查看: 6148|回复: 12
[翻译] VPS被投诉 求翻译
发表于 2011-7-13 16:24:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
abuse-ticket@quadranet.com Posted on: 06 Jul 2011 10:12 PM
There has been a report of abuse on your server.
Per our policies, we require that all our clients respond to abuse notices as they come in. Failure to do so within a timely manner (within 24 hours) will result in a suspension of services until the server administrator has time to resolve the issue.
The initial complaint is attached to this ticket. If you don't see it under my signature, please log in to your billing interface and view the ticket there.
We will await your response indicating that you have complied with the order, dispute it, or require a reasonable extension of time to resolve the issue.
Awaiting your timely response,
Vitaliy Yablonskiy
Support Engineer
The following is a list of IP addresses on your network which we have
good reason to believe may be compromised systems engaging in
malicious activity.  Please investigate and take appropriate action to
stop any malicious activity you verify.
The following is a list of types of activity that may appear in this
report:
    BEAGLE      BEAGLE3    BLASTER    BOTNETS    BOTS        BRUTEFORCE
    DAMEWARE    DEFACEMENT  DIPNET      DNSBOTS    MALWAREURL  MYDOOM
    NACHI      PHATBOT    PHISHING    ROUTERS    SCAN445    SCANNERS
    SINIT      SLAMMER    SPAM        SPYBOT      TOXBOT
Open proxies and open mail relays may also appear in this report.
Open proxies are designated by a two-character identifier (s4, s5, wg,
hc, ho, hu, or fu) followed by a colon and a TCP port number.  Open
mail relays are designated by the word "relay" followed by a colon
and
a TCP port number.
A detailed description of each of these may be found at
   https://security.gblx.net/reports.html
NOTE: IPs identified as hosting botnet controllers, phishing websites,
or malware distribution sites (marked with BOTNETS, PHISHING, or
MALWAREURL respectively) may be null routed by Global Crossing
following a separately emailed notice.  We will make every effort
to avoid taking action which will impact legitimate services on
your network, and we will now send notices of botnet controllers
within one hour of their detection.
This report is sent every day.  If you would prefer a weekly report,
sent on Mondays, please contact us by replying to this email to
request it.  We would prefer, however, that you receive and act upon
these reports daily.
Unless otherwise indicated, time stamps are in UTC (GMT).
29761 | 111.111.111.A| 2011-07-08 10:58:56 3306/tcp SCANNERS |
OC3-NETWORKS-AS-NUMBER - OC3 Networks & Web Solutions, LLC
29761 | 111.111.111.A| 2011-07-10 22:52:03 3389/tcp SCANNERS |
29761 | 111.111.111.A| 2011-07-10 23:45:00 3389/tcp SCANNERS |
29761 | 111.111.111.A| 2011-07-10 18:57:44 5060/udp SCANNERS |
29761 | 111.111.111.A| 2011-07-10 19:00:56 5060/udp SCANNERS |
29761 | 111.111.111.B| 2011-07-10 05:47:57 445/tcp SCANNERS |
29761 | 111.111.111.C| 2011-07-10 03:03:08 445/tcp SCANNERS |
没有附件
其中IP方面,只有一个IP  111.111.111.B 是我的IP ,是什么原因被投诉的?是做攻击还是做什么被投诉了
[ 本帖最后由 西西 于 2011-7-13 17:01 编辑 ]
发表于 2011-7-13 16:24:57 | 只看该作者
楼下的 翻译
发表于 2011-7-13 16:26:13 | 只看该作者
  一个一个 我懂 连起来就不懂了
发表于 2011-7-13 16:27:08 | 只看该作者
发表于 2011-7-13 16:27:55 | 只看该作者
发表于 2011-7-13 16:29:41 | 只看该作者
PR机房会给客户24小时时间处理投诉,你IP上某个站被投诉了,这封邮件最后会有URL和IP楼主没列出来,处理完请回复此邮件说你已删除被投诉的内容即可。
PR方面需要帮忙请Q我。
[ 本帖最后由 樱木花盗 于 2011-7-13 16:31 编辑 ]
发表于 2011-7-13 16:31:48 | 只看该作者
原帖由 chipang 于 2011-7-13 16:27 发表
這有附件的。請發附件
你被投訴了。24小時內不回他停你
发表于 2011-7-13 16:32:14 | 只看该作者
一个一个 我懂 连起来就不懂了
发表于 2011-7-13 16:34:55 | 只看该作者
说你有恶意行为,report下面是可能的行为,还有代理和邮件转发。
 楼主| 发表于 2011-7-13 16:49:27 | 只看该作者
其中IP方面,只有一个IP是我的IP ,是什么原因被投诉的?是做攻击还是做什么被投诉了
GMT+8, 2026-4-22 17:38 , Processed in 0.065738 second(s), 10 queries , Gzip On, MemCache On.
