查看: 5525|回复: 20
独服@i7-2600
发表于 2011-4-21 18:30:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
果然名不虚传,性能有点小虎,单核居然有1800+分
这是去除了IO的分数,秀一下
./Run dhry2reg whetstone-double syscall pipe context1 spawn execl shell1 shell8
make all
make[1]: Entering directory `/usr/local/src/unixbench-5.1.2'
Checking distribution of files
./pgms  exists
./src  exists
./testdir  exists
./tmp  exists
./results  exists
make[1]: Leaving directory `/usr/local/src/unixbench-5.1.2'
sh: 3dinfo: not found
   Version 5.1.2                      Based on the Byte Magazine Unix Benchmark
   Multi-CPU version                  Version 5 revisions by Ian Smith,
                                      Sunnyvale, CA, USA
   December 22, 2007                  johantheghost at yahoo period com
1 x Dhrystone 2 using register variables  1 2 3 4 5 6 7 8 9 10
1 x Double-Precision Whetstone  1 2 3 4 5 6 7 8 9 10
1 x System Call Overhead  1 2 3 4 5 6 7 8 9 10
1 x Pipe Throughput  1 2 3 4 5 6 7 8 9 10
1 x Pipe-based Context Switching  1 2 3 4 5 6 7 8 9 10
1 x Process Creation  1 2 3
1 x Execl Throughput  1 2 3
1 x Shell Scripts (1 concurrent)  1 2 3
1 x Shell Scripts (8 concurrent)  1 2 3
8 x Dhrystone 2 using register variables  1 2 3 4 5 6 7 8 9 10
8 x Double-Precision Whetstone  1 2 3 4 5 6 7 8 9 10
8 x System Call Overhead  1 2 3 4 5 6 7 8 9 10
8 x Pipe Throughput  1 2 3 4 5 6 7 8 9 10
8 x Pipe-based Context Switching  1 2 3 4 5 6 7 8 9 10
8 x Process Creation  1 2 3
8 x Execl Throughput  1 2 3
8 x Shell Scripts (1 concurrent)  1 2 3
8 x Shell Scripts (8 concurrent)  1 2 3
   BYTE UNIX Benchmarks (Version 5.1.2)
   System: 218489.burst.app-base.com: GNU/Linux
   OS: GNU/Linux -- 2.6.35-22-generic -- #34-Ubuntu SMP Sun Oct 10 09:26:05 UTC 2010
   Machine: x86_64 (unknown)
   Language: en_US.utf8 (charmap="UTF-8", collate="UTF-8")
   CPU 0: Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz (6784.4 bogomips)
          Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET, Intel virtualization
   CPU 1: Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz (6784.5 bogomips)
   CPU 2: Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz (6784.5 bogomips)
   CPU 3: Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz (6784.5 bogomips)
   CPU 4: Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz (6784.5 bogomips)
   CPU 5: Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz (6784.5 bogomips)
   CPU 6: Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz (6784.5 bogomips)
   CPU 7: Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz (6784.5 bogomips)
   02:41:10 up  6:48,  2 users,  load average: 9.64, 17.91, 11.59; runlevel 2
Benchmark Run: Thu Apr 21 2011 02:41:10 - 03:02:03
8 CPUs in system; running 1 parallel copy of tests
Dhrystone 2 using register variables       37821128.8 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     4041.8 MWIPS (9.9 s, 7 samples)
Execl Throughput                               4497.3 lps   (29.9 s, 2 samples)
Pipe Throughput                             2491942.2 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                 239984.0 lps   (10.0 s, 7 samples)
Process Creation                              19442.4 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                  11689.2 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                   4867.0 lpm   (60.0 s, 2 samples)
System Call Overhead                        4365438.2 lps   (10.0 s, 7 samples)
System Benchmarks Partial Index              BASELINE       RESULT    INDEX
Dhrystone 2 using register variables         116700.0   37821128.8   3240.9
Double-Precision Whetstone                       55.0       4041.8    734.9
Execl Throughput                                 43.0       4497.3   1045.9
Pipe Throughput                               12440.0    2491942.2   2003.2
Pipe-based Context Switching                   4000.0     239984.0    600.0
Process Creation                                126.0      19442.4   1543.0
Shell Scripts (1 concurrent)                     42.4      11689.2   2756.9
Shell Scripts (8 concurrent)                      6.0       4867.0   8111.7
System Call Overhead                          15000.0    4365438.2   2910.3
System Benchmarks Index Score (Partial Only)                         1885.1
Benchmark Run: Thu Apr 21 2011 03:02:03 - 03:23:04
8 CPUs in system; running 8 parallel copies of tests
Dhrystone 2 using register variables      163484593.0 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                    27558.6 MWIPS (9.9 s, 7 samples)
Execl Throughput                              31942.1 lps   (30.0 s, 2 samples)
Pipe Throughput                            10884466.9 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                2547238.2 lps   (10.0 s, 7 samples)
Process Creation                              95259.2 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                  46633.8 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                   6099.2 lpm   (60.0 s, 2 samples)
System Call Overhead                        9815086.0 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0  163484593.0  14009.0
Double-Precision Whetstone                       55.0      27558.6   5010.7
Execl Throughput                                 43.0      31942.1   7428.4
Pipe Throughput                               12440.0   10884466.9   8749.6
Pipe-based Context Switching                   4000.0    2547238.2   6368.1
Process Creation                                126.0      95259.2   7560.3
Shell Scripts (1 concurrent)                     42.4      46633.8  10998.5
Shell Scripts (8 concurrent)                      6.0       6099.2  10165.3
System Call Overhead                          15000.0    9815086.0   6543.4
System Benchmarks Index Score (Partial Only)                         8161.6
发表于 2011-4-21 18:34:17 | 只看该作者
5.13 看看
发表于 2011-4-21 18:36:50 | 只看该作者
强烈要求赞助
I7 當然要買 i7 990x
 楼主| 发表于 2011-4-21 18:41:06 | 只看该作者
原帖由 chris1914 于 2011-4-21 18:36 发表
I7 當然要買 i7 990x
i7 990x那个谁家有?有也是天价
i7-2600是Sandy Bridge架构,节电+单U便宜,一般来说服务商会给较低的价格
发表于 2011-4-21 18:42:35 | 只看该作者
强啊!!!!
发表于 2011-4-21 18:46:05 | 只看该作者
求暂住
发表于 2011-4-21 18:55:48 | 只看该作者
为啥要去除IO……
发表于 2011-4-21 18:58:31 | 只看该作者
4楼最近很有钱么?
我现在还记得那天为了1美元来讨债的口气......
 楼主| 发表于 2011-4-21 19:00:52 | 只看该作者
原帖由 Showfom 于 2011-4-21 18:55 发表
为啥要去除IO……
因为IO环境不一样会导致分数差别很大,不能很好地反映性能,而且人家unixbench的发布帖就号召去除IO的发布,我就跟风了。
http://www.webhostingtalk.com/showthread.php?t=924581
GMT+8, 2026-4-30 13:25 , Processed in 0.065392 second(s), 10 queries , Gzip On, MemCache On.
