查看: 3389|回复: 32
有同样被甲骨文扣费的mjj没
发表于 2019-9-19 11:31:12 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
发表于 2019-9-19 11:44:45 | 只看该作者
看一下 引导卷 boot volume,如果名字旁边没有始终免费就是扣费的。机子要重装。一定要确保引导卷始终是有这个标签。 一共就给了100G,两个机子就用完了,剩下新产生的就会扣费,删掉其他的卷也没用,只有把本体删除。 备份系统的引导卷一定要注意
原文释疑,讲的还算清楚
Details of the Always Free Block Volume resources
100 GB total of combined boot volume and block volume Always Free Block Volume storage.
Five total volume backups (boot volume and block volume combined).
When you create a Compute instance, the default boot volume size for the instance is 50 GB, which counts towards your allotment of 100 GB. You can customize the instance's boot volume size up to 100 GB; however, this will use up your full allotment of storage for Always Free Block Volume resources. Also, because the minimum boot volume size allowed for Compute instances is 50 GB, launching two instances will use all your Always Free Block Volume resources. Alternatively, you can launch one instance with the default boot volume size of 50 GB, and then create and attach a 50 GB block volume to expand the storage capacity of the instance. For more information, see Creating a Volume and Attaching a Volume. Although it is possible to mix paid and Always Free resources, Oracle does not recommend this. If you have used up your allotment of Always Free Block Volume resources, you can free up block storage resources by terminating an Always Free instance and deleting the boot volume, or terminating an Always Free block volume.
You can have a maximum of five Always Free volume backups at any time. This applies to both boot volume and block volume backups. For example, you could have three boot volume backups for your Always Free instance and two block volume backups for your Always Free block volumes. In this example, if you try to create new backups, the operation will fail with an error until you delete existing Always Free volume backups. For more information about volume backups, see Overview of Block Volume Backups and Overview of Boot Volume Backups.
为了这个东西从昨晚开始一直研究到早上。
 楼主| 发表于 2019-9-19 11:32:25 | 只看该作者
开了两台日本always free的机子,不懂这费用哪来的
发表于 2019-9-19 11:33:06 | 只看该作者
我也被扣了,只不过显示的是CPU
发表于 2019-9-19 11:39:07 | 只看该作者
尴尬了···大家赶紧去检查下吧~~~
发表于 2019-9-19 11:41:27 | 只看该作者
你扣的是礼金,还是扣的你的信用卡??
发表于 2019-9-19 11:43:53 | 只看该作者
winwin50 发表于 2019-9-19 11:41
你扣的是礼金,还是扣的你的信用卡??
肯定是赠款。。。优先用这个
 楼主| 发表于 2019-9-19 12:03:30 | 只看该作者
天方地圆孔方兄 发表于 2019-9-19 11:44
看一下 引导卷 boot volume,如果名字旁边没有始终免费就是扣费的。机子要重装。一定要确保引导卷始终是有 ...
哪个地方没看见啊
重新弄一个吧,这个是扣费的。楼下那个就是不扣钱的  发表于 2019-9-19 12:13
发表于 2019-9-19 12:08:07 | 只看该作者
 楼主| 发表于 2019-9-19 12:11:09 | 只看该作者
我都是默认的,新建实例引导券没有始终免费提示吧
GMT+8, 2026-1-16 03:39 , Processed in 0.068966 second(s), 12 queries , Gzip On, MemCache On.
