查看: 5215|回复: 10
[翻译] 收到 84 的邮件 ,我该怎么回复?
发表于 2011-7-21 22:01:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Please be advised that your VPS usage is currently affecting service to other clientele sharing the hardware node.
Your service may have had to be suspended to cease such load on the hardware node, or it may be running excessively slow right now, though still operational.
The reason your VPS is causing a heavy load is due to either the sheer amount of processes, or resource intensive type of usage/processes. This not only slows down your own VPS, but all other VPS sharing the same system. This may not mean you are utilizing more than your allocated/purchased resources, although that is possible (in which case you may receive a notice that you should upgrade your VPS package accordingly). Often, this is due to running processes that have heavy I/O usage, such as the Kloxo control panel, or large amount of mail processes, which also cause heavy load on the node.
If this is your first offense with this VPS, we are giving you a chance to fix this matter yourself.  If your service is presently offline, please respond to this e-mail and ask to be brought back online to work on the problem.
If this is your second offense, or if the usage is exceedingly high, BurstNET has specifically set up hardware nodes to handle higher usage VPS accounts, such as yours. We would have to move your VPS on such a node, where you may continue to operate your service at such a usage level as you have been, without the worry of affecting the hardware node overall and/or other clientele as much. This however, would require us to set up a new VPS for you on the new hardware node, and your VPS will be given new primary IP addresses as these cannot be relocated.
NOTE: Typically this is a one time move/nuisance, and once moved to a hardware node specifically set up for such high-end usage, this should not be a concern moving forward.
EXCEPTION: If you are hosted on a Premium VPS service/node, a relocation is not an option, and you may be required to upgrade to a Dedicated Server. Typically, if a Premium VPS is causing issue, the usage is not suitable for a VPS node at all, and a Dedicated Server is the more appropriate solution.
We appreciate your assistance with remedying this matter, and understanding our concerns.
Please respond back to us as soon as possible, so we can attend to the issue as quickly as possible, as the issue is very well affecting service to other clientele, as well as your own service.
Regards,
BURSTNET
CUSTOMER SERVICE DEPARTMENT
发表于 2011-7-21 22:05:52 | 只看该作者
sorry. I WILL check my vps carefully to affect others.
发表于 2011-7-21 22:07:14 | 只看该作者
干什么了?用来生成了?
发表于 2011-7-21 22:08:24 | 只看该作者
回复 2# cnweb 的帖子
seems that your English  isn't very well
发表于 2011-7-21 22:15:48 | 只看该作者
真长啊
 楼主| 发表于 2011-7-21 22:16:25 | 只看该作者
我也不知道怎么回事,一直都这么用的,半年多了,今天才发来说我负载高。平时负载也才0.0几呀
发表于 2011-7-21 23:26:41 | 只看该作者
被黑了?
好好解释
发表于 2011-7-21 23:29:53 | 只看该作者
一定要好好解释,多说些道歉的话
比如很抱歉麻烦你们了,也影响了其他客户,这都是我自己的错误,我以前不会再出现一类的。。。
发表于 2011-7-22 00:44:14 | 只看该作者
看不懂啊
发表于 2011-7-22 11:04:51 | 只看该作者
保证不再出现类似情况
GMT+8, 2026-4-21 05:37 , Processed in 0.064650 second(s), 10 queries , Gzip On, MemCache On.
