查看: 1983|回复: 4
又一条可能的赚钱之道:举报Cookie-stuffing(cs)
发表于 2018-11-30 20:12:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
类似王海打假,在aff界来一场cs打假如何?能否赚一波?
瓦工的tos中明确写明了禁止Cookie-stuffing,mjj们是不是可以逛逛各大aff站点,举报或要挟一通,保证大有收获
不知瓦工是否能给举报人奖励,这可是可以省一大笔钱啊
附:瓦工tos中aff条款
Affiliate program
You may use URL shortening or URL masking techniques to hide the full affiliate link, however, your users must follow the link naturally and not as the result of confusing/misleading information.
Affiliate links must be followed naturally by visitors via a website. We may request to review websites where our links are used to make sure they comply with our policies; inability to verify source of visitors may result in refusal of your request to withdraw funds.
The following practices are strictly forbidden and will result in a permanent ban from our affiliate program:
Cookie-stuffing (loading affiliate links by using an invisible image) and similar techniques
Any activity that results in artificial increase of visitors to our affiliate links including, but not limited to click/pageview exchange services
Mentioning our affiliate links in any type of unsolicited communication (be it email/forum posting/private messaging/instant messaging).
Using affiliate links to order service for yourself or your family, or on behalf of someone else.
Violation of the Affiliate program rules will lead to inability to withdraw any funds.
Commission withdrawals for amounts under $1000 are provided via Paypal. For amounts over $1000 we may either make a payout via paypal (based on funds availability), or via wire transfer.
Note that certain plans developed in collaboration with our partners do not qualify for affiliate commissions. Such plans can be recognized by partner name in the plan name (for example, "91yun 2017 special" plan etc).
谷歌翻译:
联盟计划
您可以使用URL缩短或URL屏蔽技术来隐藏完整的会员链接,但是,您的用户必须自然地遵循链接,而不是混淆/误导信息的结果。
访问者必须通过网站自然遵循联盟链接。我们可能会要求审查使用我们链接的网站,以确保它们符合我们的政策;无法核实访客来源可能会导致您拒绝提取资金的请求。
以下做法是严格禁止的,将导致我们的联盟计划永久禁止:
Cookie填充(使用不可见图像加载会员链接)和类似技术
任何导致我们的联盟链接的访问者人为增加的活动,包括但不限于点击/网页浏览交换服务
在任何类型的未经请求的通信中提及我们的会员链接(无论是电子邮件/论坛发布/私人消息/即时消息)。
使用会员链接为自己或家人或代表其他人订购服务。
违反联盟计划规则将导致无法提取任何资金。
通过Paypal提供1000美元以下金额的佣金提款。对于超过1000美元的金额,我们可以通过paypal(基于资金可用性)或通过电汇进行支付。
请注意,与我们的合作伙伴合作开发的某些计划不符合联盟佣金的条件。此类计划可以通过计划名称中的合作伙伴名称进行识别(例如,“91yun 2017 special”计划等)。
发表于 2018-11-30 22:29:24 来自手机 | 只看该作者
搞cs主机测评被骂 vc大佬一堆人夸 这是一件事 两个标准 搞不明白 谁对谁错
发表于 2018-11-30 22:27:59 来自手机 | 只看该作者
 楼主| 发表于 2018-11-30 22:17:29 | 只看该作者
各位affman注意了,在论坛发aff链接也是禁止的,会导致所有累计的、可循环的aff灰飞烟灭啊
发表于 2018-11-30 21:16:27 | 只看该作者
搬瓦工还给91开特殊计划了?
GMT+8, 2026-5-4 00:37 , Processed in 0.060444 second(s), 11 queries , Gzip On, MemCache On.
