查看: 5778|回复: 10
[特价VPS] AX41-NVMe 开箱报告
发表于 2019-12-10 20:37:06 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
官网配置:
官方上架说明:
AX41-NVMe for Falkenstein (FSN1): Due to very high demand for these server models, its current setup time is approximately up to 10 workdays.*
证明这东西需求量真大啊,最多10工作日才能上架,这么说我7个工作日上架算赚到了
Linux下测试:
-> CPU Performance Test (Standard Mode, 3-Pass @ 30sec)
1 Thread Test:                        2070 Scores
12 Threads Test:                12627 Scores
-> Memory Performance Test (Standard Mode, 3-Pass @ 30sec)
1  Thread - Read Test:                55800.82 MB/s
1  Thread - Write Test:                24392.27 MB/s
12 Threads - Read Test:                335003.68 MB/s
12 Threads - Write Test:        25720.36 MB/s
-> Disk Speed Test (4K Block/1M Block, Direct-Write)
Test Name                Write Speed                                Read Speed
10MB-4K Block                68.7 MB/s (0.06 IOPS, 0.15 s)                130 MB/s (31736 IOPS, 0.08 s)
10MB-1M Block                204 MB/s (194 IOPS, 0.05 s)                1.7 GB/s (1586 IOPS, 0.01 s)
100MB-4K Block                174 MB/s (0.02 IOPS, 0.60 s)                188 MB/s (45996 IOPS, 0.56 s)
100MB-1M Block                1.1 GB/s (1017 IOPS, 0.10 s)                2.4 GB/s (2273 IOPS, 0.04 s)
1GB-4K Block                161 MB/s (0.03 IOPS, 6.52 s)                187 MB/s (45660 IOPS, 5.61 s)
1GB-1M Block                1.8 GB/s (1707 IOPS, 0.59 s)                2.3 GB/s (2199 IOPS, 0.45 s)
-> Speedtest.net Network Speed Test
Node Name                        Upload Speed        Download Speed        Ping Latency
Speedtest Default                110.43 MB/s        65.06 MB/s        2.71 ms
China, Jilin CU                0.42 MB/s        9.67 MB/s        254.08 ms
China, Shandong CU                1.95 MB/s        95.51 MB/s        256.34 ms
China, Nanjing CU                15.25 MB/s        55.76 MB/s        234.70 ms
China, Shanghai CU                3.45 MB/s        56.22 MB/s        254.85 ms
China, Guangxi CU                0.06 MB/s        79.56 MB/s        360.38 ms
China, Lanzhou CU                1.06 MB/s        84.82 MB/s        266.37 ms
China, Beijing CT                0.09 MB/s        50.74 MB/s        209.70 ms
China, Hangzhou CT                0.05 MB/s        43.81 MB/s        246.35 ms
China, Nanjing CT                0.01 MB/s        49.96 MB/s        210.95 ms
China, Guangzhou CT                Fail: Unknown Error
China, Wuhan CT                Fail: Unknown Error
China, Shenyang CM                6.14 MB/s        49.47 MB/s        158.17 ms
China, Hangzhou CM                0.20 MB/s        38.97 MB/s        235.01 ms
China, Shanghai CM                0.12 MB/s        0.06 MB/s        232.90 ms
China, Nanning CM                Fail: Unknown Error
China, Lanzhou CM                Fail: Unknown Error
欧洲区回国都网络比较差
随便DD了一个Windows(Hetzner的IPMI要申请,只能用三个小时,申请下来以后发现真难用,光盘挂载只能通过Windows文件夹共享的方式,并且最大只能共享4.7G的iso文件)
DD的时候注意of=/dev/nvme0n1
主板是微星B450M-S01,网卡是应该是Realtek 8111H,随便DD一个Windows10可以自动匹配网卡
NVMe是东芝的新盘,kxg60znv512g
Raid1模式下跑个分
无Raid模式下跑个分(怎么还不如Raid1
DD的Win没法组Raid0模式,跑分略
最后鲁大师跑个分
结论,AMD yes,hetzner真香,39欧超值
发表于 2019-12-10 20:39:50 | 只看该作者
香是香,就是安装费有点贵 。
发表于 2019-12-10 20:40:25 来自手机 | 只看该作者
这是一只母鸡。。。
发表于 2019-12-10 20:41:14 | 只看该作者
发表于 2019-12-10 20:41:28 | 只看该作者
好狠的性能
发表于 2019-12-11 04:34:15 | 只看该作者
AX51款默认有ECC,AX41款可以加5o换ECC,感觉真的很强,就是我没钱
发表于 2019-12-11 04:40:03 | 只看该作者
居然是独服
发表于 2019-12-11 05:09:28 来自手机 | 只看该作者
这台我一直想买,可惜不想出安装费
发表于 2019-12-11 07:27:20 | 只看该作者
GMT+8, 2026-4-23 18:05 , Processed in 0.066097 second(s), 10 queries , Gzip On, MemCache On.
