查看: 8915|回复: 37
一键v2ray对域名有要求吗
 关闭 [复制链接]
发表于 2020-5-17 00:04:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
https://github.com/wulabing/V2Ray_ws-tls_bash_onekey
用freenom的免费域名可以吗
为什么安装到最后报错 请大家帮忙看看
域名设置了a记录绑定了ip 可以ping通
[Sat May 16 23:54:01 CST 2020] Your cert is in  /root/.acme.sh/www.aaa.tk_ecc/www.aaa.tk.cer
[Sat May 16 23:54:01 CST 2020] Your cert key is in  /root/.acme.sh/www.aaa.tk_ecc/www.aaa.tk.key
[Sat May 16 23:54:01 CST 2020] The intermediate CA cert is in  /root/.acme.sh/www.aaa.tk_ecc/ca.cer
[Sat May 16 23:54:01 CST 2020] And the full chain certs is there:  /root/.acme.sh/www.aaa.tk_ecc/fullchain.cer
[OK]  SSL 证书测试签发成功,开始正式签发
[Sat May 16 23:54:06 CST 2020] Standalone mode.
[Sat May 16 23:54:06 CST 2020] Creating domain key
[Sat May 16 23:54:06 CST 2020] The domain key is here: /root/.acme.sh/www.aaa.tk_ecc/www.aaa.tk.key
[Sat May 16 23:54:07 CST 2020] Single domain='www.aaa.tk'
[Sat May 16 23:54:07 CST 2020] Getting domain auth token for each domain
[Sat May 16 23:54:10 CST 2020] Getting webroot for domain='www.aaa.tk'
[Sat May 16 23:54:10 CST 2020] Verifying: www.aaa.tk
[Sat May 16 23:54:10 CST 2020] Standalone mode server
[Sat May 16 23:54:15 CST 2020] www.aaa.tk:Verify erroruring secondary validation: No valid IP addresses found for www.aaa.tk
[Sat May 16 23:54:15 CST 2020] Please add '--debug' or '--log' to check more details.
[Sat May 16 23:54:15 CST 2020] See: https://github.com/acmesh-official/acme.sh/wiki/How-to-debug-acme.sh
[错误]  SSL 证书生成失败
发表于 2020-5-17 12:00:03 | 只看该作者
wifitry 发表于 2020-5-17 07:35
很多只会用一键
用那些自制一键脚本,问题多多。制作的人很多也是傻X ,那个233把alterId 服务客户两端都设成233,导致慢得卵都跌
发表于 2020-5-17 19:21:37 | 只看该作者
ramonde 发表于 2020-5-17 18:19
alterId 设置成不一样,我测试了并没提高速度,新伯力
当使用WS+TLS+WEB 模式进行反代时,alterId 越大,会导致暴内存和CPU。官方建议设置成4 ,那个233脚本alterId设置过大会有错误日志 drop connection, obfuscation= AlterID
发表于 2020-5-17 00:05:46 | 只看该作者
对域名没要求哦
发表于 2020-5-17 00:05:51 | 只看该作者
没用过一键,手动搭建也可以啊
发表于 2020-5-17 00:07:28 | 只看该作者
cloudflare DNS屏蔽了部分免费域名,如果要用dns api来签证书的话就别用cf
发表于 2020-5-17 00:09:00 | 只看该作者
前缀不用www,随便换个其他的试试
发表于 2020-5-17 00:19:11 | 只看该作者
好像是cf屏蔽了免费域名的api,所以脚本调用api申请证书会失败
发表于 2020-5-17 00:21:59 | 只看该作者
根本就没套CF
[Sun May 17 00:18:56 CST 2020] Getting domain auth token for each domain
[Sun May 17 00:19:00 CST 2020] Getting webroot for domain='kkk.321ss.date'
[Sun May 17 00:19:00 CST 2020] Verifying: kkk.321ss.date
[Sun May 17 00:19:00 CST 2020] Standalone mode server
[Sun May 17 00:19:06 CST 2020] Pending
[Sun May 17 00:19:09 CST 2020] Pending
[Sun May 17 00:19:12 CST 2020] kkk.321ss.date:Verify errorNS problem: SERVFAIL looking up A for okk.1ss.date - the domain's nameservers may be malfunctioning
[Sun May 17 00:19:12 CST 2020] Please add '--debug' or '--log' to check more details.
[Sun May 17 00:19:12 CST 2020] See: https://github.com/acmesh-official/acme.sh/wiki/How-to-debug-acme.sh
[错误]  SSL 证书测试签发失败
我相信楼主跟我一样的情况,从昨天开始 一键V2 就一直是这样了,有大佬知道怎么搞吗???
发表于 2020-5-17 00:23:04 | 只看该作者
正常来说,对域名没要求。如果过程中出了什么错误,检查下所做的步骤吧
发表于 2020-5-17 00:23:06 | 只看该作者
楼主我跟你的情况一样的,前几天都还是正常一键走完,昨天开始就这样了
GMT+8, 2026-4-16 16:44 , Processed in 0.069199 second(s), 11 queries , Gzip On, MemCache On.
