查看: 4029|回复: 9
MYEntunnel 只能打开https连接。
发表于 2011-3-22 17:57:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请教了 https连接可以转发 但是http就不行 报错如下
17:54:58.401 (unrecognized proxy protocol) connection from 127.0.0.1:57351 failed: Unsupported client protocol; the client may be expecting a regular HTTP proxy.
17:54:58.523 (unrecognized proxy protocol) connection from 127.0.0.1:57352 failed: Unsupported client protocol; the client may be expecting a regular HTTP proxy.
17:54:58.987 (unrecognized proxy protocol) connection from 127.0.0.1:57353 failed: Unsupported client protocol; the client may be expecting a regular HTTP proxy.
17:55:08.145 (unrecognized proxy protocol) connection from 127.0.0.1:57354 failed: Unsupported client protocol; the client may be expecting a regular HTTP proxy.
17:55:08.283 (unrecognized proxy protocol) connection from 127.0.0.1:57355 failed: Unsupported client protocol; the client may be expecting a regular HTTP proxy.
17:55:08.365 (unrecognized proxy protocol) connection from 127.0.0.1:57356 failed: Unsupported client protocol; the client may be expecting a regular HTTP proxy.
17:55:08.771 (unrecognized proxy protocol) connection from 127.0.0.1:57357 failed: Unsupported client protocol; the client may be expecting a regular HTTP proxy.
17:55:16.444 (unrecognized proxy protocol) connection from 127.0.0.1:57358 failed: Unsupported client protocol; the client may be expecting a regular HTTP proxy.
17:55:16.642 (unrecognized proxy protocol) connection from 127.0.0.1:57359 failed: Unsupported client protocol; the client may be expecting a regular HTTP proxy.
17:55:17.009 (unrecognized proxy protocol) connection from 127.0.0.1:57360 failed: Unsupported client protocol; the client may be expecting a regular HTTP proxy.
17:55:17.091 (unrecognized proxy protocol) connection from 127.0.0.1:57361 failed: Unsupported client protocol; the client may be expecting a regular HTTP proxy.
谢谢各位高手解答
发表于 2011-3-22 18:19:28 | 只看该作者
你代理类型选的是sock5么,浏览器端。
 楼主| 发表于 2011-3-22 19:46:35 | 只看该作者
不太明白什么意思啊 我只是在ie代理那里设置了127.0.0.1:6600@http啊 是不是设置错误
发表于 2011-3-22 19:57:12 | 只看该作者
不支持客户端协议
 楼主| 发表于 2011-3-22 19:58:48 | 只看该作者
这是什么原因造成的啊 是浏览器的事还是怎么回事啊?
发表于 2011-3-22 20:33:14 | 只看该作者
用SOCK5
发表于 2011-3-22 21:03:18 | 只看该作者
原帖由 jason9988 于 2011-3-22 19:46 发表
IE好像是有这个问题,何况你设置HTTP代理肯定错误的,要设置为sock5代理。。。
建议用火狐吧 +个AutoProxy插件。
 楼主| 发表于 2011-3-22 21:08:05 | 只看该作者
火狐已经安装 装的4.0正式版 怎么设置sock5代理呀
发表于 2011-3-22 21:26:17 | 只看该作者
火狐配合AutoProxy使用
发表于 2011-3-22 21:42:29 | 只看该作者
嗯,火狐+SSH不错的……
GMT+8, 2026-4-26 11:36 , Processed in 0.064575 second(s), 10 queries , Gzip On, MemCache On.
