查看: 5740|回复: 0
让主域名指向public_html下的子目录
发表于 2008-10-30 17:50:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
编辑public_html目录下的.htaccess文件,加入如下语句.如果public_html下没有.htaccess文件,新建一个即可.
注意:将 yourmaindomain.com修改为你的域名,将subfolder修改为你要指向的public_html下的子目录.最后一行中的index.php修改为你的网站的主页名称.(修改粗体表示的内容,其他内容不要改动)
# www.loc.qiche.eu.org
# .htaccess main domain to subfolder redirect
# Copy and paste the following code into the .htaccess file
# in the public_html folder of your hosting account
# make the changes to the file according to the instructions.
RewriteEngine on
# Change yourdomain.com to be your main domain.
RewriteCond %{HTTP_HOST} ^(www.)?yourmaindomain.com$
# Change ’subfolder’ to be the folder you will use for your main domain.
RewriteCond %{REQUEST_URI} !^/subfolder/
# Don’t change this line.
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule ^(.*)$ /subfolder/$1
# Change yourdomain.com to be your main domain again.
# followed by / then the main file for your site, index.php, index.html, etc.
RewriteRule ^(/)?$ subfolder/index.php [L]
GMT+8, 2026-4-18 13:34 , Processed in 0.056065 second(s), 8 queries , Gzip On, MemCache On.
