查看: 6482|回复: 5
GD空间是否限制http 连接呢·?
发表于 2009-1-5 21:46:34 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
因为我有另外的一个国外空间发来以下这样的信
我想知道 GD的 是否有这个限制·            675的HTTP 头
Hello,
Your account has been disabled because you were causing the server to crash due to the CPU and memory load you were generating.  At the time of suspension, your account had 675 HTTP connections (Apache) to port 80. This was causing the server to crash for all our clients on there and we can't allow this to happen.
Because of the volume of this traffic you must move to a dedicated server or to another hosting company. I'm sorry but your site is not fit for shared web hosting. You may want to consider upgrading to a dedicated server with us as we can have it up and migrate everything for you very quickly.
Please let us know what you would like to do, we would be happy to either migrate you to a new server with us as soon as possible or give you a backup to move somewhere else. Please respond ASAP as because of the severity of the problem we have to suspend your site to prevent the server from crashing.
If you have any questions or concerns about this issue, please do not hesitate to let us know.
Thank you.
PS. For more info please see our RUP at (http://www.site5.com/support/rup.php)
Best regards,
Prince Kumar
Systems Administrator
Site5 LLC
发表于 2009-1-6 10:21:20 | 只看该作者
回复 1# 的帖子
连接数太多的话会占用多的CPU,而CPU是限制的,所有会产生错误,也就是说CPU限制也会导致连接数的限制。
 楼主| 发表于 2009-1-6 11:09:24 | 只看该作者
原帖由 cpuer 于 2009-1-6 10:21 发表
那晕了··正如你说的 GD和一些其他的国外的都限制CPU的使用在百分之1  那···百分之1的限制是多少个连接数呢
发表于 2009-1-6 12:13:25 | 只看该作者
回复 3# 的帖子
这个无法直接有个等数值,只能说有个量,一般静态网页的话就量多些,动态网页就少些。
 楼主| 发表于 2009-1-6 17:25:16 | 只看该作者
原帖由 cpuer 于 2009-1-6 12:13 发表
谢谢呀··
发表于 2009-1-7 00:01:56 | 只看该作者
回复 5# 的帖子
GMT+8, 2026-4-20 18:01 , Processed in 0.062598 second(s), 9 queries , Gzip On, MemCache On.
