查看: 3051|回复: 15
15.3/17.1跑个测速
发表于 2020-4-29 21:35:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
简述:IO都限制到50,17.1的CPU比15.3的频率高,端口多30,有raid10,但15.3的流量多100G.
15.3结果
CPU Model            : Common KVM processor
CPU Cores            : 1 Cores 2099.998 MHz x86_64
CPU Cache            : 16384 KB
OS                   : Debian GNU/Linux 9 (64 Bit) KVM
Kernel               : 4.9.0-8-amd64
Total Space          : 1.1 GB / 9.8 GB
Total RAM            : 33 MB / 492 MB (277 MB Buff)
Total SWAP           : 0 MB / 0 MB
Uptime               : 0 days 0 hour 5 min
Load Average         : 0.29, 0.08, 0.02
TCP CC               : cubic
ASN & ISP            : AS209484, Asia Communications Co., Limited
Organization         : Network and Information Technology Limited
Region               : Florida
I/O Speed( 1.0GB )   : 51.0 MB/s
I/O Speed( 1.0GB )   : 52.1 MB/s
I/O Speed( 1.0GB )   : 52.4 MB/s
Average I/O Speed    : 51.8 MB/s
Speedtest.net    3.09 Mbit/s       1.03 Mbit/s         (*) 109.91 ms
Fast.com         0.00 Mbit/s       59.7 Mbit/s         -
Beijing 5G   CT  4.60 Mbit/s       3.22 Mbit/s         -
Nanjing 5G   CT  11.37 Mbit/s      4.23 Mbit/s         -
Hefei 5G     CT  5.63 Mbit/s       14.93 Mbit/s        -
Guangzhou 5G CT  3.40 Mbit/s       2.96 Mbit/s         -
TianJin 5G   CU  2.87 Mbit/s       5.49 Mbit/s         -
Shanghai 5G  CU  9.01 Mbit/s       6.37 Mbit/s         -
Guangzhou 5G CU  1.48 Mbit/s       5.08 Mbit/s         -
Tianjin 5G   CM  2.07 Mbit/s       1.13 Mbit/s         -
Wuxi 5G      CM  0.50 Mbit/s       3.54 Mbit/s         -
Nanjing 5G   CM  0.33 Mbit/s       5.36 Mbit/s         -
Hefei 5G     CM  3.40 Mbit/s       6.91 Mbit/s         -
Changsha 5G  CM  0.30 Mbit/s       1.95 Mbit/s         -
Finished in  : 10 min 33 sec
Timestamp    : 2020-04-29 21:34:59 GMT+8
Results      : /root/superbench.log
 楼主| 发表于 2020-4-29 21:36:35 | 只看该作者
17.1测速
Superbench.sh -- https://www.oldking.net/350.html
Mode  : Standard    Version : 1.1.6
Usage : wget -qO- git.io/superbench.sh | bash
Fixed bugs version usage : wget -qO- https://git.io/Jvh0J | bash
Fixed version 3
CPU Cores            : 1 Cores 2799.998 MHz x86_64
OS                   : CentOS 7.6.1810 (64 Bit) KVM
Kernel               : 3.10.0-957.10.1.el7.x86_64
Total Space          : 3.8 GB / 10.0 GB
Total RAM            : 359 MB / 487 MB (120 MB Buff)
Total SWAP           : 149 MB / 1024 MB
Uptime               : 2 days 0 hour 54 min
Load Average         : 0.00, 0.01, 0.05
TCP CC               : cubic
Region               : Florida
I/O Speed( 1.0GB )   : 48.8 MB/s
I/O Speed( 1.0GB )   : 52.5 MB/s
I/O Speed( 1.0GB )   : 52.3 MB/s
Average I/O Speed    : 51.2 MB/s
Speedtest.net    44.59 Mbit/s      2.47 Mbit/s         (*) 125.415 ms
Fast.com         0.00 Mbit/s       27.4 Mbit/s         -
Beijing 5G   CT  3.88 Mbit/s       1.01 Mbit/s         -
Nanjing 5G   CT  10.20 Mbit/s      4.08 Mbit/s         -
Hefei 5G     CT  9.95 Mbit/s       17.18 Mbit/s        -
Guangzhou 5G CT  1.68 Mbit/s       3.99 Mbit/s         -
TianJin 5G   CU  3.72 Mbit/s       14.41 Mbit/s        -
Shanghai 5G  CU  4.24 Mbit/s       2.47 Mbit/s         -
Guangzhou 5G CU  1.85 Mbit/s       7.45 Mbit/s         -
Tianjin 5G   CM  1.64 Mbit/s       8.42 Mbit/s         -
Wuxi 5G      CM  0.71 Mbit/s       1.59 Mbit/s         -
Nanjing 5G   CM  0.26 Mbit/s       3.72 Mbit/s         -
Hefei 5G     CM  10.17 Mbit/s      27.34 Mbit/s        -
Changsha 5G  CM  0.24 Mbit/s       2.00 Mbit/s         -
Finished in  : 10 min 4 sec
Timestamp    : 2020-04-29 21:38:09 GMT+8
发表于 2020-4-29 21:36:50 | 只看该作者
发表于 2020-4-29 21:37:22 | 只看该作者
这速度看着一般啊,真的是70MB嘛  还是说现在折腾的人有点多
发表于 2020-4-29 21:37:49 | 只看该作者
我就静静的看着不说话
发表于 2020-4-29 21:43:44 | 只看该作者
正在装 bbrplus 4.14.173
 楼主| 发表于 2020-4-29 21:45:54 | 只看该作者
MJJ都在折腾,明天再说,今天先放着了。发现15.3的延迟比17.1的延迟低了15MS
发表于 2020-4-29 21:47:35 | 只看该作者
bax 发表于 2020-4-29 21:45
MJJ都在折腾,明天再说,今天先放着了。发现15.3的延迟比17.1的延迟低了15MS ...
不是一样的东西吗。
发表于 2020-4-29 21:48:25 | 只看该作者
一般般吧,但是价钱够顶
  --< mjj专用白薯布丁 >--
发表于 2020-4-29 21:50:01 | 只看该作者
GMT+8, 2026-4-16 05:45 , Processed in 0.067340 second(s), 10 queries , Gzip On, MemCache On.
