查看: 1810|回复: 9
autoclone安装问题,求大佬指点
发表于 2020-6-14 11:18:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
各位大佬,在电脑上安装autoclone,到创建SA总是报错,用的clash开了全局模式也不行。。。到底啥原因啊
  1. PS D:\AutoRclone-master> python gen_sa_accounts.py --quick-setup -1
  2. Traceback (most recent call last):
  3.   File "gen_sa_accounts.py", line 311, in <module>
  4.     resp = serviceaccountfactory(
  5.   File "gen_sa_accounts.py", line 178, in serviceaccountfactory
  6.     cloud = build('cloudresourcemanager', 'v1', credentials=creds)
  7.   File "C:\Program Files (x86)\Python38-32\lib\site-packages\googleapiclient\_helpers.py", line 134, in positional_wrapper
  8.     return wrapped(*args, **kwargs)
  9.   File "C:\Program Files (x86)\Python38-32\lib\site-packages\googleapiclient\discovery.py", line 245, in build
  10.     content = _retrieve_discovery_doc(
  11.   File "C:\Program Files (x86)\Python38-32\lib\site-packages\googleapiclient\discovery.py", line 305, in _retrieve_discovery_doc
  12.     resp, content = http.request(actual_url)
  13.   File "C:\Program Files (x86)\Python38-32\lib\site-packages\httplib2\__init__.py", line 1985, in request
  14.     (response, content) = self._request(
  15.   File "C:\Program Files (x86)\Python38-32\lib\site-packages\httplib2\__init__.py", line 1650, in _request
  16.     (response, content) = self._conn_request(
  17.   File "C:\Program Files (x86)\Python38-32\lib\site-packages\httplib2\__init__.py", line 1557, in _conn_request
  18.     conn.connect()
  19.   File "C:\Program Files (x86)\Python38-32\lib\site-packages\httplib2\__init__.py", line 1391, in connect
  20.     raise socket_err
  21.   File "C:\Program Files (x86)\Python38-32\lib\site-packages\httplib2\__init__.py", line 1324, in connect
  22.     sock.connect((self.host, self.port))
  23. TimeoutError: [WinError 10060] 由于连接方在一段时间后没有正确答复或连接的主机没有反应,连接尝试失败。
发表于 2020-6-14 11:29:18 来自手机 | 只看该作者
 楼主| 发表于 2020-6-14 11:31:24 | 只看该作者
清羽大魔王 发表于 2020-6-14 11:29
这是网络问题(没上网代理),没用过clash,不过众所周知,上网代理软件的全局都是伪全局,用Proxifier, ...
但是我用curl google.com,返回的信息是可以访问啊。。。。
发表于 2020-6-14 11:32:17 | 只看该作者
i65u 该用户已被删除
发表于 2020-6-14 11:33:18 | 只看该作者
发表于 2020-6-14 11:36:35 | 只看该作者
发表于 2020-6-14 11:40:18 | 只看该作者
没有连到谷歌服务器,用代理
 楼主| 发表于 2020-6-14 11:50:52 | 只看该作者
清羽大魔王 发表于 2020-6-14 11:36
你还是用国外vps创建吧,或者设置一下powershell默认代理
怎么设置呢,谷歌了几种方法,最后都还是不行。。。
 楼主| 发表于 2020-6-14 11:56:22 | 只看该作者
搞了半天,试了各种办法
用这个命令才行
  1. $env:HTTPS_PROXY="http://127.0.0.1:1080"
  2. $env:HTTP_PROXY="http://127.0.0.1:1080"
GMT+8, 2026-4-20 03:14 , Processed in 0.065631 second(s), 11 queries , Gzip On, MemCache On.
