查看: 4500|回复: 15
求解....关于远程桌面RDP的
发表于 2019-5-9 00:07:12 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
两个机器在同一个服务器上.同一个母鸡
一个vps的3389是好的.一个时好时坏
重装系统也一样,
正常的机器是这样子的:
Probing 103.232.1**.**:3389/tcp - Port is open - time=3.741ms
Probing 103.232.1**.**:3389/tcp - Port is open - time=4.244ms
Probing 103.232.1**.**:3389/tcp - Port is open - time=5.460ms
Probing 103.232.1**.**:3389/tcp - Port is open - time=4.262ms
Probing 103.232.1**.**:3389/tcp - Port is open - time=5.116ms
Probing 103.232.1**.**:3389/tcp - Port is open - time=5.130ms
Probing 103.232.1**.**:3389/tcp - Port is open - time=4.771ms
Probing 103.232.1**.**:3389/tcp - Port is open - time=4.588ms
Probing 103.232.1**.**:3389/tcp - Port is open - time=4.570ms
Probing 103.232.1**.**:3389/tcp - Port is open - time=5.683ms
Probing 103.232.1**.**:3389/tcp - Port is open - time=4.883ms
Probing 103.232.1**.**:3389/tcp - Port is open - time=4.495ms
Probing 103.232.1**.**:3389/tcp - Port is open - time=4.679ms
Probing 103.232.1**.**:3389/tcp - Port is open - time=3.902ms
Probing 103.232.1**.**:3389/tcp - Port is open - time=4.806ms
Probing 103.232.1**.**:3389/tcp - Port is open - time=5.661ms
Probing 103.232.1**.**:3389/tcp - Port is open - time=4.387ms
Probing 103.232.1**.**:3389/tcp - Port is open - time=4.698ms
Probing 103.232.1**.**:3389/tcp - Port is open - time=4.987ms
Probing 103.232.1**.**:3389/tcp - Port is open - time=5.321ms
Probing 103.232.1**.**:3389/tcp - Port is open - time=4.340ms
Probing 103.232.1**.**:3389/tcp - Port is open - time=4.436ms
Probing 103.232.1**.**:3389/tcp - Port is open - time=5.346ms
Probing 103.232.1**.**:3389/tcp - Port is open - time=4.629ms
不正常的是这样子的::
Probing 103.232.1**.**:3389/tcp - No response - time=2001.008ms
Probing 103.232.1**.**:3389/tcp - No response - time=2001.132ms
Probing 103.232.1**.**:3389/tcp - Port is open - time=506.125ms
Probing 103.232.1**.**:3389/tcp - No response - time=2001.041ms
Probing 103.232.1**.**:3389/tcp - No response - time=2001.072ms
Probing 103.232.1**.**:3389/tcp - Port is open - time=6.536ms
Probing 103.232.1**.**:3389/tcp - No response - time=2001.009ms
Probing 103.232.1**.**:3389/tcp - Port is open - time=5.667ms
Probing 103.232.1**.**:3389/tcp - Port is open - time=6.300ms
Probing 103.232.1**.**:3389/tcp - No response - time=2001.007ms
Probing 103.232.1**.**:3389/tcp - No response - time=2000.142ms
Probing 103.232.1**.**:3389/tcp - No response - time=2000.124ms
Probing 103.232.1**.**:3389/tcp - Port is open - time=515.089ms
Probing 103.232.1**.**:3389/tcp - No response - time=2000.986ms
Probing 103.232.1**.**:3389/tcp - No response - time=2000.182ms
Probing 103.232.1**.**:3389/tcp - Port is open - time=1026.177ms
Probing 103.232.1**.**:3389/tcp - No response - time=2001.075ms
Probing 103.232.1**.**:3389/tcp - No response - time=2000.135ms
Probing 103.232.1**.**:3389/tcp - Port is open - time=4.183ms
Probing 103.232.1**.**:3389/tcp - No response - time=2001.011ms
Probing 103.232.1**.**:3389/tcp - Port is open - time=505.186ms
Probing 103.232.1**.**:3389/tcp - Port is open - time=4.952ms
Probing 103.232.1**.**:3389/tcp - Port is open - time=4.800ms
 楼主| 发表于 2019-5-9 00:09:31 | 只看该作者
我去..图片咋这么小..
发表于 2019-5-9 00:12:26 | 只看该作者
都元老了,还这么皮。你需要个图床
 楼主| 发表于 2019-5-9 00:36:46 | 只看该作者
发了纯文字版
发表于 2019-5-9 00:39:47 来自手机 | 只看该作者
改成两个不同的端口
发表于 2019-5-9 00:41:40 | 只看该作者
干扰,换端口吧。
 楼主| 发表于 2019-5-9 00:50:46 | 只看该作者
62900015 发表于 2019-5-9 00:41
干扰,换端口吧。
有木有法子不换端口...换端口贼鸡儿痛苦.因为还有一堆机器要换端口额.
发表于 2019-5-9 00:56:59 | 只看该作者
换端口,干扰。楼主需要图床
 楼主| 发表于 2019-5-9 00:59:50 | 只看该作者
geo 发表于 2019-5-9 00:56
换端口,干扰。楼主需要图床
这玩意是哪里来的干扰?
vps与vps之间的干扰么
发表于 2019-5-9 01:02:58 | 只看该作者
winder 发表于 2019-5-9 00:59
这玩意是哪里来的干扰?
vps与vps之间的干扰么
内网还是外网,外网就是墙的干扰。内网检查防火墙/交换机和ARP。
GMT+8, 2026-4-16 08:49 , Processed in 0.066286 second(s), 11 queries , Gzip On, MemCache On.
