查看: 2788|回复: 16
100元带账号出一台蘑菇韩国机器
发表于 2020-6-10 15:51:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
cpu:双路e5-2630l
内存:32G
硬盘:480G ssd
带宽:韩国10M上下对等
续费价格:29美元
到期:2020/06/16
有需要的请左边QQ联系
发表于 2020-6-11 16:58:43 | 只看该作者
不稳定
发表于 2020-6-11 16:59:41 | 只看该作者
大佬终于顶不住了?  我也开始找机器了.... 因为我也顶不住了....
2020-06-06 00:23:20:{"high_ms_num": 0, "mix_ping_ms": 62, "max_ping_ms": 78, "timeout_num": 6}
2020-06-06 00:36:35:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 00:37:55:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 00:39:15:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 00:40:35:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 00:41:55:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 00:43:15:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 00:44:35:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 00:45:55:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 00:47:15:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 00:48:35:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 00:49:55:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 00:51:15:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 00:52:35:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 00:53:55:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 00:55:15:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 00:56:35:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 00:57:55:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 00:59:15:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 01:00:35:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 01:01:55:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 01:03:15:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 01:04:35:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 01:05:55:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 01:07:15:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 01:08:35:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 01:09:55:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 01:11:15:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 01:12:35:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 01:13:55:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 01:15:15:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 01:16:35:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 01:17:55:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 01:19:15:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 01:20:35:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 01:21:55:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 01:23:15:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 01:24:35:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 01:25:55:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 01:27:15:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 01:28:35:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 01:29:55:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 01:31:15:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 01:32:35:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 01:33:55:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 01:35:15:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 01:36:35:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 01:37:55:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 01:39:15:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 01:40:35:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 01:41:55:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 01:43:15:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 01:44:35:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 01:45:55:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 01:47:15:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 01:48:35:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 01:49:55:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 01:51:15:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 01:52:35:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 01:53:55:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 01:55:16:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 01:56:36:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 01:57:56:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 01:59:16:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 02:00:36:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 02:01:56:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 02:03:16:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 02:04:36:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 02:05:56:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 02:58:58:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 03:00:18:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 03:01:38:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-06 18:38:16:{"high_ms_num": 0, "mix_ping_ms": 62, "max_ping_ms": 62, "timeout_num": 7}
2020-06-06 22:32:36:{"high_ms_num": 6, "mix_ping_ms": 93, "max_ping_ms": 110, "timeout_num": 0}
2020-06-06 22:40:55:{"high_ms_num": 6, "mix_ping_ms": 92, "max_ping_ms": 110, "timeout_num": 0}
2020-06-06 22:46:52:{"high_ms_num": 6, "mix_ping_ms": 92, "max_ping_ms": 110, "timeout_num": 1}
2020-06-06 22:55:10:{"high_ms_num": 8, "mix_ping_ms": 94, "max_ping_ms": 110, "timeout_num": 1}
2020-06-06 22:59:55:{"high_ms_num": 6, "mix_ping_ms": 77, "max_ping_ms": 110, "timeout_num": 0}
2020-06-06 23:05:51:{"high_ms_num": 7, "mix_ping_ms": 93, "max_ping_ms": 110, "timeout_num": 1}
2020-06-06 23:09:25:{"high_ms_num": 6, "mix_ping_ms": 77, "max_ping_ms": 110, "timeout_num": 1}
2020-06-06 23:17:42:{"high_ms_num": 10, "mix_ping_ms": 108, "max_ping_ms": 110, "timeout_num": 0}
2020-06-06 23:20:04:{"high_ms_num": 10, "mix_ping_ms": 108, "max_ping_ms": 110, "timeout_num": 0}
2020-06-06 23:44:59:{"high_ms_num": 7, "mix_ping_ms": 94, "max_ping_ms": 109, "timeout_num": 0}
2020-06-06 23:47:21:{"high_ms_num": 6, "mix_ping_ms": 78, "max_ping_ms": 109, "timeout_num": 0}
2020-06-06 23:48:32:{"high_ms_num": 7, "mix_ping_ms": 93, "max_ping_ms": 109, "timeout_num": 0}
2020-06-06 23:56:54:{"high_ms_num": 6, "mix_ping_ms": 78, "max_ping_ms": 110, "timeout_num": 1}
2020-06-07 00:08:43:{"high_ms_num": 10, "mix_ping_ms": 108, "max_ping_ms": 110, "timeout_num": 0}
2020-06-07 00:17:04:{"high_ms_num": 10, "mix_ping_ms": 108, "max_ping_ms": 111, "timeout_num": 0}
2020-06-07 00:26:34:{"high_ms_num": 8, "mix_ping_ms": 94, "max_ping_ms": 110, "timeout_num": 0}
2020-06-07 00:34:52:{"high_ms_num": 10, "mix_ping_ms": 108, "max_ping_ms": 110, "timeout_num": 0}
2020-06-07 00:40:49:{"high_ms_num": 6, "mix_ping_ms": 92, "max_ping_ms": 110, "timeout_num": 0}
2020-06-07 16:13:26:{"high_ms_num": 2, "mix_ping_ms": 93, "max_ping_ms": 109, "timeout_num": 6}
2020-06-07 18:35:47:{"high_ms_num": 0, "mix_ping_ms": 61, "max_ping_ms": 62, "timeout_num": 7}
2020-06-08 13:07:14:{"high_ms_num": 2, "mix_ping_ms": 140, "max_ping_ms": 141, "timeout_num": 8}
2020-06-08 17:27:04:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-08 19:19:59:{"high_ms_num": 0, "mix_ping_ms": 61, "max_ping_ms": 62, "timeout_num": 6}
2020-06-08 19:29:37:{"high_ms_num": 0, "mix_ping_ms": 62, "max_ping_ms": 62, "timeout_num": 6}
2020-06-08 19:35:38:{"high_ms_num": 0, "mix_ping_ms": 62, "max_ping_ms": 93, "timeout_num": 6}
2020-06-08 20:27:31:{"high_ms_num": 0, "mix_ping_ms": 62, "max_ping_ms": 62, "timeout_num": 6}
2020-06-09 11:34:37:{"high_ms_num": 6, "mix_ping_ms": 108, "max_ping_ms": 110, "timeout_num": 4}
2020-06-09 14:32:25:{"high_ms_num": 0, "mix_ping_ms": 62, "max_ping_ms": 78, "timeout_num": 6}
2020-06-09 14:34:58:{"high_ms_num": 0, "mix_ping_ms": 62, "max_ping_ms": 78, "timeout_num": 7}
2020-06-09 14:36:14:{"high_ms_num": 0, "mix_ping_ms": 62, "max_ping_ms": 78, "timeout_num": 6}
2020-06-09 19:33:59:{"high_ms_num": 0, "mix_ping_ms": 46, "max_ping_ms": 47, "timeout_num": 6}
2020-06-09 19:36:25:{"high_ms_num": 1, "mix_ping_ms": 93, "max_ping_ms": 109, "timeout_num": 6}
2020-06-09 23:44:39:{"high_ms_num": 0, "mix_ping_ms": 62, "max_ping_ms": 78, "timeout_num": 7}
2020-06-10 00:21:26:{"high_ms_num": 0, "mix_ping_ms": 46, "max_ping_ms": 62, "timeout_num": 6}
2020-06-10 01:56:17:{"high_ms_num": 0, "mix_ping_ms": 46, "max_ping_ms": 77, "timeout_num": 7}
2020-06-10 02:08:16:{"high_ms_num": 0, "mix_ping_ms": 63, "max_ping_ms": 63, "timeout_num": 9}
2020-06-10 02:20:16:{"high_ms_num": 0, "mix_ping_ms": 77, "max_ping_ms": 78, "timeout_num": 7}
2020-06-10 02:26:16:{"high_ms_num": 0, "mix_ping_ms": 62, "max_ping_ms": 78, "timeout_num": 8}
2020-06-10 07:05:37:{"high_ms_num": 0, "mix_ping_ms": 62, "max_ping_ms": 78, "timeout_num": 6}
2020-06-10 15:09:19:{"high_ms_num": 0, "mix_ping_ms": 62, "max_ping_ms": 62, "timeout_num": 9}
2020-06-10 15:10:37:{"high_ms_num": 0, "mix_ping_ms": 62, "max_ping_ms": 77, "timeout_num": 8}
2020-06-10 15:11:54:{"high_ms_num": 0, "mix_ping_ms": 47, "max_ping_ms": 78, "timeout_num": 6}
2020-06-10 15:13:14:{"high_ms_num": 0, "mix_ping_ms": 0, "max_ping_ms": 0, "timeout_num": 10}
2020-06-10 15:14:32:{"high_ms_num": 0, "mix_ping_ms": 77, "max_ping_ms": 78, "timeout_num": 8}
2020-06-10 15:15:51:{"high_ms_num": 0, "mix_ping_ms": 77, "max_ping_ms": 77, "timeout_num": 9}
2020-06-10 16:47:50:{"high_ms_num": 0, "mix_ping_ms": 30, "max_ping_ms": 47, "timeout_num": 6}
2020-06-10 17:33:02:{"high_ms_num": 10, "mix_ping_ms": 203, "max_ping_ms": 266, "timeout_num": 0}
2020-06-10 17:34:14:{"high_ms_num": 10, "mix_ping_ms": 234, "max_ping_ms": 266, "timeout_num": 0}
2020-06-10 17:35:27:{"high_ms_num": 10, "mix_ping_ms": 203, "max_ping_ms": 266, "timeout_num": 0}
2020-06-10 17:36:39:{"high_ms_num": 10, "mix_ping_ms": 202, "max_ping_ms": 250, "timeout_num": 0}
2020-06-10 17:37:52:{"high_ms_num": 10, "mix_ping_ms": 187, "max_ping_ms": 266, "timeout_num": 0}
2020-06-10 17:40:21:{"high_ms_num": 9, "mix_ping_ms": 171, "max_ping_ms": 282, "timeout_num": 1}
2020-06-10 22:32:45:{"high_ms_num": 0, "mix_ping_ms": 31, "max_ping_ms": 78, "timeout_num": 6}
2020-06-10 22:43:29:{"high_ms_num": 0, "mix_ping_ms": 30, "max_ping_ms": 46, "timeout_num": 6}
2020-06-11 00:40:04:{"high_ms_num": 0, "mix_ping_ms": 78, "max_ping_ms": 78, "timeout_num": 8}
2020-06-11 13:19:30:{"high_ms_num": 0, "mix_ping_ms": 31, "max_ping_ms": 47, "timeout_num": 6}
发表于 2020-6-11 17:01:19 | 只看该作者
mjj骂骂咧咧陆陆续续下了车
紫薯布丁
发表于 2020-6-11 17:03:46 | 只看该作者
将就用吧,,实在不行就换,,,我感觉还能再战
发表于 2020-6-11 17:07:58 | 只看该作者
官网KS3  27.8买了一台
发表于 2020-6-11 17:08:37 | 只看该作者
这个多少个IP?
发表于 2020-6-11 18:35:38 | 只看该作者
感觉蘑菇技术一般
发表于 2020-6-11 20:10:15 | 只看该作者
2020-06-06 00:23:20:{"high_ms_num": 0, ...
我门家 比他好很多
发表于 2020-6-11 20:11:23 | 只看该作者
不过。。。
蘑菇不是挺好的么。。
我于总大佬的机子
威武的很~~~
GMT+8, 2026-5-2 00:14 , Processed in 0.064390 second(s), 10 queries , Gzip On, MemCache On.
