查看: 4201|回复: 10
Softlayer达拉斯5号机房怎么啦?
发表于 2011-6-28 13:35:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
PING不通,跟踪到机房节点就断了
  1.   2    35 ms    35 ms    36 ms  116.25.20.1
  2.   3    36 ms    37 ms    38 ms  119.145.50.5
  3.   4    36 ms    36 ms    37 ms  121.15.179.74
  4.   5    39 ms    38 ms    39 ms  119.145.47.18
  5.   6    39 ms    39 ms    39 ms  202.97.35.194
  6.   7    53 ms    57 ms    55 ms  202.97.60.50
  7.   8   207 ms   207 ms   209 ms  202.97.51.214
  8.   9     *        *        *     Request timed out.
  9. 10     *      362 ms     *     las-bb1-link.telia.net [80.91.247.170]
  10. 11     *      402 ms     *     dls-bb1-link.telia.net [213.248.80.14]
  11. 12     *        *        *     Request timed out.
  12. 13   391 ms   382 ms   384 ms  ae7.bbr01.eq01.dal03.networklayer.com [173.192.18.208]
  13. 14     *        *        *     Request timed out.
  14. 15     *        *        *     Request timed out.
  15. 16     *        *        *     Request timed out.
  16. 17     *        *        *     Request timed out.
  17. 18     *        *        *     Request timed out.
  18. 19     *        *        *     Request timed out.
  19. 20     *        *        *     Request timed out.
参与人数 2威望 +2 收起 理由
liheyuan + 1 SL路由挂了,已恢复。
kpt2008 + 1 走telia的都悲剧
 楼主| 发表于 2011-6-28 13:36:17 | 只看该作者
有知情者没?
发表于 2011-6-28 13:36:40 | 只看该作者
剛剛好像是的..不過現在正常了.
這幾個月..softlayer 出了很多問題
发表于 2011-6-28 13:37:42 | 只看该作者
木有sl的
发表于 2011-6-28 13:38:52 | 只看该作者
没 达拉斯的
 楼主| 发表于 2011-6-28 13:41:38 | 只看该作者
  1. SoftLayer Engineers are aware of an ongoing latency/loss issue with FCR01.DAL05, FCR02.DAL05, FCR01.SJC01, FCR01.HOU02. Initial investigation shows it be related to a large number of BGP updates causing 100% CPU. Engineers are working towards a resolution and should have more information as soon as possible.
晕。。。,
不会又是个临时工吧?擦
发表于 2011-6-28 13:44:01 | 只看该作者
还可以
发表于 2011-6-28 13:56:14 | 只看该作者
发表于 2011-6-28 13:59:09 | 只看该作者
  零时工 好伟大啊
发表于 2011-6-28 17:25:06 | 只看该作者
抽了啊
GMT+8, 2026-4-24 02:03 , Processed in 0.068750 second(s), 11 queries , Gzip On, MemCache On.
