查看: 2265|回复: 13
88折出一个4核4g40g硬盘大水牛
发表于 2018-12-1 11:14:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
配置如下:
$26.28 /yr
KVM – 10 GIGABIT
WINDOWS 2008 AVAILABLE
4核Intel(R) Xeon(R) CPU E5-2690 v2 @ 3.00GHz cpu,高端大气!不是2.2G的!
4096MB DEDICATED RAM
4x FAIR SHARE CPU vCORE
40GB SSD (RAID 10)
2000GB BANDWIDTH
BUFFALO, NY LOCATION
1 DEDICATED IPv4
机房在纽约,水牛城
2019年以前原价出
2019年以后估计就没人出同款了,有人收的话看情况。。。
除非我自己降价,否则不刀
改邮箱出
发帖较多且qq等级大于两个太阳的大佬要收的话,可以先货
附上测试,看看这个cpu和io,我怎么总感觉可以多买点钱的。。
CPU model            : Intel(R) Xeon(R) CPU E5-2690 v2 @ 3.00GHz
Number of cores      : 4
CPU frequency        : 2999.998 MHz
Total size of Disk   : 40.0 GB (1.4 GB Used)
Total amount of Mem  : 3789 MB (105 MB Used)
Total amount of Swap : 255 MB (0 MB Used)
System uptime        : 0 days, 0 hour 5 min
Load average         : 0.05, 0.05, 0.03
OS                   : CentOS 7.5.1804
Arch                 : x86_64 (64 Bit)
Kernel               : 3.10.0-862.14.4.el7.x86_64
I/O speed(1st run)   : 658 MB/s
I/O speed(2nd run)   : 630 MB/s
I/O speed(3rd run)   : 639 MB/s
Average I/O speed    : 642.3 MB/s
Node Name                       IPv4 address            Download Speed
CacheFly                        205.234.175.175         81.6MB/s
Linode, Tokyo, JP               106.187.96.148          12.7MB/s
Linode, Singapore, SG           139.162.23.4            9.85MB/s
Linode, London, UK              176.58.107.39           27.3MB/s
Linode, Frankfurt, DE           139.162.130.8           20.3MB/s
Linode, Fremont, CA             50.116.14.9             29.7MB/s
Softlayer, Dallas, TX           173.192.68.18           35.9MB/s
Softlayer, Seattle, WA          67.228.112.250          18.9MB/s
Softlayer, Frankfurt, DE        159.122.69.4            9.00MB/s
Softlayer, Singapore, SG        119.81.28.170           6.02MB/s
Softlayer, HongKong, CN         119.81.130.170          7.19MB/s
跑了个分,虽然看不太懂,但还是分享给大家做个参考:
System: SuperiorSeveral-VM: GNU/Linux
   OS: GNU/Linux -- 3.10.0-862.14.4.el7.x86_64 -- #1 SMP Wed Sep 26 15:12:11 UTC 2018
   Machine: x86_64 (x86_64)
   Language: en_US.utf8 (charmap="UTF-8", collate="UTF-8")
   CPU 0: Intel(R) Xeon(R) CPU E5-2690 v2 @ 3.00GHz (6000.0 bogomips)
          x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET
   CPU 1: Intel(R) Xeon(R) CPU E5-2690 v2 @ 3.00GHz (6000.0 bogomips)
   CPU 2: Intel(R) Xeon(R) CPU E5-2690 v2 @ 3.00GHz (6000.0 bogomips)
   CPU 3: Intel(R) Xeon(R) CPU E5-2690 v2 @ 3.00GHz (6000.0 bogomips)
   20:00:50 up  1:37,  1 user,  load average: 0.00, 0.02, 0.05; runlevel 3
Benchmark Run: Fri Nov 30 2018 20:00:50 - 20:28:55
4 CPUs in system; running 1 parallel copy of tests
Dhrystone 2 using register variables       33112103.0 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     4169.4 MWIPS (9.9 s, 7 samples)
Execl Throughput                               1827.5 lps   (30.0 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        497384.0 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks          132202.1 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks       1265551.0 KBps  (30.0 s, 2 samples)
Pipe Throughput                              716929.0 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                 146876.4 lps   (10.0 s, 7 samples)
Process Creation                               5428.3 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                   4866.2 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                   1841.1 lpm   (60.0 s, 2 samples)
System Call Overhead                         643035.2 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0   33112103.0   2837.4
Double-Precision Whetstone                       55.0       4169.4    758.1
Execl Throughput                                 43.0       1827.5    425.0
File Copy 1024 bufsize 2000 maxblocks          3960.0     497384.0   1256.0
File Copy 256 bufsize 500 maxblocks            1655.0     132202.1    798.8
File Copy 4096 bufsize 8000 maxblocks          5800.0    1265551.0   2182.0
Pipe Throughput                               12440.0     716929.0    576.3
Pipe-based Context Switching                   4000.0     146876.4    367.2
Process Creation                                126.0       5428.3    430.8
Shell Scripts (1 concurrent)                     42.4       4866.2   1147.7
Shell Scripts (8 concurrent)                      6.0       1841.1   3068.4
System Call Overhead                          15000.0     643035.2    428.7
System Benchmarks Index Score                                         898.1
Benchmark Run: Fri Nov 30 2018 20:28:55 - 20:57:05
4 CPUs in system; running 4 parallel copies of tests
Dhrystone 2 using register variables      128803077.0 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                    16365.5 MWIPS (9.8 s, 7 samples)
Execl Throughput                              10335.1 lps   (30.0 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        834688.2 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks          236312.9 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks       2627794.3 KBps  (30.0 s, 2 samples)
Pipe Throughput                             2842857.5 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                 581907.6 lps   (10.0 s, 7 samples)
Process Creation                              29820.1 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                  16544.0 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                   2303.2 lpm   (60.0 s, 2 samples)
System Call Overhead                        2309482.7 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0  128803077.0  11037.1
Double-Precision Whetstone                       55.0      16365.5   2975.6
Execl Throughput                                 43.0      10335.1   2403.5
File Copy 1024 bufsize 2000 maxblocks          3960.0     834688.2   2107.8
File Copy 256 bufsize 500 maxblocks            1655.0     236312.9   1427.9
File Copy 4096 bufsize 8000 maxblocks          5800.0    2627794.3   4530.7
Pipe Throughput                               12440.0    2842857.5   2285.3
Pipe-based Context Switching                   4000.0     581907.6   1454.8
Process Creation                                126.0      29820.1   2366.7
Shell Scripts (1 concurrent)                     42.4      16544.0   3901.9
Shell Scripts (8 concurrent)                      6.0       2303.2   3838.7
System Call Overhead                          15000.0    2309482.7   1539.7
System Benchmarks Index Score                                        2759.9
======= Script description and score comparison completed! =======
发表于 2018-12-1 11:17:31 | 只看该作者
有个性,支持
发表于 2018-12-1 11:18:29 | 只看该作者
搭楼同出
3核
6G
45G SSD
2T
水牛城,10G口
可win
年付25刀
250出,账号里面还有点aff
发表于 2018-12-1 11:19:53 | 只看该作者
有一丝丝 心动,可惜钱包不支持
发表于 2018-12-1 11:44:10 | 只看该作者
借楼出Virmach亚特兰大年付18.05刀,2核6.5G内存10G硬盘2T流量。110元。
发表于 2018-12-1 11:46:43 | 只看该作者
出同款,所有时间节点折扣和楼主一样
发表于 2018-12-1 11:58:32 来自手机 | 只看该作者
cigar2010 发表于 2018-12-1 11:46
出同款,所有时间节点折扣和楼主一样
150,出不,能出我接盘
发表于 2018-12-1 12:00:55 | 只看该作者
150块 我也要 哈哈
GMT+8, 2026-4-30 07:48 , Processed in 0.063531 second(s), 10 queries , Gzip On, MemCache On.
