查看: 4364|回复: 12
[Windows VPS] 求助搬瓦工服务总是被暂停
发表于 2020-2-15 11:50:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
vps:搬瓦工 cn gia 65(dc9),
环境:Centos 7 x86_64 bbr centos7+233v2ray一键脚本+宝塔7免费版+typecho+bbr-plus一键脚本
用来扶墙和几个简单网页发布,最近一两个月总是会服务暂停,登陆kiwivm.64clouds.com后台看到Network abuse: Mass Mailing的提示(附在最后)。
之后尝试了:
1. 更换SSH端口和密码,开通后台的二次验证登录;更换宝塔面板端口和密码,开通二次验证登录;更换v2ray端口和设置;重启VPS,几天后仍被暂停
2. 切换DC3机房,切换回DC9,ip没变,几天后被暂停
3. 备份数据后,重新安装系统为Centos 7 x86_64 bbr,两天内没有被暂停,然后不使用v2ray 的233脚本,用官网脚本安装v2ray,两天后服务被暂停
yum -y install wget
wget https://install.direct/go.sh
sudo bash go.sh
sudo systemctl start v2ray
发了bwg工单,客服回复他们不管客户软件问题。
求助下大佬们,怎么解决这个问题?是centos 系统或者v2ray有bug?
搬瓦工暂停服务的原因提示:
Reason:        Network abuse: Mass Mailing
More details:        We have detected a large number of outgoing SMTP connections originating from this server. This usually means that the server is sending out spam.
Additional information(bwg ip 改为了123.123.123.123):
1581710224.343711        Cnnb5a4Kp2xDjGXxM1        123.123.123.123        37156        74.125.20.26        25        1        -        -        -        -        -        -        -        -        -        -        -        -        -        -        220 2.0.0 Ready to start TLS        74.125.20.26,123.123.123.123        -        T        (empty)        F
1581710698.536005        Cy4mcsl5wAT7AmoDd        123.123.123.123        37184        74.125.20.26        25        1        [100.74.12.42]        -        -        -        -        -        -        -        -        -        -        -        -        -        220 2.0.0 Ready to start TLS        74.125.20.26,123.123.123.123        -        T        (empty)        F
1581710742.982538        C2nPST1V6PoG1HkMGb        123.123.123.123        37186        74.125.20.26        25        1        dfymirandari.com        -        -        -        -        -        -        -        -        -        -        -        -        -        220 2.0.0 Ready to start TLS        74.125.20.26,123.123.123.123        -        T        (empty)        F
1581710916.786263        C4ImSq1ydW5OZDnbS4        123.123.123.123        37194        74.125.20.26        25        1        y2.localhost        -        -        -        -        -        -        -        -        -        -        -        -        -        220 2.0.0 Ready to start TLS        74.125.20.26,123.123.123.123        -        T        (empty)        F
1581710940.364672        CN6AwP1AG6UI4fkkEc        123.123.123.123        37198        74.125.20.26        25        1        oo3.local        -        -        -        -        -        -        -        -        -        -        -        -        -        220 2.0.0 Ready to start TLS        74.125.20.26,123.123.123.123        -        T        (empty)        F
1581710940.923473        CGfUsn3eDcY5BqtZua        123.123.123.123        37200        74.125.20.26        25        1        redjaidaop.com        -        -        -        -        -        -        -        -        -        -        -        -        -        220 2.0.0 Ready to start TLS        74.125.20.26,123.123.123.123        -        T        (empty)        F
1581710958.257594        CfVLXJALqs8UJ2b2i        123.123.123.123        59362        64.233.177.27        25        1        encathleenpq.com        -        -        -        -        -        -        -        -        -        -        -        -        -        220 2.0.0 Ready to start TLS        64.233.177.27,123.123.123.123        -        T        (empty)        F
1581711376.727651        CpBUZGvYnCrroVLj5        123.123.123.123        37228        74.125.20.26        25        1        y01.local        -        -        -        -        -        -        -        -        -        -        -        -        -        220 2.0.0 Ready to start TLS        74.125.20.26,123.123.123.123        -        T        (empty)        F
1581711536.260695        CyKpRI4bJ0QNHiSbj        123.123.123.123        59582        64.233.177.27        25        1        pesheribe.com        -        -        -        -        -        -        -        -        -        -        -        -        -        220 2.0.0 Ready to start TLS        64.233.177.27,123.123.123.123        -        T        (empty)        F
1581711552.614375        Crg86x465khTgclS4b        123.123.123.123        59506        173.194.77.26        25        1        hjptamiaczn.com        -        -        -        -        -        -        -        -        -        -        -        -        -        220 2.0.0 Ready to start TLS        173.194.77.26,123.123.123.123        -        T        (empty)        F
Abuse points:        100 – points added for this suspension
Total abuse points:        600 – total points already accumulated during current calendar year
Max abuse points:        1300 – maximum points allowed within one calendar year; after reaching this number service will be permanently suspended until end of year.
How to resolve:        This usually happens when your server is rooted/hacked. Make sure to install a clean OS immediately after resuming service, otherwise the issue will likely repeat.
You can unsuspend service as long as Total abuse points accumulated within one calendar year is less than Max abuse points allowed by your plan.
By clicking the button above you agree to take all measures to prevent future TOS violations.
You also acknowledge that if/when Total abuse points exceeds Maximum abuse points within this calendar year, then service will be disabled until January 1, 2021.
发表于 2020-2-15 11:52:02 | 只看该作者
看翻译,不是说乱发邮件吗?是不是中马了
 楼主| 发表于 2020-2-15 11:55:58 | 只看该作者
雪丫鬟 发表于 2020-2-15 11:52
看翻译,不是说乱发邮件吗?是不是中马了
重新装了系统,也是这个提示
发表于 2020-2-15 11:57:36 | 只看该作者
ukam 发表于 2020-2-15 11:55
重新装了系统,也是这个提示
那就奇了怪了。太诡异了
 楼主| 发表于 2020-2-15 12:00:30 | 只看该作者
雪丫鬟 发表于 2020-2-15 11:57
那就奇了怪了。太诡异了
是啊,备份重装后只装了v2ray官方脚本,一天后就有这个乱发邮件暂停服务的提示
发表于 2020-2-15 12:01:32 来自手机 | 只看该作者
发表于 2020-2-15 12:10:13 | 只看该作者
我教你一个管用的笨办法
全新安装系统,然后用官方安装你常用的玩意儿,测试没问题以后snapshot备份,得到备份A
过几天被停了以后再生成snapshot备份b
把a和b备份都弄到电脑本地,然后开对比软件,挨着对比,看看到底他吗的哪里有改动
 楼主| 发表于 2020-2-15 12:17:04 | 只看该作者
qwerttaa 发表于 2020-2-15 12:10
我教你一个管用的笨办法
全新安装系统,然后用官方安装你常用的玩意儿,测试没问题以后snapshot备份,得到 ...
多谢,也只能这样试下了;google了下,有几个相同的案例,有的说是发工单,客服说是系统bug,他们给解决了,有的说可能自己客户端电脑中毒,调用v2ray客户端的v2ray_privoxy.exe,导致的服务端的vps被暂停
发表于 2020-2-15 12:18:34 | 只看该作者
估计你脚本有问题吧
发表于 2020-2-15 12:21:53 | 只看该作者
GMT+8, 2026-4-23 19:50 , Processed in 0.066325 second(s), 10 queries , Gzip On, MemCache On.
