查看: 6408|回复: 8
CPUER帮我 转一下 吧··
发表于 2008-12-25 19:35:47 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我需要联系老外解决问题可是英文不行
问题1:空间子目录下设置.htaccess 无效
问题2:无法新增域名 新增加的 4dc.cn 域名提示 domain name is used please select anew domain name
麻烦会的帮我转成英文 谢谢了··
发表于 2008-12-25 19:42:21 | 只看该作者
two problems:
one is that .htaccess in sub directory is no effects.
the oher is that I can not add the domain"4dc.cn" to my webhosting,it displays that"domain name is used please select anew domain name",what is wrong?
一般来说第二个提示的话是说明4dc.cn 域名已经被添加到空间上了。
 楼主| 发表于 2008-12-25 19:43:49 | 只看该作者
原帖由 cpuer 于 2008-12-25 19:42 发表
two problems:
the oher is that I can not add the domain"4dc.cn" to my webhosting,it displays that"domain name is used please select anew domain na ...
补充呀
这个是我之前添加的主域名 4dc.cn
发表于 2008-12-25 19:44:06 | 只看该作者
如果是更改了主域名要再添加到其他子目录上的话要等24小时后再添加。
 楼主| 发表于 2008-12-25 19:47:39 | 只看该作者
原帖由 cpuer 于 2008-12-25 19:44 发表
谢了·真是··感谢
 楼主| 发表于 2008-12-25 20:07:08 | 只看该作者
Email Support
Your question has been sent to our customer support staff! You should receive a response within 2 hours.  Click here to return to the support page.
等他的答复了 呵呵····
发表于 2008-12-25 22:03:20 | 只看该作者
回复 6# 的帖子
 楼主| 发表于 2008-12-25 23:50:26 | 只看该作者
原帖由 cpuer 于 2008-12-25 22:03 发表
Thank you for contacting Hosting Support,
Unfortunately we are not able to assist with third party custom scripting. I have provided some links below to assist with setting up a .htacess file. Htaccess files will function properly in sub-directories if scripted properly. If you feel that the issue is directly related to the server we would need to know more informtion in regard to the issue that you are having.
htaccess to manage my PHP file extensions
mod_rewrite
Please contact us if you have any further issues.
Regards,
Richard C.
Hosting Support
老外的回复····晕菜·
发表于 2008-12-25 23:55:25 | 只看该作者
回复 8# 的帖子
godaddy的客服有时候回复确实很机械的,
GMT+8, 2026-4-20 03:10 , Processed in 0.065106 second(s), 9 queries , Gzip On, MemCache On.
