查看: 1832|回复: 4
记录一下UltrVPS.eu的bench
发表于 2019-12-1 00:56:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
原版Debian10开启bbr
  1. ----------------------------------------------------------------------
  2. CPU model            : Intel(R) Xeon(R) CPU E5-2680 v3 [url=home.php?mod=space&uid=175]@[/url] 2.50GHz
  3. Number of cores      : 2
  4. CPU frequency        : 2499.952 MHz
  5. Total size of Disk   : 5.9 GB (0.9 GB Used)
  6. Total amount of Mem  : 3946 MB (53 MB Used)
  7. Total amount of Swap : 4092 MB (0 MB Used)
  8. System uptime        : 0 days, 0 hour 2 min
  9. Load average         : 0.20, 0.06, 0.02
  10. OS                   : Debian GNU/Linux 10
  11. Arch                 : x86_64 (64 Bit)
  12. Kernel               : 4.19.0-6-amd64
  13. ----------------------------------------------------------------------
  14. I/O speed(1st run)   : 845 MB/s
  15. I/O speed(2nd run)   : 750 MB/s
  16. I/O speed(3rd run)   : 707 MB/s
  17. Average I/O speed    : 767.3 MB/s
  18. ----------------------------------------------------------------------
  19. Node Name                       IPv4 address            Download Speed
  20. CacheFly                        205.234.175.175         89.1MB/s
  21. Linode, Tokyo2, JP              139.162.65.37           11.2MB/s
  22. Linode, Singapore, SG           139.162.23.4            15.9MB/s
  23. Linode, London, UK              176.58.107.39           147MB/s
  24. Linode, Frankfurt, DE           139.162.130.8           181MB/s
  25. Linode, Fremont, CA             50.116.14.9             18.1MB/s
  26. Softlayer, Dallas, TX           173.192.68.18           19.5MB/s
  27. Softlayer, Seattle, WA          67.228.112.250          14.4MB/s
  28. Softlayer, Frankfurt, DE        159.122.69.4            61.6MB/s
  29. Softlayer, Singapore, SG        119.81.28.170           8.90MB/s
  30. Softlayer, HongKong, CN         119.81.130.170          7.84MB/s
  31. ----------------------------------------------------------------------
补一个lemon的benchmark
https://paste.ubuntu.com/p/sNTmp397Jz/
发表于 2019-12-1 01:02:15 来自手机 | 只看该作者
unixbench,Lemonbench才有用啊。这个就等于跑了个测速
发表于 2019-12-1 01:12:42 | 只看该作者
是哪一个机房?
 楼主| 发表于 2019-12-1 01:21:24 | 只看该作者
hyllgf 发表于 2019-12-1 01:12
是哪一个机房?
德国的
 楼主| 发表于 2019-12-1 01:22:46 | 只看该作者
补充了
GMT+8, 2026-4-25 21:48 , Processed in 0.061604 second(s), 9 queries , Gzip On, MemCache On.
