查看: 1711|回复: 9
两个圣何塞小鸡差别好大啊
发表于 2019-12-12 11:11:39 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Superbench.sh -- https://www.oldking.net/350.html
Mode  : Standard    Version : 1.1.6
Usage : wget -qO- git.io/superbench.sh | bash
CPU Model            : QEMU Virtual CPU version (cpu64-rhel6)
CPU Cores            : 1 Cores 2499.998 MHz x86_64
CPU Cache            : 4096 KB
OS                   : CentOS 7.7.1908 (64 Bit) KVM
Kernel               : 4.11.8-1.el7.elrepo.x86_64
Total Space          : 2.9 GB / 15.0 GB
Total RAM            : 284 MB / 739 MB (87 MB Buff)
Total SWAP           : 3 MB / 255 MB
Uptime               : 5 days 17 hour 48 min
Load Average         : 0.02, 0.01, 0.03
TCP CC               : bbr
ASN & ISP            : AS36352, ColoCrossing
Organization         : Virtual Machine Solutions LLC
Region               : California
I/O Speed( 1.0GB )   : 674 MB/s
I/O Speed( 1.0GB )   : 673 MB/s
I/O Speed( 1.0GB )   : 633 MB/s
Average I/O Speed    : 660.0 MB/s
Speedtest.net    264.47 Mbit/s     236.13 Mbit/s       (*) 64.681 ms
Fast.com         0.00 Mbit/s       185.5 Mbit/s        -
Beijing 5G   CT  29.44 Mbit/s      118.10 Mbit/s       -
Nanjing 5G   CT  132.05 Mbit/s     98.97 Mbit/s        -
Hefei 5G     CT  62.76 Mbit/s      93.32 Mbit/s        -
Guangzhou 5G CT  2.87 Mbit/s       26.07 Mbit/s        -
TianJin 5G   CU  114.90 Mbit/s     52.28 Mbit/s        -
Shanghai 5G  CU  113.93 Mbit/s     31.21 Mbit/s        -
Guangzhou 5G CU  66.11 Mbit/s      46.27 Mbit/s        -
Tianjin 5G   CM  10.93 Mbit/s      48.57 Mbit/s        -
Wuxi 5G      CM  10.05 Mbit/s      27.87 Mbit/s        -
Nanjing 5G   CM  13.71 Mbit/s      56.95 Mbit/s        -
Hefei 5G     CM  6.57 Mbit/s       40.89 Mbit/s        -
Changsha 5G  CM  19.65 Mbit/s      268.47 Mbit/s       -
Finished in  : 5 min 33 sec
Timestamp    : 2019-12-12 11:08:52 GMT+8
Results      : /root/superbench.log
CPU Cache            : 4096 KB
Total Space          : 3.5 GB / 25.0 GB
Total RAM            : 499 MB / 991 MB (415 MB Buff)
Total SWAP           : 6 MB / 255 MB
Uptime               : 0 days 3 hour 49 min
Load Average         : 0.24, 0.08, 0.09
TCP CC               : bbr
Organization         : Level 3, LLC
Region               : California
I/O Speed( 1.0GB )   : 63.9 MB/s
I/O Speed( 1.0GB )   : 70.1 MB/s
I/O Speed( 1.0GB )   : 83.3 MB/s
Average I/O Speed    : 72.4 MB/s
Speedtest.net    411.50 Mbit/s     304.30 Mbit/s       45.284 ms
Fast.com         0.00 Mbit/s       0.0 Mbit/s          -
Beijing 5G   CT  84.91 Mbit/s      17.69 Mbit/s        -
Nanjing 5G   CT  82.41 Mbit/s      127.58 Mbit/s       -
Hefei 5G     CT  9.94 Mbit/s       7.54 Mbit/s         -
Guangzhou 5G CT  2.95 Mbit/s       5.46 Mbit/s         -
TianJin 5G   CU  118.25 Mbit/s     4.45 Mbit/s         -
Shanghai 5G  CU  129.61 Mbit/s     106.53 Mbit/s       -
Guangzhou 5G CU  91.97 Mbit/s      94.02 Mbit/s        -
Tianjin 5G   CM  10.61 Mbit/s      17.04 Mbit/s        -
Wuxi 5G      CM  10.07 Mbit/s      23.17 Mbit/s        -
Nanjing 5G   CM  15.80 Mbit/s      53.45 Mbit/s        -
Hefei 5G     CM  13.54 Mbit/s      78.74 Mbit/s        -
Changsha 5G  CM  18.98 Mbit/s      338.93 Mbit/s       -
Finished in  : 6 min 18 sec
Timestamp    : 2019-12-12 11:09:30 GMT+8
发表于 2019-12-12 11:12:23 来自手机 | 只看该作者
第一个12号节点,后面6号节点?
发表于 2019-12-12 11:33:40 来自手机 | 只看该作者
12节点不知道,不过6号节点就是第二个那尿性
发表于 2019-12-12 11:35:26 | 只看该作者
我圣何塞2IP小鸡 两个ip差别都很大。走不同线路。
不过也好,不同网络环境,总有一个ip不炸。
发表于 2019-12-12 11:39:21 | 只看该作者
貌似挺正常的,第一台鸡等小伙伴凑齐了就跟第二台一样了。。
发表于 2019-12-12 11:40:28 来自手机 | 只看该作者
不过也好,不同网络环境,总有一个ip不炸。 ...
圣何塞分配的IP很迷,有水牛城,有洛杉矶
发表于 2019-12-12 11:41:46 来自手机 | 只看该作者
发表于 2019-12-12 11:59:49 | 只看该作者
我两个都是圣何塞。只是有个会从洛杉矶跳一下
 楼主| 发表于 2019-12-12 12:02:36 | 只看该作者
768M内存是SJKVM12
1G内存是SJKVM11
 楼主| 发表于 2019-12-12 13:13:08 | 只看该作者
确实很迷,我的也是有个会从洛杉矶跳
GMT+8, 2026-4-25 00:58 , Processed in 0.064102 second(s), 10 queries , Gzip On, MemCache On.
