查看: 2691|回复: 5
新入手的photonvps,分数不错呢920分
发表于 2009-12-8 04:07:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  BYTE UNIX Benchmarks (Version 4.1.0)
  System -- Linux vps.www2qyorg.com 2.6.18-128.1.1.el5.028stab062.3 #1 SMP Sun May 10 18:54:51 MSD 2009 i686 i686 i386 GNU/Linux
  Start Benchmark Run: 2009年 12月 07日 星期一 09:29:09 PST
   1 interactive users.
   09:29:09 up 1 day,  8:19,  1 user,  load average: 0.07, 0.02, 0.00
  lrwxrwxrwx 1 root root 4 12-06 00:43 /bin/sh -> bash
  /bin/sh: symbolic link to `bash'
  /dev/simfs            20480000   2075560  18404440  11% /
Dhrystone 2 using register variables     9101764.2 lps   (10.0 secs, 10 samples)
Double-Precision Whetstone                 1974.2 MWIPS (10.2 secs, 10 samples)
System Call Overhead                     770495.8 lps   (10.0 secs, 10 samples)
Pipe Throughput                          870642.7 lps   (10.0 secs, 10 samples)
Pipe-based Context Switching              51391.2 lps   (10.0 secs, 10 samples)
Process Creation                          11786.3 lps   (30.0 secs, 3 samples)
Execl Throughput                           3691.0 lps   (29.5 secs, 3 samples)
File Read 1024 bufsize 2000 maxblocks    1454121.0 KBps  (30.0 secs, 3 samples)
File Write 1024 bufsize 2000 maxblocks   806949.0 KBps  (30.0 secs, 3 samples)
File Copy 1024 bufsize 2000 maxblocks    475072.0 KBps  (30.0 secs, 3 samples)
File Read 256 bufsize 500 maxblocks      424128.0 KBps  (30.0 secs, 3 samples)
File Write 256 bufsize 500 maxblocks     208288.0 KBps  (30.0 secs, 3 samples)
File Copy 256 bufsize 500 maxblocks      133618.0 KBps  (30.0 secs, 3 samples)
File Read 4096 bufsize 8000 maxblocks    3384232.0 KBps  (30.0 secs, 3 samples)
File Write 4096 bufsize 8000 maxblocks   1993315.0 KBps  (30.0 secs, 3 samples)
File Copy 4096 bufsize 8000 maxblocks    1154923.0 KBps  (30.0 secs, 3 samples)
Shell Scripts (1 concurrent)               4969.8 lpm   (60.0 secs, 3 samples)
Shell Scripts (8 concurrent)               1673.0 lpm   (60.0 secs, 3 samples)
Shell Scripts (16 concurrent)               924.6 lpm   (60.0 secs, 3 samples)
Arithmetic Test (type = short)           1965909.8 lps   (10.0 secs, 3 samples)
Arithmetic Test (type = int)             1988678.5 lps   (10.0 secs, 3 samples)
Arithmetic Test (type = long)            1987914.7 lps   (10.0 secs, 3 samples)
Arithmetic Test (type = float)           928086.6 lps   (10.0 secs, 3 samples)
Arithmetic Test (type = double)          924831.8 lps   (10.0 secs, 3 samples)
Arithoh                                       0.0 lps   (10.0 secs, 3 samples)
C Compiler Throughput                      1132.0 lpm   (60.0 secs, 3 samples)
Dc: sqrt(2) to 99 decimal places         477008.4 lpm   (30.0 secs, 3 samples)
Recursion Test--Tower of Hanoi           111062.2 lps   (20.0 secs, 3 samples)
                     INDEX VALUES
TEST                                        BASELINE     RESULT      INDEX
Dhrystone 2 using register variables        116700.0  9101764.2      779.9
Double-Precision Whetstone                      55.0     1974.2      358.9
Execl Throughput                                43.0     3691.0      858.4
File Copy 1024 bufsize 2000 maxblocks         3960.0   475072.0     1199.7
File Copy 256 bufsize 500 maxblocks           1655.0   133618.0      807.4
File Copy 4096 bufsize 8000 maxblocks         5800.0  1154923.0     1991.2
Pipe Throughput                              12440.0   870642.7      699.9
Process Creation                               126.0    11786.3      935.4
Shell Scripts (8 concurrent)                     6.0     1673.0     2788.3
System Call Overhead                         15000.0   770495.8      513.7
     FINAL SCORE                                                     920.0
目前感觉良好 (~ o ~)~zZ
发表于 2009-12-8 06:10:18 | 只看该作者
妈妈说爽一下是没有用了,要一直爽下去才是关键
发表于 2009-12-8 09:58:29 | 只看该作者
回复 2# 的帖子
呵呵,别爽过头就是杯具了。
发表于 2009-12-8 10:55:20 | 只看该作者
photonvps现在还没有控制面板啊?
发表于 2009-12-8 11:45:30 | 只看该作者
回复 4# 的帖子
有的话早有人宣传了。
发表于 2009-12-25 07:03:40 | 只看该作者
靠 这分数太恐怖了
GMT+8, 2026-4-29 19:52 , Processed in 0.066090 second(s), 10 queries , Gzip On, MemCache On.
