查看: 2893|回复: 13
[不限流量] 关于不知名py机真香评测
发表于 2020-3-22 01:43:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. LemonBench Linux System Benchmark Utility Version 20200318 Intl BetaVersion
  2. OS Release:                CentOS Linux 7.4.1708 (x86_64)
  3. CPU Model:                Intel Xeon E3-12xx v2 (Ivy Bridge, IBRS)
  4. CPU Cache Size:        4096 KB
  5. CPU Number:                1 vCPU
  6. Virt Type:                KVM
  7. Memory Usage:                141.48 MB / 992.45 MB
  8. Swap Usage:                0 KB / 2.00 GB
  9. Disk Usage:                1.07 GB / 17.81 GB
  10. Boot Device:                /dev/mapper/centos-root
  11. Load (1/5/15min):        1.42 0.57 0.24
  12. -> Network Information
  13. IPV4 - IP Address:        [US] 45.220.83.*
  14. IPV4 - ASN Info:        AS22769 (DDOSING-BGP-NETWORK)
  15. IPV4 - Region:                United States Indiana Terre Haute
  16. -> Media Unlock Test
  17. HBO Now:                                No
  18. Bahamut Anime:                                No
  19. Abema.TV:                                No
  20. Princess Connect Re:Dive (Beta):        Yes
  21. BBC:                                        No
  22. Bilibili China Mainland Only:                No
  23. Bilibili Hongkong/Macau/Taiwan:        No
  24. Bilibili Taiwan Only:                        No
  25. -> CPU Performance Test (Fast Mode, 1-Pass [url=home.php?mod=space&uid=175]@[/url] 5sec)
  26. 1 Thread Test:                        330 Scores
  27. -> Memory Performance Test (Fast Mode, 1-Pass @ 5sec)
  28. 1 Thread - Read Test :                5912.24 MB/s
  29. 1 Thread - Write Test:                3655.56 MB/s
  30. -> Disk Speed Test (4K Block/1M Block, Direct Mode)
  31. Test Name                Write Speed                                Read Speed
  32. 100MB-4K Block                 (0 IOPS, 0.00 s)                 (0 IOPS, 0.00 s)
  33. 1GB-1M Block                 (0 IOPS, 0.00 s)                 (0 IOPS, 0.00 s)
  34. -> Speedtest.net Network Speed Test
  35. Node Name                        Upload Speed        Download Speed        Ping Latency
  36. Speedtest Default                1.20 MB/s        1.21 MB/s        32.25 ms
  37. China, Jilin CU                1.30 MB/s        1.25 MB/s        175.51 ms
  38. China, Nanning CM                Fail: Unknown Error
  39. China, Nanjing CT                1.27 MB/s        1.18 MB/s        175.16 ms
  40. -> Traceroute Test (IPV4)
  41. Traceroute to China, Beijing CU (TCP Mode, Max 50 Hop)
  42. ============================================================
  43. traceroute to 123.125.99.1 (123.125.99.1), 50 hops max, 60 byte packets
  44. 1  *
  45. 2  *
  46. 3  212.95.128.5  33.95 ms  AS22769  United States California Los Angeles nlidc.com
  47. 4  218.30.49.165  28.76 ms  AS4134  United States ctamericas.com
  48. 5  59.43.181.145  138.21 ms  *  China ChinaTelecom
  49. 6  59.43.187.81  159.21 ms  *  China Shanghai ChinaTelecom
  50. 7  59.43.138.69  130.87 ms  *  China Shanghai ChinaTelecom
  51. 8  59.43.80.102  146.53 ms  *  China Shanghai ChinaTelecom
  52. 9  202.97.50.253  131.25 ms  AS4134  China Shanghai ChinaTelecom
  53. 10  *
  54. 11  219.158.5.73  167.05 ms  AS4837  China Shanghai ChinaUnicom
  55. 12  219.158.6.165  150.92 ms  AS4837  China Beijing ChinaUnicom
  56. 13  *
  57. 14  219.232.11.198  159.69 ms  AS4808  China Beijing ChinaUnicom
  58. 15  124.65.194.42  171.56 ms  AS4808  China Beijing ChinaUnicom
  59. 16  61.135.113.154  152.65 ms  AS4808  China Beijing ChinaUnicom
  60. 17  *
  61. 18  *
  62. 19  123.125.99.1  171.25 ms  AS4808  China Beijing ChinaUnicom
  63. Generated by LemonBench on 2020-03-21T16:57:29Z Version 20200318 Intl BetaVersion
发表于 2020-3-22 01:44:03 | 只看该作者
深夜再围观
发表于 2020-3-22 01:46:32 | 只看该作者
下次再带大家上白piao车
买GCP和学生及找我鸭 (给自己打一下广告)
 楼主| 发表于 2020-3-22 01:48:04 | 只看该作者
雨巷 发表于 2020-3-22 01:46
下次再带大家上白piao车
买GCP和学生及找我鸭 (给自己打一下广告) ...
学生是啥配置啥价钱?
发表于 2020-3-22 01:49:00 | 只看该作者
leonead 发表于 2020-3-22 01:48
学生是啥配置啥价钱?
老哥看一下我之前的帖子。。。我手机上的电脑版,打字太费劲
发表于 2020-3-22 01:50:07 | 只看该作者
 楼主| 发表于 2020-3-22 01:51:51 | 只看该作者
h20 发表于 2020-3-22 01:50
我发现面板写20G空间,实际是40G,是这样的吗
为啥你的硬盘大一些
发表于 2020-3-22 01:57:56 | 只看该作者
来晚了,看来又错过一台传家宝啊
发表于 2020-3-22 01:59:03 | 只看该作者
你的为啥这么大!!
发表于 2020-3-22 01:59:52 | 只看该作者
GMT+8, 2026-4-28 04:47 , Processed in 0.067870 second(s), 10 queries , Gzip On, MemCache On.
