查看: 2070|回复: 9
[Windows VPS] Centos8编译Google BBR2出错未大佬指点
发表于 2019-12-6 14:53:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  INSTALL /root/rpmbuild/BUILDROOT/kernel-5.4.0_rc6-1.x86_64/usr/include
/bin/sh: rsync: command not found
make[2]: *** [Makefile:1183: headers_install] Error 127
error: Bad exit status from /var/tmp/rpm-tmp.eWlsnD (%install)
RPM build errors:
make[1]: *** [scripts/Makefile.package:59: rpm-pkg] Error 1
make: *** [Makefile:1427: rpm-pkg] Error 2
real        108m13.659s
user        93m39.136s
sys        18m54.816s
# 安装编译相关的工具
yum groups install development -y
yum install gcc bc ncurses-devel openssl-devel elfutils-libelf-devel -y
# 获取源代码
git clone -o google-bbr -b v2alpha  https://github.com/google/bbr.git
# 进入源代码文件夹
cd bbr
# 打开编译选项菜单
make menuconfig
# 编译选项菜单 (图1)
# 按 / 键在搜索框输入 bbr2 回车 (图2)
# 根据查询结果(图3),按 数字键 2 进入 TCP_CONG_BBR2 配置页面 (图4)
# 按 空格键 启用 bbr2 内核模块 (图4)
# 按 Save 保存到 .config 文件中 (图5)
# 查看保存的配置文件中BBR配置项是否为m (CONFIG_TCP_CONG_BBR2=m)
grep -i bbr2 .config
# 禁用调试
scripts/config --disable DEBUG_INFO
# 编译内核并打包成rpm安装包
time make rpm-pkg
发表于 2019-12-6 15:05:05 | 只看该作者
哎。。。基本的排错都不会就跳级玩编译内核
发表于 2019-12-6 14:55:39 | 只看该作者
先把rsync装了
 楼主| 发表于 2019-12-6 15:17:50 | 只看该作者
自己动手丰衣足食
 楼主| 发表于 2019-12-6 15:19:49 | 只看该作者
先把rsync装了
谢谢大佬我再试试
 楼主| 发表于 2019-12-9 12:52:13 | 只看该作者
先把rsync装了
谢谢大佬,成功了
Checking for unpackaged file(s): /usr/lib/rpm/check-files /root/rpmbuild/BUILDROOT/kernel-5.4.0_rc6-1.x86_64
Wrote: /root/rpmbuild/SRPMS/kernel-5.4.0_rc6-1.src.rpm
Wrote: /root/rpmbuild/RPMS/x86_64/kernel-5.4.0_rc6-1.x86_64.rpm
Wrote: /root/rpmbuild/RPMS/x86_64/kernel-headers-5.4.0_rc6-1.x86_64.rpm
Wrote: /root/rpmbuild/RPMS/x86_64/kernel-devel-5.4.0_rc6-1.x86_64.rpm
Executing(%clean): /bin/sh -e /var/tmp/rpm-tmp.mCdXCw
+ umask 022
+ cd /root/rpmbuild/BUILD
+ cd kernel-5.4.0_rc6
+ rm -rf /root/rpmbuild/BUILDROOT/kernel-5.4.0_rc6-1.x86_64
+ exit 0
real        105m41.303s
user        92m37.938s
sys        18m59.026s
 楼主| 发表于 2019-12-9 12:54:21 | 只看该作者
你还别笑小弟成功了
+ umask 022
+ exit 0
real        105m41.303s
user        92m37.938s
sys        18m59.026s
发表于 2019-12-9 12:56:20 | 只看该作者
 楼主| 发表于 2019-12-9 13:32:34 | 只看该作者
llmwxt 发表于 2019-12-9 12:56
加油,给弄个一键脚本,给我们小白也用用
https://www.loc.qiche.eu.org/thread-616040-1-1.html
大佬早搞了弄个一键脚本
GMT+8, 2026-4-16 16:15 , Processed in 0.062685 second(s), 11 queries , Gzip On, MemCache On.
