查看: 2617|回复: 17
[Windows VPS] 你们的skysilk有出现这样吗
发表于 2019-1-3 04:25:21 来自手机 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
提示
This VPS is running on a node that is experiencing degraded performance, our team is aware of the issue and actively working on a fix. You may experience a reboot of your current running VPS, otherwise, all other services should be nominal. If you have any questions please create a support ticket, thanks for your patience.
发表于 2019-1-3 04:49:27 | 只看该作者
我也这样,但是我开了几十台没有能看网飞的 放弃了
发表于 2019-1-3 04:49:35 | 只看该作者
同样This VPS is running on a node that is experiencing degraded performance, our team is aware of the issue and actively working on a fix. You may experience a reboot of your current running VPS, otherwise, all other services should be nominal. If you have any questions please create a support ticket, thanks for your patience.
 楼主| 发表于 2019-1-3 05:01:56 来自手机 | 只看该作者
62.54可以看啊
发表于 2019-1-3 05:02:56 | 只看该作者
开不出来
发表于 2019-1-3 05:07:32 | 只看该作者
发表于 2019-1-3 07:29:21 | 只看该作者
我还没看,不过看大家这么说,估计也一样了。
发表于 2019-1-3 07:34:06 来自手机 | 只看该作者
正常,机房故障而已,vultr也偶尔会出这种问题
GMT+8, 2026-4-29 19:54 , Processed in 0.070856 second(s), 10 queries , Gzip On, MemCache On.
