查看: 2510|回复: 11
sharkserve的15刀测速 供各位mjj参考
发表于 2020-7-18 22:01:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
SharkServers,国外商家,2014年成立,前身为Fat Shark Ltd,2016年更改为SharkServers Ltd,提供虚拟主机、VPS、独立服务器等。VPS基于KVM VPS,数据中心有德国、芬兰、英国、荷兰、俄罗斯等,根据硬盘分为NVMe和SSD两类,NVMe仅为德国,SSD可选四个数据中心。现在有一款特价德国KVM VPS,性价比极高。
VPS 2 – NVMe
vCPU:2
内存:2 GB
空间:25 GB NVMe
流量:不限 / 月(1Gbps端口)
Hetnzer数据中心
IPv4:1
IPv6:1
使用优惠码:GO68KFAA9P
$15/年
https://www.sharkserve.rs/aff.php?aff=18&pid=79
真实版测速:
CPU Model            : Intel(R) Xeon(R) CPU E3-1275 v5 @ 3.60GHz
CPU Cores            : 2 Cores 3599.988 MHz x86_64
CPU Cache            : 8192 KB
OS                   : CentOS 7.7.1908 (64 Bit) KVM
Kernel               : 4.11.8-1.el7.elrepo.x86_64
Total Space          : 1.7 GB / 25.0 GB
Total RAM            : 57 MB / 1999 MB (96 MB Buff)
Total SWAP           : 0 MB / 0 MB
Uptime               : 0 days 0 hour 1 min
Load Average         : 0.00, 0.00, 0.00
TCP CC               : nanqinlang
ASN & ISP            : AS24940, Hetzner
Organization         : Server Block
Region               : Hesse
I/O Speed( 1.0GB )   : 741 MB/s
I/O Speed( 1.0GB )   : 806 MB/s
I/O Speed( 1.0GB )   : 793 MB/s
Average I/O Speed    : 780.0 MB/s
Speedtest.net    627.62 Mbit/s     636.42 Mbit/s       13.795 ms
Fast.com         0.00 Mbit/s       143.5 Mbit/s        -
Nanjing 5G   CT  0.78 Mbit/s       2.26 Mbit/s         -
Hefei 5G     CT  3.85 Mbit/s       59.29 Mbit/s        -
Guangzhou 5G CT  1.32 Mbit/s       14.72 Mbit/s        -
TianJin 5G   CU  18.51 Mbit/s      14.83 Mbit/s        -
Shanghai 5G  CU  14.97 Mbit/s      12.91 Mbit/s        -
Guangzhou 5G CU  17.69 Mbit/s      41.99 Mbit/s        -
Tianjin 5G   CM  2.85 Mbit/s       7.69 Mbit/s         -
Wuxi 5G      CM  4.74 Mbit/s       16.19 Mbit/s        -
Nanjing 5G   CM  0.67 Mbit/s       32.03 Mbit/s        -
Hefei 5G     CM  20.60 Mbit/s      24.69 Mbit/s        -
Changsha 5G  CM  14.47 Mbit/s      24.65 Mbit/s        -
Finished in  : 6 min 23 sec
Timestamp    : 2020-07-18 20:11:33 GMT+8
Results      : /root/superbench.log
speedtest:
Hosted by ANTEC Servicepool GmbH (Hannover) [120.85 km]: 14.118 ms
Testing download speed................................................................................
Download: 729.60 Mbit/s
Testing upload speed................................................................................................
Upload: 663.22 Mbit/s
unixbench:
Benchmark Run: 六 7月 18 2020 20:34:07 - 21:02:12
2 CPUs in system; running 1 parallel copy of tests
Dhrystone 2 using register variables       38813411.1 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     4674.1 MWIPS (9.8 s, 7 samples)
Execl Throughput                               4590.6 lps   (30.0 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks       1126686.5 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks          319027.9 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks       3048325.0 KBps  (30.0 s, 2 samples)
Pipe Throughput                             2361717.3 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                 309077.1 lps   (10.0 s, 7 samples)
Process Creation                               8879.8 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                   7480.7 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                   1250.5 lpm   (60.0 s, 2 samples)
System Call Overhead                        3965366.3 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0   38813411.1   3325.9
Double-Precision Whetstone                       55.0       4674.1    849.8
Execl Throughput                                 43.0       4590.6   1067.6
File Copy 1024 bufsize 2000 maxblocks          3960.0    1126686.5   2845.2
File Copy 256 bufsize 500 maxblocks            1655.0     319027.9   1927.7
File Copy 4096 bufsize 8000 maxblocks          5800.0    3048325.0   5255.7
Pipe Throughput                               12440.0    2361717.3   1898.5
Pipe-based Context Switching                   4000.0     309077.1    772.7
Process Creation                                126.0       8879.8    704.7
Shell Scripts (1 concurrent)                     42.4       7480.7   1764.3
Shell Scripts (8 concurrent)                      6.0       1250.5   2084.2
System Call Overhead                          15000.0    3965366.3   2643.6
System Benchmarks Index Score                                        1758.5
Benchmark Run: 六 7月 18 2020 21:02:12 - 21:30:27
2 CPUs in system; running 2 parallel copies of tests
Dhrystone 2 using register variables       70271190.4 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     9134.2 MWIPS (10.1 s, 7 samples)
Execl Throughput                               8799.0 lps   (29.9 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks       1414047.4 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks          377864.3 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks       4320671.2 KBps  (30.0 s, 2 samples)
Pipe Throughput                             4233419.4 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                 616976.7 lps   (10.0 s, 7 samples)
Process Creation                              17202.5 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                   9664.0 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                   1558.1 lpm   (60.0 s, 2 samples)
System Call Overhead                        5774054.7 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0   70271190.4   6021.5
Double-Precision Whetstone                       55.0       9134.2   1660.8
Execl Throughput                                 43.0       8799.0   2046.3
File Copy 1024 bufsize 2000 maxblocks          3960.0    1414047.4   3570.8
File Copy 256 bufsize 500 maxblocks            1655.0     377864.3   2283.2
File Copy 4096 bufsize 8000 maxblocks          5800.0    4320671.2   7449.4
Pipe Throughput                               12440.0    4233419.4   3403.1
Pipe-based Context Switching                   4000.0     616976.7   1542.4
Process Creation                                126.0      17202.5   1365.3
Shell Scripts (1 concurrent)                     42.4       9664.0   2279.2
Shell Scripts (8 concurrent)                      6.0       1558.1   2596.9
System Call Overhead                          15000.0    5774054.7   3849.4
System Benchmarks Index Score                                        2768.7
后台:
电信去程路由:
联通去程路由:
移动去程路由:
cherbim 该用户已被删除
发表于 2020-7-18 22:05:46 来自手机 | 只看该作者
CO2 该用户已被删除
发表于 2020-7-18 22:02:57 来自手机 | 只看该作者
 楼主| 发表于 2020-7-18 22:03:14 | 只看该作者
还有什么能测的吗?
发表于 2020-7-18 22:03:25 | 只看该作者
cpu分挺高啊,母鸡还没超爆?
发表于 2020-7-18 22:03:50 | 只看该作者
16年改名 18个aff?
发表于 2020-7-18 22:04:13 | 只看该作者
这个IO可以啊
 楼主| 发表于 2020-7-18 22:05:23 | 只看该作者
tdd 发表于 2020-7-18 22:03
16年改名 18个aff?
vpsid也是2位数,应该是刚开吧
 楼主| 发表于 2020-7-18 22:07:55 | 只看该作者
cherbim 发表于 2020-7-18 22:05
成立了六年,然而你的aff=18
哈哈,资料是网上搜索的,aff的确是18,前面好像也有一个测评,是17
GMT+8, 2026-4-23 02:23 , Processed in 0.073481 second(s), 12 queries , Gzip On, MemCache On.
