查看: 8827|回复: 17
0.99美元的客服
发表于 2011-3-25 15:36:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
发现没开启 gzip 访问很慢, 没用过 cpanel 也不知道怎么开启
于是我用蹩脚英语和 live chat 询问如何开启 gzip
Hello, your representative is Andrew
Welcome to Hostable, Andrew will be right with you.
Andrew
Thank you for visiting today, how may I help you?
yaoe@*********
hi, i want to know, how do turn on gzip?
yaoe@*********
in cpanel
Andrew
it is turned on
Andrew
you select the file you want to zip and select compress
yaoe@*********
but i vista php page, it's off.
yaoe@*********
HTTP/1.1 200 OK
Date: Fri, 25 Mar 2011 07:21:15 GMT
Server: Apache/2.2.17 (Unix) mod_ssl/2.2.17 OpenSSL/0.9.8e-fips-rhel5 mod_auth_passthrough/2.1 mod_bwlimited/1.4 FrontPage/5.0.2.2635
X-Powered-By: PHP/5.3.6
Transfer-Encoding: chunked
Content-Type: text/html
Andrew
I'm not sure I follow you ?
yaoe@*********
i sorry for bad english.
yaoe@*********
apache gzip maybe off
yaoe@*********
so, access is too slow
Andrew
no, I am able to access gzip in your account
yaoe@*********
Is there any way you can enable the gzip
yaoe@*********
Oh, thanks, I'll give it a try
Andrew
yes i just compressed a test file using gzip
yaoe@*********
If gzip open, then when I visit a page, the page should be for the gzip output.
yaoe@*********
Instead of using the gzip compressed file
Andrew
you go to your files located in your account
Andrew
select the file you want to compress and chose gzip
yaoe@*********
Anyway, thanks, take your time
[ 本帖最后由 yaoe 于 2011-3-25 15:40 编辑 ]
参与人数 1威望 -2 收起 理由
xxxbi -2 骂人是就该扣分,你还反过来扣别人分 ...
发表于 2011-3-25 15:38:48 | 只看该作者
我要看国语,请楼主翻译!
发表于 2011-3-25 16:57:35 | 只看该作者
默认是开启状态的
发表于 2011-3-25 17:01:02 | 只看该作者
蹩脚英语呃。。
老外如果不知道你是中国的话,可能会看成澳大利亚英语。。
因为澳大利亚英语和你说的差不多。
 楼主| 发表于 2011-3-25 17:12:37 | 只看该作者
回复 3# 的帖子
没有开启啊,你确定这开启了?
# curl -I --compressed  ****.a.hostable.me
HTTP/1.1 200 OK
Date: Fri, 25 Mar 2011 08:46:32 GMT
Last-Modified: Fri, 25 Mar 2011 04:49:51 GMT
ETag: "1570009-420-49f47530259c0"
Accept-Ranges: bytes
Content-Length: 1056
发表于 2011-3-26 09:09:22 | 只看该作者
客服好像看成你在咨询:如何压缩文件
发表于 2011-3-26 19:54:47 | 只看该作者
原帖由 sunday 于 2011-3-26 09:09 发表
客服好像看成你在咨询:如何压缩文件
发表于 2011-3-26 22:01:48 | 只看该作者
zend都不让用,因为他安装了apc
 楼主| 发表于 2011-3-26 22:08:40 | 只看该作者
回复 8# 的帖子
不能用zend的真正原因是他们用了5.3.6的php,而zend当前只能支持到php 5.2.x,这是zend自身的悲剧.和apc无关
发表于 2011-3-26 22:23:11 | 只看该作者
原帖由 yaoe 于 2011-3-26 22:08 发表
好像在whm下没办法同时使用apc+zend,查了好多资料没解决方案.
GMT+8, 2026-4-17 00:02 , Processed in 0.072931 second(s), 13 queries , Gzip On, MemCache On.
