CeraNetworks网络延迟测速工具IP归属甄别
查看: 3396|回复: 1
733 error on VPN settings
发表于 2011-5-4 12:11:01 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
修复733问题的3种方法:
1. netsh int ip reset resetlog.txt
2. netsh winsock reset
3. reboot
前2个命令会将网络设置到dhcp,因此在重启前, 要先把IP设置到静态IP,否则你就进不去了
 楼主| 发表于 2011-5-4 12:24:51 | 只看该作者
You can try below 3 commands to fix 733 error
3. reboot
First 2 commands will convert the network setting of your server to dhcp, therefore before you reboot, make sure to change ip setting to static ip otherwise after reboot you will not able to access the server.
GMT+8, 2026-5-1 21:20 , Processed in 0.057941 second(s), 10 queries , Gzip On, MemCache On.
