查看: 4973|回复: 6
Important Notice Regarding Your Domain Name(s) GD的这封信什么意思
发表于 2011-5-10 09:38:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Dear xxx,
It's that time of year again. ICANN (the Internet Corporation for Assigned Names and Numbers) annually requires that all accredited registrars (like Go Daddy) ask their domain administrators/registrants to review domain name contact data and make any changes necessary to ensure accuracy. According to our records, you are the ADMINISTRATIVE CONTACT on the following domain names registered at GoDaddy.com as of 5/9/2011:
xxx.COM
To review/update your contact data:
        1.        You will need a copy of your Domain Information Key:
xxx
         2.        Go to https://www.godaddy.com/icann/
        3.        Input your Domain Information Key and review your contact information.
If you find that your domain contact data is current and accurate, there's no need to take action. If, however, your domain contact information is inaccurate, you must correct it. (Under ICANN rules and the terms of your registration agreement, PROVIDING FALSE CONTACT INFORMATION CAN BE GROUNDS FOR DOMAIN NAME CANCELLATION.) To review the ICANN policy, visit: http://www.icann.org/en/whois/wdrp-registrant-faq.htm
Review your contact information then SAVE 20% on $65* at GoDaddy.com!
Use source code BBCNAB when you check out.
If you have questions or believe you received this email in error, you can get help at http://www.godaddy.com/gethelp or give us a call 24/7 at (480) 505-8877.
As our thanks for reviewing your account settings, please take 20% OFF your order of $65* or more. This offer expires 6/8/2011 at midnight (PT).
Sincerely,
GoDaddy.com Domain Support
*Not applicable to ICANN fees, taxes, shipping and handling, sale priced domain names, bulk domains, premium domains, Sunrise/Landrush domain registrations and pre-registrations, memberships or maintenance plans, additional disk space and bandwidth renewals, additional AdSpace advertising funds, custom page layouts, incorporation and brand identity services, Go Daddy branded merchandise, posters, die-cast cars or gift cards. Discount reflected in your shopping cart – cannot be used in conjunction with any other offer, discount or promotion. Cannot be used with renewals discounted from current list pricing.
Note: If you are the domain administrator of more than one GoDaddy.com domain account, you may receive this notice multiple times.
Copyright © 2011 GoDaddy.com, Inc. All rights reserved.
注册域名用的假资料没事吧
发表于 2011-5-10 10:44:42 | 只看该作者
调查信 按要求到godaddy输入key就可以了
发表于 2011-5-10 10:52:43 | 只看该作者
如果你填写的WHOIS资料是正确的,什么都不用做。
如果有错误或需要更新,那就要到GD更新。
参与人数 1威望 +20 收起 理由
Kokgog + 20 嗯嗯,无视就可以了........
发表于 2011-5-10 12:31:59 | 只看该作者
没需要改动注册信息的话不用管
GD随机抽查到你了
发表于 2011-5-10 12:54:50 | 只看该作者
抽查你的域名信息而已
 楼主| 发表于 2011-5-10 13:21:24 | 只看该作者
谢谢楼上诸位
我已经修改成偏向真实的信息
但是不全是
发表于 2011-5-10 20:25:06 | 只看该作者
叼 楼主哪里都混啊!!
GMT+8, 2026-4-22 05:04 , Processed in 0.058718 second(s), 10 queries , Gzip On, MemCache On.
