查看: 2443|回复: 17
[Windows VPS] LiteUnit的同学有ACME成功的吗?
发表于 2020-5-19 15:17:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
刚刚翻车后重开的 LiteUnit 鸡(自购买日期起补了三个月),部署了 Caddy2 之后,ACME 死活联络不上:
  1. May 19 13:45:41 tupolev caddy[21314]: 2020/05/19 13:45:41 [ERROR] Making new ACME client: get directory at 'https://acme-staging-v02.api.letsencrypt.org/directory': Get "https://acme-staging-v02.api.letsencrypt.org/directory": dial tcp 172.65.46.172:443: connect: connection timed out (attempt 1/2)
  2. May 19 13:45:44 tupolev caddy[21314]: 2020/05/19 13:45:44 [ERROR] Making new ACME client: get directory at 'https://acme-staging-v02.api.letsencrypt.org/directory': Get "https://acme-staging-v02.api.letsencrypt.org/directory": dial tcp 172.65.46.172:443: connect: connection timed out (attempt 1/2)
  3. May 19 13:45:47 tupolev caddy[21314]: 2020/05/19 13:45:47 [ERROR] Making new ACME client: get directory at 'https://acme-staging-v02.api.letsencrypt.org/directory': Get "https://acme-staging-v02.api.letsencrypt.org/directory": dial tcp 172.65.46.172:443: connect: connection timed out (attempt 2/2)
  4. May 19 13:45:47 tupolev caddy[21314]: 2020/05/19 13:45:47 [ERROR] attempt 5: [域名删了] Obtain: get directory at 'https://acme-staging-v02.api.letsencrypt.org/directory': Get "https://acme-staging-v02.api.letsencrypt.org/directory": dial tcp 172.65.46.172:443: connect: connection timed out - retrying in 10m0s (10m48.265728948s/720h0m0s elapsed)...
直接 ping 172.65.46.172 或 acme-staging-v02.api.letsencrypt.org 也没戏(别的鸡都可以),不知道是我个别IP问题还是它家网络/防火墙的锅。最后只能暂时先手动干证书了。
发工单前就想问问有没有成功请求 ACME 的 LiteUnit 同学?
发表于 2020-5-19 15:22:29 | 只看该作者
用手动dns申请他不香嘛?
发表于 2020-5-19 15:23:11 | 只看该作者
caddy2怎么做代理,所说一条命令就是反向代理,我没成功过,不知道原因。也找不到文档。
发表于 2020-5-19 15:23:21 | 只看该作者
国内鸡?写个hosts吧
发表于 2020-5-19 15:24:51 | 只看该作者
老板给我说的是延长三个月呀  怎么是自购买日期起补了三个月?
 楼主| 发表于 2020-5-19 15:31:49 | 只看该作者
4月29上的车,昨天回魂,从4月29算起补了三个月
 楼主| 发表于 2020-5-19 15:33:39 | 只看该作者
32MB.CN 发表于 2020-5-19 15:23
国内鸡?写个hosts吧
毛子鸡,IP也连不上,不是DNS问题
 楼主| 发表于 2020-5-19 15:35:19 | 只看该作者
jhu 发表于 2020-5-19 15:23
caddy2怎么做代理,所说一条命令就是反向代理,我没成功过,不知道原因。也找不到文档。 ...
这个反代模组的文档算是Caddy里面写得比较详细的了:
https://caddyserver.com/docs/caddyfile/directives/reverse_proxy
发表于 2020-5-19 15:41:31 | 只看该作者
https://caddyserver.com/docs/caddyfile/directive ...
读过那个文档,配置代理到有图比没有成功。
发表于 2020-5-19 19:38:11 | 只看该作者
老哥还能连上小鸡吗  我又失联了。。
GMT+8, 2026-4-16 07:25 , Processed in 0.069355 second(s), 10 queries , Gzip On, MemCache On.
