查看: 4612|回复: 3
226号母鸡存储出问题了
发表于 2011-3-15 14:09:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
226号母鸡存储出问题了,刚才官方发来了邮件。
看看你的VPS的veid前三位是不是226
  1. Dear BurstNET® Client,
  2. We recently encountered a critical error with the drive array on the server/node hosting your container.
  3. Our engineers have been working on two different fronts to resolve the issue:
  4. First they are restoring your VPS containers (So you will have the same VEID’s and same IP addresses).
  5. We are going to set up for you a new container, on a new server/node, so you can upload any backup of your site you have, and get up and running while we work on recoving the data.
  6. Your username and passwords may change, but you will be given that info when your system goes live again.
  7. You will receive a welcome letter with your new VPS access information.
  8. We expect to have all this completed within the next 4 to 5 hours.
  9. At the same time they are working to restore the data from the drive array.
  10. We still have no firm ETA on when, and if, data will be available, as there is, obviously, HUGE amounts of data to be checked and verified.
  11. Our hope is to have everything completed by 9AM EST on 3-15-2011.
  12. We will update you again once we complete restoring the containers.
发表于 2011-3-15 14:20:42 | 只看该作者
剛剛下載了Backup
发表于 2011-3-15 15:37:50 | 只看该作者
他们也在努力
发表于 2011-3-15 22:14:16 | 只看该作者
还不错,有通知
GMT+8, 2026-4-27 17:44 , Processed in 0.063186 second(s), 9 queries , Gzip On, MemCache On.
