查看: 4044|回复: 13
晒一个1刀四核Xeon独服,公布root密码
发表于 2011-4-2 03:22:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
WHT上淘的首月1刀服务器,本来就想试试看的1刀也损失不了多少,想不到一天就部署好给我了
配置如下:
Technical Specifications
Manufacturer: Dell
Model: R210
Processor: 1x Xeon X3430, 2400 MHz (4 cores per CPU)
Memory: 4x2GB
Hard Drive: 2 x 300GB, SAS 15000rpm
RAID levels supported: Hardware RAID 1
Network Adapter: 1000 Mbit/s
Form Factor: Rack mounted, 1U
Order Details
Dell R210 SAS
Created: Apr 1, 2011 01:56
IPs: 93.170.104.54,93.170.104.55
Status: In use
Tarif: R210 SAS Trial
Start date: Apr 1, 2011 11:37
Expected end date: May 1, 2011 00:00
Total rent period: 1 months,0 days  Extend
Month traffic: Unlimited
OS: CentOS 5.5 64 bit ($ 0.00 per CPU / month)
Port speed: 1000 Mbit/s (2011-04-01 20:46:03)
Port state: UP
续费是将近两百刀的样子,肯定是不会续的了,这个我主要是拿来看看X3450+RAID1的性能到底如何
等我折腾完了以后把密码放出来,大家都可以拿去玩玩:)
更新:我已经用完了,到这个月底到期,请随意折腾吧,玩坏了我也不回去要求重启的,所以节制点
93.170.104.54
root:1dollar
更新2:刚公布密码就给我改密码,怒了,收回
更新3:更新了一个test:test的没有root权限的帐号,看看还会不会有人去改
[ 本帖最后由 observer 于 2011-4-2 11:09 编辑 ]
 楼主| 发表于 2011-4-2 03:22:31 | 只看该作者
一些测试结果:
因为只是RAID1,用dd测试的磁盘IO上看不出太大的优势,大概是110M/s的样子
给个探针
http://93.170.104.54/iProber.php
http://93.170.104.54/p.php
贴个geekbench的成绩,总分7776
http://browse.geekbench.ca/geekbench2/view?id=390168
给个Unixbench 5.1.2禁用磁盘测试以后的成绩:
[root@d1702 results]# cat d1702-2011-04-01-02
   BYTE UNIX Benchmarks (Version 5.1.2)
   System: d1702: GNU/Linux
   OS: GNU/Linux -- 2.6.18-194.el5 -- #1 SMP Fri Apr 2 14:58:14 EDT 2010
   Machine: x86_64 (x86_64)
   Language: en_US.utf8 (charmap="UTF-8", collate="UTF-8")
   CPU 0: Intel(R) Xeon(R) CPU X3450 @ 2.67GHz (5320.1 bogomips)
          Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET, Intel virtualization
   CPU 1: Intel(R) Xeon(R) CPU X3450 @ 2.67GHz (5320.0 bogomips)
   CPU 2: Intel(R) Xeon(R) CPU X3450 @ 2.67GHz (5320.0 bogomips)
   CPU 3: Intel(R) Xeon(R) CPU X3450 @ 2.67GHz (5320.0 bogomips)
   CPU 4: Intel(R) Xeon(R) CPU X3450 @ 2.67GHz (5319.9 bogomips)
   CPU 5: Intel(R) Xeon(R) CPU X3450 @ 2.67GHz (5319.9 bogomips)
   CPU 6: Intel(R) Xeon(R) CPU X3450 @ 2.67GHz (5319.9 bogomips)
   CPU 7: Intel(R) Xeon(R) CPU X3450 @ 2.67GHz (5319.9 bogomips)
   20:27:21 up  9:56,  2 users,  load average: 4.23, 16.48, 12.28; runlevel 3
Benchmark Run: Fri Apr 01 2011 20:27:21 - 20:51:36
8 CPUs in system; running 1 parallel copy of tests
Dhrystone 2 using register variables       15371058.7 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     3038.3 MWIPS (9.9 s, 7 samples)
Execl Throughput                               3598.5 lps   (29.9 s, 2 samples)
Pipe Throughput                             1014611.8 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                 136597.2 lps   (10.0 s, 7 samples)
Process Creation                              16648.6 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                   6991.7 lpm   (60.0 s, 2 samples)
Shell Scripts (16 concurrent)                  1654.3 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                   2893.3 lpm   (60.0 s, 2 samples)
System Call Overhead                         950585.1 lps   (10.0 s, 7 samples)
System Benchmarks Partial Index              BASELINE       RESULT    INDEX
Dhrystone 2 using register variables         116700.0   15371058.7   1317.1
Double-Precision Whetstone                       55.0       3038.3    552.4
Execl Throughput                                 43.0       3598.5    836.9
Pipe Throughput                               12440.0    1014611.8    815.6
Pipe-based Context Switching                   4000.0     136597.2    341.5
Process Creation                                126.0      16648.6   1321.3
Shell Scripts (1 concurrent)                     42.4       6991.7   1649.0
Shell Scripts (16 concurrent)                     ---       1654.3      ---
Shell Scripts (8 concurrent)                      6.0       2893.3   4822.2
System Call Overhead                          15000.0     950585.1    633.7
System Benchmarks Index Score (Partial Only)                         1013.6
Benchmark Run: Fri Apr 01 2011 20:51:36 - 21:15:34
8 CPUs in system; running 8 parallel copies of tests
Dhrystone 2 using register variables       57601855.8 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                    19571.3 MWIPS (9.9 s, 7 samples)
Execl Throughput                              20810.0 lps   (29.9 s, 2 samples)
Pipe Throughput                             4924890.4 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                1524922.5 lps   (10.0 s, 7 samples)
Process Creation                              84844.8 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                  32341.6 lpm   (60.0 s, 2 samples)
Shell Scripts (16 concurrent)                  2227.1 lpm   (60.1 s, 2 samples)
Shell Scripts (8 concurrent)                   4451.0 lpm   (60.1 s, 2 samples)
System Call Overhead                        5561688.3 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0   57601855.8   4935.9
Double-Precision Whetstone                       55.0      19571.3   3558.4
Execl Throughput                                 43.0      20810.0   4839.5
Pipe Throughput                               12440.0    4924890.4   3958.9
Pipe-based Context Switching                   4000.0    1524922.5   3812.3
Process Creation                                126.0      84844.8   6733.7
Shell Scripts (1 concurrent)                     42.4      32341.6   7627.7
Shell Scripts (16 concurrent)                     ---       2227.1      ---
Shell Scripts (8 concurrent)                      6.0       4451.0   7418.3
System Call Overhead                          15000.0    5561688.3   3707.8
System Benchmarks Index Score (Partial Only)                         4958.6
发表于 2011-4-2 03:33:21 | 只看该作者
 楼主| 发表于 2011-4-2 03:45:11 | 只看该作者
有没有弄到那个50刀/月的X3450?那个真是羡慕嫉妒恨啊,要是我那段时间去一下WHT就好了,性价比简直太高了,加硬盘居然还是one-off的,口碑还很不错,真是禽兽一般的价格啊
买个这个主要是为了了解一下中端服务器的性能状态
坐等过几周i7 2600,或者xeon e3 12XX大量上市了
那处理器也是禽兽,能耗低,性能强,所以售价肯定不会很高,已经在WHT上看到不少99刀的i7了,不过对我来说还是贵,现在还是对磁盘IO更为看重一点。
发表于 2011-4-2 03:47:31 | 只看该作者
这性价比.实在不错.
不过IO倒是挺杯具的..
观望中.
发表于 2011-4-2 04:22:05 | 只看该作者
 楼主| 发表于 2011-4-2 10:53:57 | 只看该作者
密码已经公布,enjoy
 楼主| 发表于 2011-4-2 11:04:05 | 只看该作者
原帖由 observer 于 2011-4-2 10:53 发表
密码已经公布,enjoy
公布服务器是让“大家”玩的,不是让人该密码了自用的
既然这样不识抬举,那我收回了
发表于 2011-4-2 11:05:07 | 只看该作者
SAS硬盘,不错啊
发表于 2011-4-2 11:26:18 | 只看该作者
serverculb.com
如果我没猜错的话。
GMT+8, 2026-5-1 00:43 , Processed in 0.064527 second(s), 10 queries , Gzip On, MemCache On.
