查看: 2727|回复: 6
[不限流量] Virmach订单一直被Cancelled,请问怎么解决
发表于 2018-11-26 22:36:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Oops, there's a problem...
Order Failed
I'm sorry but we cannot current accept your order automatically through our system due to billing issues.
If you feel you have received this message in error, then please accept our apologies and view the support ticket generated for this order. Thank you.
We apologize, but your recent order did not pass our automated anti-fraud measures. Please read this message fully for assistance in completing your order, so you can avoid some common mistakes that would result in your order not being processed by our system. If you have any questions, please respond to this ticket. Please do not re-order without resolving one of these "common errors" or contacting us first.
This message is related to order #225590
Issues You May Be Facing
You appear to be masking your IP.
Our system shows that you may be masking your residential IP address by using services from Tencent cloud computing. We require this to properly process payments and avoid fraudulent payments. Please turn your proxy/扶墙 off if possible, or provide a photo ID to verify your identity & billing address. If you're not using a proxy or 扶墙, please send us a copy of your internet bill. We do respect your privacy, so if you want to mask your IP address and do not want to provide documentation, you can contact us to make a deposit using Bitcoin instead.
You have entered your address incorrectly.
If you're not travelling, and are not masking your IP address, have you made sure your address is correct in our system? A quick way of ensuring you entered your address correctly is copying your address on file with us, and pasting it on a service such as Google Maps. If there's an error looking up the address, chances are that you have inputted your address incorrectly which causes an error in our system. To complete your order, rectify the error and place a new order.
Is our system making a mistake?
This is completely possible. If you believe that our system is cancelling your order in error, please reply to this ticket with more information. We do apologize for the inconvenience, but sometimes our automated system does make mistakes. In these cases, one of our support agents can step in and make sure you can complete your order.
选择PayPal支付方式,就这样提示了。
发表于 2018-11-26 22:38:10 来自手机 | 只看该作者
不要挂代理
发表于 2018-11-26 22:39:14 来自手机 | 只看该作者
关掉代理,使用与账单地址一致的ip 重新下单
 楼主| 发表于 2018-11-26 23:13:35 | 只看该作者
@nosec
@sina
没有用代理,账单地址是一致的,我用的拼音,是不是要中文呢?
 楼主| 发表于 2018-11-26 23:20:30 | 只看该作者
我地址改成中文,付款成功。
发表于 2018-11-26 23:20:48 | 只看该作者
也可能你这个ip刷新virmach网页次数太多了 或者由于别的原因进黑名单了
重启路由器换个ip试试看
 楼主| 发表于 2018-11-26 23:26:08 | 只看该作者
重启路由器换个ip试试看 ...
谢谢。
账单地址改成中文就ok了
GMT+8, 2026-4-14 10:42 , Processed in 0.062146 second(s), 10 queries , Gzip On, MemCache On.
