查看: 2036|回复: 4
[翻译] 使用postfix中继outlook报错
发表于 2020-6-11 09:57:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
main.cf配置文件
  1. smtpd_relay_restrictions = permit_mynetworks permit_sasl_authenticated defer_unauth_destination
  2. myhostname = gov.996icu.com
  3. alias_maps = hash:/etc/aliases
  4. alias_database = hash:/etc/aliases
  5. myorigin = /etc/mailname
  6. mydestination = $myhostname, gov.996icu.com, localhost.wanvi.net, , localhost
  7. relayhost = smtp.office365.com:587
  8. mynetworks = 127.0.0.0/8 172.17.17.91/18  [::ffff:127.0.0.0]/104 [::1]/128
  9. mailbox_size_limit = 0
  10. recipient_delimiter = +
  11. inet_interfaces = loopback-only
  12. inet_protocols = ipv4
  13. smtp_sasl_auth_enable = yes
  14. smtp_sasl_password_maps = hash:/etc/postfix/sasl_passwd
  15. smtp_sasl_security_options = noanonymous
  16. smtp_tls_security_level = may
  17. header_size_limit = 4096000
账户密码配置文件/etc/postfix/sasl_passwd
  1. smtp.office365.com:587 user@outlook.com:passwd
  1. Jun 11 09:53:45 gov postfix/smtpd[15473]: connect from localhost[127.0.0.1]
  2. Jun 11 09:53:45 gov postfix/smtpd[15473]: 770352007F3: client=localhost[127.0.0.1]
  3. Jun 11 09:53:45 gov postfix/cleanup[15475]: 770352007F3: message-id=<bd47daaf5283c9bd576ad128dc529428@996icu.com>
  4. Jun 11 09:53:45 gov postfix/qmgr[15468]: 770352007F3: from=<pengxp1996@outlook.com>, size=655, nrcpt=1 (queue active)
  5. Jun 11 09:53:45 gov postfix/smtpd[15473]: disconnect from localhost[127.0.0.1] ehlo=1 mail=1 rcpt=1 data=1 quit=1 commands=5
  6. Jun 11 09:53:49 gov postfix/smtp[15470]: 088E32007EC: SASL authentication failed; server smtp.office365.com[40.100.54.2] said: 535 5.7.3 Authentication unsuccessful [HK2PR0302CA0009.apcprd03.prod.outlook.com]
  7. Jun 11 09:53:51 gov postfix/smtp[15476]: 770352007F3: SASL authentication failed; server smtp.office365.com[40.100.54.242] said: 535 5.7.3 Authentication unsuccessful [HK2PR03CA0056.apcprd03.prod.outlook.com]
  8. Jun 11 09:53:56 gov postfix/smtp[15470]: 088E32007EC: SASL authentication failed; server smtp.office365.com[40.100.2.98] said: 535 5.7.3 Authentication unsuccessful [HK2PR02CA0200.apcprd02.prod.outlook.com]
  9. Jun 11 09:53:59 gov postfix/smtp[15476]: 770352007F3: SASL authentication failed; server smtp.office365.com[52.98.85.194] said: 535 5.7.3 Authentication unsuccessful [HK2PR06CA0023.apcprd06.prod.outlook.com]
懂的大佬快来看看?
问题最终发生在微软smtp服务器拒绝身份验证,这一个安全策略,只需要为不支持多重验证的应用创建应用密码即可。
发表于 2020-6-11 10:48:24 | 只看该作者
把提交端口从587换成25看看有没有变化?
 楼主| 发表于 2020-6-11 10:59:11 | 只看该作者
outlook提供的smtp为smtp.office365.com:465
没有开放多余端口
发表于 2020-6-11 11:04:01 | 只看该作者
没有开放多余端口
outlook客户端提交邮件确实只用465,但是你这个不是用的outlook客户端,只是向outlook服务器提交邮件,应该用587/25都可以吧,587验证不过可以试一下25端口提交
 楼主| 发表于 2020-6-11 14:50:46 | 只看该作者
shc 发表于 2020-6-11 11:04
outlook客户端提交邮件确实只用465,但是你这个不是用的outlook客户端,只是向outlook服务器提交邮件,应 ...
我配置的就是587,一样的结果。25是关闭的。可能加密方式不一样:STARTTLS
GMT+8, 2026-4-30 05:35 , Processed in 0.058825 second(s), 10 queries , Gzip On, MemCache On.
