查看: 1764|回复: 7
水一贴,给4核4G水牛跑了个分。。。
发表于 2018-12-2 12:49:32 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
似乎没见到有跑分的帖子,发上来给大家参考一下
不过我看不太懂,也不知道是个啥水平。。。
System: SuperiorSeveral-VM: GNU/Linux
   OS: GNU/Linux -- 3.10.0-862.14.4.el7.x86_64 -- #1 SMP Wed Sep 26 15:12:11 UTC 2018
   Machine: x86_64 (x86_64)
   Language: en_US.utf8 (charmap="UTF-8", collate="UTF-8")
   CPU 0: Intel(R) Xeon(R) CPU E5-2690 v2 @ 3.00GHz (6000.0 bogomips)
          x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET
   CPU 1: Intel(R) Xeon(R) CPU E5-2690 v2 @ 3.00GHz (6000.0 bogomips)
   CPU 2: Intel(R) Xeon(R) CPU E5-2690 v2 @ 3.00GHz (6000.0 bogomips)
   CPU 3: Intel(R) Xeon(R) CPU E5-2690 v2 @ 3.00GHz (6000.0 bogomips)
   20:00:50 up  1:37,  1 user,  load average: 0.00, 0.02, 0.05; runlevel 3
Benchmark Run: Fri Nov 30 2018 20:00:50 - 20:28:55
4 CPUs in system; running 1 parallel copy of tests
Dhrystone 2 using register variables       33112103.0 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     4169.4 MWIPS (9.9 s, 7 samples)
Execl Throughput                               1827.5 lps   (30.0 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        497384.0 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks          132202.1 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks       1265551.0 KBps  (30.0 s, 2 samples)
Pipe Throughput                              716929.0 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                 146876.4 lps   (10.0 s, 7 samples)
Process Creation                               5428.3 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                   4866.2 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                   1841.1 lpm   (60.0 s, 2 samples)
System Call Overhead                         643035.2 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0   33112103.0   2837.4
Double-Precision Whetstone                       55.0       4169.4    758.1
Execl Throughput                                 43.0       1827.5    425.0
File Copy 1024 bufsize 2000 maxblocks          3960.0     497384.0   1256.0
File Copy 256 bufsize 500 maxblocks            1655.0     132202.1    798.8
File Copy 4096 bufsize 8000 maxblocks          5800.0    1265551.0   2182.0
Pipe Throughput                               12440.0     716929.0    576.3
Pipe-based Context Switching                   4000.0     146876.4    367.2
Process Creation                                126.0       5428.3    430.8
Shell Scripts (1 concurrent)                     42.4       4866.2   1147.7
Shell Scripts (8 concurrent)                      6.0       1841.1   3068.4
System Call Overhead                          15000.0     643035.2    428.7
System Benchmarks Index Score                                         898.1
Benchmark Run: Fri Nov 30 2018 20:28:55 - 20:57:05
4 CPUs in system; running 4 parallel copies of tests
Dhrystone 2 using register variables      128803077.0 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                    16365.5 MWIPS (9.8 s, 7 samples)
Execl Throughput                              10335.1 lps   (30.0 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        834688.2 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks          236312.9 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks       2627794.3 KBps  (30.0 s, 2 samples)
Pipe Throughput                             2842857.5 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                 581907.6 lps   (10.0 s, 7 samples)
Process Creation                              29820.1 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                  16544.0 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                   2303.2 lpm   (60.0 s, 2 samples)
System Call Overhead                        2309482.7 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0  128803077.0  11037.1
Double-Precision Whetstone                       55.0      16365.5   2975.6
Execl Throughput                                 43.0      10335.1   2403.5
File Copy 1024 bufsize 2000 maxblocks          3960.0     834688.2   2107.8
File Copy 256 bufsize 500 maxblocks            1655.0     236312.9   1427.9
File Copy 4096 bufsize 8000 maxblocks          5800.0    2627794.3   4530.7
Pipe Throughput                               12440.0    2842857.5   2285.3
Pipe-based Context Switching                   4000.0     581907.6   1454.8
Process Creation                                126.0      29820.1   2366.7
Shell Scripts (1 concurrent)                     42.4      16544.0   3901.9
Shell Scripts (8 concurrent)                      6.0       2303.2   3838.7
System Call Overhead                          15000.0    2309482.7   1539.7
System Benchmarks Index Score                                        2759.9
======= Script description and score comparison completed! =======
发表于 2018-12-2 12:50:17 | 只看该作者
Vir:水牛城滞销,帮帮我!
发表于 2018-12-2 12:50:56 来自手机 | 只看该作者
水牛城都泛滥了……
发表于 2018-12-2 12:53:03 来自手机 | 只看该作者
比我4h8g跑分高
 楼主| 发表于 2018-12-2 12:54:15 | 只看该作者
大佬,4h8g多少分啊
发表于 2018-12-2 13:03:56 | 只看该作者
wkgit 发表于 2018-12-2 12:54
大佬,4h8g多少分啊
https://www.loc.qiche.eu.org/thread-498421-1-1.html
 楼主| 发表于 2018-12-2 13:07:34 | 只看该作者
可能有误差吧,cpu应该都是一样的
GMT+8, 2026-5-1 02:35 , Processed in 0.068816 second(s), 11 queries , Gzip On, MemCache On.
