楼主: jiaju99
添加二级域名失败:提示: owned by another user
发表于 2008-10-5 11:19:53 | 只看该作者
When you got this error "Error from domain wrapper: domain.com is owned by another user" when you are trying to add subdomains to one of your cPanel accounts.
This happens when cPanel doesn’t remove the subdomain correctly and then it thinks it’s still there so when you try to add it back on you get an error. Here’s how to fix it:
1. Remove domain.com from /var/cpanel/users/cpanel-username
2. Run /scripts/updateuserdomains as root user on the server because you changed the above file manually, this will create adjusted cache files
3. Remove /var/named/domain.com.db if the file exists (it doesn’t always)
4. Remove the virtualhost for domain.com on /usr/local/apache/conf/httpd.conf
5. Remove domain.com from /etc/named.conf
Now you can add the domain back on in cPanel with no problems..
发表于 2008-10-5 11:20:46 | 只看该作者
只有一个办法了,发ticket/邮件给lunarpages客服要求帮你解决了。
好像cpanel面板都有这个毛病。
 楼主| 发表于 2008-10-5 11:48:20 | 只看该作者
写了:给大家参考
Primary Domain is aneave.com ,the addon domain is jiaju99.com.
I got problem with subdomain addition(e.jiaju99.com) ,
Today I deleted my subdomain e.jiaju99.com through cpanel.
Then I created it over, also from cpanel,I got the message as below :
Sub Domain Maintenance
SubDomain Creation
Error from domain wrapper: e.jiaju99.com is owned by another user.
the subdomain was deleted and the folder was not yet,for I need the folder.
Thank you for your help to solve the problem~~~
yours
wang xiaolong
发表于 2008-10-5 13:35:00 | 只看该作者
回复 13# 的帖子
等回复了,看客服的解决效率了。
持续关注
 楼主| 发表于 2008-10-5 16:42:20 | 只看该作者
yangzhmeishi(16:31:23):
竟然不支持 ~
yangzhmeishi(16:31:40):
Hello,
Currently cpanel does not officially support subdomains for addon domains, however if you previously had this, we can see if it can be readded.
yangzhmeishi(16:31:58):
晕死
yangzhmeishi(16:32:15):
以后不在lunarpages续费了
 楼主| 发表于 2008-10-5 17:05:57 | 只看该作者
I have another try  :  r.jiaju99.com
SubDomain Creation
Bind reloading on ns1 using rndc zone: [jiaju99.com]
Bind reload skipped on good (nameserver disabled)
Bind reloading on ns2 using rndc zone: [jiaju99.com]
The subdomain, r.jiaju99.com has been added.
As if Currently cpanel does support subdomains for addon domains~
I feel confused.....
发表于 2008-10-5 18:10:44 | 只看该作者
回复 15# 的帖子
看来得耐心的跟lunarpages周旋了。
发表于 2008-10-5 18:12:16 | 只看该作者
回复 13# 的帖子
支持的,就是生效慢。
 楼主| 发表于 2008-10-5 18:42:50 | 只看该作者
呵呵,不知道啊,官方说不支持,不会是他们说错了??
20#
发表于 2008-10-5 19:52:24 | 只看该作者
回复 19# 的帖子
看来是他们理解错了吧。
GMT+8, 2026-4-23 13:58 , Processed in 0.062725 second(s), 9 queries , Gzip On, MemCache On.
