查看: 1694|回复: 7
Pacificrack 512m4核Benchmarks
发表于 2019-11-9 21:19:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
   BYTE UNIX Benchmarks (Version 5.1.3)
   System: host.domain.com: GNU/Linux
   OS: GNU/Linux -- 4.9.0-4-amd64 -- #1 SMP Debian 4.9.65-3+deb9u1 (2017-12-23)
   Machine: x86_64 (unknown)
   Language: en_US.utf8 (charmap="UTF-8", collate="UTF-8")
   CPU 0: QEMU Virtual CPU version (cpu64-rhel6) (4200.0 bogomips)
          x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET
   CPU 1: QEMU Virtual CPU version (cpu64-rhel6) (4200.0 bogomips)
   CPU 2: QEMU Virtual CPU version (cpu64-rhel6) (4200.0 bogomips)
   CPU 3: QEMU Virtual CPU version (cpu64-rhel6) (4200.0 bogomips)
   07:08:21 up  1:10,  1 user,  load average: 0.29, 0.19, 0.34; runlevel 5
Benchmark Run: Sat Nov 09 2019 07:08:21 - 07:36:29
4 CPUs in system; running 1 parallel copy of tests
Dhrystone 2 using register variables       24928561.6 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     3950.4 MWIPS (9.7 s, 7 samples)
Execl Throughput                               1566.0 lps   (29.9 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        835565.6 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks          234972.1 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks       1741266.8 KBps  (30.0 s, 2 samples)
Pipe Throughput                             1769791.7 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                  24482.6 lps   (10.0 s, 7 samples)
Process Creation                               3227.6 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                   3810.9 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                   1867.9 lpm   (60.0 s, 2 samples)
System Call Overhead                        2503963.3 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0   24928561.6   2136.1
Double-Precision Whetstone                       55.0       3950.4    718.3
Execl Throughput                                 43.0       1566.0    364.2
File Copy 1024 bufsize 2000 maxblocks          3960.0     835565.6   2110.0
File Copy 256 bufsize 500 maxblocks            1655.0     234972.1   1419.8
File Copy 4096 bufsize 8000 maxblocks          5800.0    1741266.8   3002.2
Pipe Throughput                               12440.0    1769791.7   1422.7
Pipe-based Context Switching                   4000.0      24482.6     61.2
Process Creation                                126.0       3227.6    256.2
Shell Scripts (1 concurrent)                     42.4       3810.9    898.8
Shell Scripts (8 concurrent)                      6.0       1867.9   3113.2
System Call Overhead                          15000.0    2503963.3   1669.3
System Benchmarks Index Score                                         947.5
Benchmark Run: Sat Nov 09 2019 07:36:29 - 08:04:40
4 CPUs in system; running 4 parallel copies of tests
Dhrystone 2 using register variables       97969562.7 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                    15647.7 MWIPS (9.8 s, 7 samples)
Execl Throughput                              13407.2 lps   (30.0 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        701361.1 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks          195944.0 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks       2124433.6 KBps  (30.0 s, 2 samples)
Pipe Throughput                             6963168.5 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                 477997.5 lps   (10.0 s, 7 samples)
Process Creation                              12104.6 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                  20453.6 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                   2730.7 lpm   (60.0 s, 2 samples)
System Call Overhead                        5009936.7 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0   97969562.7   8395.0
Double-Precision Whetstone                       55.0      15647.7   2845.0
Execl Throughput                                 43.0      13407.2   3117.9
File Copy 1024 bufsize 2000 maxblocks          3960.0     701361.1   1771.1
File Copy 256 bufsize 500 maxblocks            1655.0     195944.0   1184.0
File Copy 4096 bufsize 8000 maxblocks          5800.0    2124433.6   3662.8
Pipe Throughput                               12440.0    6963168.5   5597.4
Pipe-based Context Switching                   4000.0     477997.5   1195.0
Process Creation                                126.0      12104.6    960.7
Shell Scripts (1 concurrent)                     42.4      20453.6   4824.0
Shell Scripts (8 concurrent)                      6.0       2730.7   4551.2
System Call Overhead                          15000.0    5009936.7   3340.0
System Benchmarks Index Score                                        2835.0
======= Script description and score comparison completed! =======
 楼主| 发表于 2019-11-9 21:20:05 | 只看该作者
这应该是个bug,4核的
发表于 2019-11-9 21:21:02 | 只看该作者
发表于 2019-11-9 21:21:22 | 只看该作者
512M 开的都是4核,不过我已经发工单取消了
发表于 2019-11-9 21:27:59 来自手机 | 只看该作者
尼玛 2800 上天了
发表于 2019-11-9 21:28:29 | 只看该作者
你是几点开的,都长时间开通的,我的一个多小时了,还等待中
 楼主| 发表于 2019-11-9 21:37:36 | 只看该作者
已不间断运行: 0天2小时38分钟
 楼主| 发表于 2019-11-9 21:38:52 | 只看该作者
4核肯定要屌一些
GMT+8, 2026-4-15 13:24 , Processed in 0.066000 second(s), 10 queries , Gzip On, MemCache On.
