问了客服,结果给我换了一个新节点H4,但这IO也太低了吧
CPU model            : Intel Xeon E312xx (Sandy Bridge, IBRS update)
Number of cores      : 1
CPU frequency        : 2499.998 MHz
Total size of Disk   : 59.0 GB (1.4 GB Used)
Total amount of Mem  : 1834 MB (58 MB Used)
Total amount of Swap : 0 MB (0 MB Used)
System uptime        : 0 days, 2 hour 19 min
Load average         : 0.00, 0.04, 0.05
OS                   : CentOS 7.6.1810
Arch                 : x86_64 (64 Bit)
Kernel               : 3.10.0-957.21.3.el7.x86_64
I/O speed(1st run)   : 34.7 MB/s
I/O speed(2nd run)   : 43.5 MB/s
I/O speed(3rd run)   : 37.7 MB/s
Average I/O speed    : 38.6 MB/s
Node Name                       IPv4 address            Download Speed
CacheFly                        205.234.175.175         57.0MB/s
Linode, Tokyo2, JP              139.162.65.37           9.00MB/s
Linode, Singapore, SG           139.162.23.4            7.24MB/s
Linode, London, UK              176.58.107.39           9.11MB/s
Linode, Frankfurt, DE           139.162.130.8           5.50MB/s
Linode, Fremont, CA             50.116.14.9             50.5MB/s
Softlayer, Dallas, TX           173.192.68.18           19.7MB/s
Softlayer, Seattle, WA          67.228.112.250          34.4MB/s
Softlayer, Frankfurt, DE        159.122.69.4            6.45MB/s
Softlayer, Singapore, SG        119.81.28.170           1.43MB/s
Softlayer, HongKong, CN         119.81.130.170          9.31MB/s
UnixBench性能测试,分数也是低得可怜
   BYTE UNIX Benchmarks (Version 5.1.3)
   System: mycc: GNU/Linux
   OS: GNU/Linux -- 3.10.0-957.21.3.el7.x86_64 -- #1 SMP Tue Jun 18 16:35:19 UTC 2019
   Machine: x86_64 (x86_64)
   Language: en_US.utf8 (charmap="UTF-8", collate="UTF-8")
   CPU 0: Intel Xeon E312xx (Sandy Bridge, IBRS update) (5000.0 bogomips)
          x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET
   09:48:18 up  3:10,  1 user,  load average: 1.46, 0.50, 0.36; runlevel 3
Benchmark Run: Mon Jul 20 2020 09:48:19 - 10:16:43
1 CPU in system; running 1 parallel copy of tests
Dhrystone 2 using register variables       26713682.3 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     3422.5 MWIPS (9.7 s, 7 samples)
Execl Throughput                               1501.7 lps   (29.9 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        145765.2 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks           38090.3 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks        484254.1 KBps  (30.0 s, 2 samples)
Pipe Throughput                              200055.7 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                  55268.7 lps   (10.0 s, 7 samples)
Process Creation                               4840.1 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                   2153.8 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                    292.4 lpm   (60.1 s, 2 samples)
System Call Overhead                         192652.4 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0   26713682.3   2289.1
Double-Precision Whetstone                       55.0       3422.5    622.3
Execl Throughput                                 43.0       1501.7    349.2
File Copy 1024 bufsize 2000 maxblocks          3960.0     145765.2    368.1
File Copy 256 bufsize 500 maxblocks            1655.0      38090.3    230.2
File Copy 4096 bufsize 8000 maxblocks          5800.0     484254.1    834.9
Pipe Throughput                               12440.0     200055.7    160.8
Pipe-based Context Switching                   4000.0      55268.7    138.2
Process Creation                                126.0       4840.1    384.1
Shell Scripts (1 concurrent)                     42.4       2153.8    508.0
Shell Scripts (8 concurrent)                      6.0        292.4    487.4
System Call Overhead                          15000.0     192652.4    128.4
System Benchmarks Index Score                                         381.7
======= Script description and score comparison completed! =======
发表于 2020-7-20 17:17:25 | 只看该作者
比毛子的钻石好啊
发表于 2020-7-20 17:18:24 | 只看该作者
发表于 2020-7-20 17:18:52 | 只看该作者
过段时间再瞧瞧
 楼主| 发表于 2020-7-20 17:19:05 | 只看该作者
樯橹 发表于 2020-7-20 17:17
比毛子的钻石好啊
原来的44节点还有一百多的速度呢
 楼主| 发表于 2020-7-20 17:20:41 | 只看该作者
llmwxt 发表于 2020-7-20 17:18
还可以啦,就这价格,你还想多少好?
难道非SSD就是这样的速度?
发表于 2020-7-20 17:20:45 | 只看该作者
我的情况比你好点 有没有要收的
发表于 2020-7-20 17:21:09 | 只看该作者
nico 该用户已被删除
发表于 2020-7-20 17:22:14 | 只看该作者
GMT+8, 2026-4-23 12:26 , Processed in 0.065695 second(s), 11 queries , Gzip On, MemCache On.
