查看: 1613|回复: 5
[疑问] PR28号鸡UnixBench跑分
发表于 2019-12-10 14:13:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
还是瓦工强些虽然贵
瓦工双11款切到mc机房可以跑1900分
这款双核还真没virmach单核跑的高
翻车了 翻车了
1 x Dhrystone 2 using register variables  1 2 3 4 5 6 7 8 9 10
1 x Double-Precision Whetstone  1 2 3 4 5 6 7 8 9 10
1 x Execl Throughput  1 2 3
1 x File Copy 1024 bufsize 2000 maxblocks  1 2 3
1 x File Copy 256 bufsize 500 maxblocks  1 2 3
1 x File Copy 4096 bufsize 8000 maxblocks  1 2 3
1 x Pipe Throughput  1 2 3 4 5 6 7 8 9 10
1 x Pipe-based Context Switching  1 2 3 4 5 6 7 8 9 10
1 x Process Creation  1 2 3
1 x System Call Overhead  1 2 3 4 5 6 7 8 9 10
1 x Shell Scripts (1 concurrent)  1 2 3
1 x Shell Scripts (8 concurrent)  1 2 3
2 x Dhrystone 2 using register variables  1 2 3 4 5 6 7 8 9 10
2 x Double-Precision Whetstone  1 2 3 4 5 6 7 8 9 10
2 x Execl Throughput  1 2 3
2 x File Copy 1024 bufsize 2000 maxblocks  1 2 3
2 x File Copy 256 bufsize 500 maxblocks  1 2 3
2 x File Copy 4096 bufsize 8000 maxblocks  1 2 3
2 x Pipe Throughput  1 2 3 4 5 6 7 8 9 10
2 x Pipe-based Context Switching  1 2 3 4 5 6 7 8 9 10
2 x Process Creation  1 2 3
2 x System Call Overhead  1 2 3 4 5 6 7 8 9 10
2 x Shell Scripts (1 concurrent)  1 2 3
2 x Shell Scripts (8 concurrent)  1 2 3
   BYTE UNIX Benchmarks (Version 5.1.3)
   System: server: GNU/Linux
   OS: GNU/Linux -- 4.14.129-bbrplus -- #1 SMP Tue Jun 25 12:23:41 UTC 2019
   Machine: x86_64 (x86_64)
   Language: en_US.utf8 (charmap="UTF-8", collate="UTF-8")
   CPU 0: QEMU Virtual CPU version (cpu64-rhel6) (5200.0 bogomips)
          x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET
   CPU 1: QEMU Virtual CPU version (cpu64-rhel6) (5200.0 bogomips)
   12:47:24 up 9 min,  1 user,  load average: 0.45, 0.32, 0.19; runlevel 2019-12-10
Benchmark Run: Tue Dec 10 2019 12:47:24 - 13:15:43
2 CPUs in system; running 1 parallel copy of tests
Dhrystone 2 using register variables       25769002.7 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     3372.9 MWIPS (9.5 s, 7 samples)
Execl Throughput                               1740.1 lps   (29.8 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        120562.5 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks           29600.8 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks        381077.5 KBps  (30.0 s, 2 samples)
Pipe Throughput                              161048.7 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                   9600.3 lps   (10.0 s, 7 samples)
Process Creation                               2806.3 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                   2756.7 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                    608.6 lpm   (60.0 s, 2 samples)
System Call Overhead                         146944.3 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0   25769002.7   2208.1
Double-Precision Whetstone                       55.0       3372.9    613.2
Execl Throughput                                 43.0       1740.1    404.7
File Copy 1024 bufsize 2000 maxblocks          3960.0     120562.5    304.5
File Copy 256 bufsize 500 maxblocks            1655.0      29600.8    178.9
File Copy 4096 bufsize 8000 maxblocks          5800.0     381077.5    657.0
Pipe Throughput                               12440.0     161048.7    129.5
Pipe-based Context Switching                   4000.0       9600.3     24.0
Process Creation                                126.0       2806.3    222.7
Shell Scripts (1 concurrent)                     42.4       2756.7    650.2
Shell Scripts (8 concurrent)                      6.0        608.6   1014.3
System Call Overhead                          15000.0     146944.3     98.0
System Benchmarks Index Score                                         312.8
Benchmark Run: Tue Dec 10 2019 13:15:43 - 13:44:01
2 CPUs in system; running 2 parallel copies of tests
Dhrystone 2 using register variables       51424597.5 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     6799.2 MWIPS (9.8 s, 7 samples)
Execl Throughput                               3815.7 lps   (30.0 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        228242.9 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks           53355.0 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks        725327.6 KBps  (30.0 s, 2 samples)
Pipe Throughput                              322724.2 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                  19042.6 lps   (10.0 s, 7 samples)
Process Creation                               5195.8 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                   4268.5 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                    640.9 lpm   (60.0 s, 2 samples)
System Call Overhead                         282715.1 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0   51424597.5   4406.6
Double-Precision Whetstone                       55.0       6799.2   1236.2
Execl Throughput                                 43.0       3815.7    887.4
File Copy 1024 bufsize 2000 maxblocks          3960.0     228242.9    576.4
File Copy 256 bufsize 500 maxblocks            1655.0      53355.0    322.4
File Copy 4096 bufsize 8000 maxblocks          5800.0     725327.6   1250.6
Pipe Throughput                               12440.0     322724.2    259.4
Pipe-based Context Switching                   4000.0      19042.6     47.6
Process Creation                                126.0       5195.8    412.4
Shell Scripts (1 concurrent)                     42.4       4268.5   1006.7
Shell Scripts (8 concurrent)                      6.0        640.9   1068.1
System Call Overhead                          15000.0     282715.1    188.5
System Benchmarks Index Score                                         569.3
I/O Speed( 1.0GB )   : 77.3 MB/s
I/O Speed( 1.0GB )   : 120 MB/s
I/O Speed( 1.0GB )   : 98.5 MB/s
Average I/O Speed    : 98.6 MB/s
发表于 2019-12-10 14:18:29 | 只看该作者
发表于 2019-12-10 16:03:19 | 只看该作者
综合摸到570啦 不错呦 甲骨文也才630+ c2338杜甫全和也才650+
发表于 2019-12-10 16:04:37 | 只看该作者
28号母鸡?  你邻居在happy着
发表于 2019-12-10 16:12:01 | 只看该作者
哎呀,不幸和楼主做成了邻居。
发表于 2019-12-10 16:29:20 | 只看该作者
GMT+8, 2026-4-23 07:03 , Processed in 0.064421 second(s), 11 queries , Gzip On, MemCache On.
