查看: 1579|回复: 1
[疑问] 25刀UnixBench跑分
发表于 2018-11-26 18:35:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
   Version 5.1.3                      Based on the Byte Magazine Unix Benchmark
   Multi-CPU version                  Version 5 revisions by Ian Smith,
                                      Sunnyvale, CA, USA
   January 13, 2011                   johantheghost at yahoo period com
1 x Dhrystone 2 using register variables  1 2 3 4 5 6 7 8 9 10
1 x Double-Precision Whetstone  1 2 3 4 5 6 7 8 9 10
1 x Execl Throughput  1 2 3
1 x File Copy 1024 bufsize 2000 maxblocks  1 2 3
1 x File Copy 256 bufsize 500 maxblocks  1 2 3
1 x File Copy 4096 bufsize 8000 maxblocks  1 2 3
1 x Pipe Throughput  1 2 3 4 5 6 7 8 9 10
1 x Pipe-based Context Switching  1 2 3 4 5 6 7 8 9 10
1 x Process Creation  1 2 3
1 x System Call Overhead  1 2 3 4 5 6 7 8 9 10
1 x Shell Scripts (1 concurrent)  1 2 3
1 x Shell Scripts (8 concurrent)  1 2 3
4 x Dhrystone 2 using register variables  1 2 3 4 5 6 7 8 9 10
4 x Double-Precision Whetstone  1 2 3 4 5 6 7 8 9 10
4 x Execl Throughput  1 2 3
4 x File Copy 1024 bufsize 2000 maxblocks  1 2 3
4 x File Copy 256 bufsize 500 maxblocks  1 2 3
4 x File Copy 4096 bufsize 8000 maxblocks  1 2 3
4 x Pipe Throughput  1 2 3 4 5 6 7 8 9 10
4 x Pipe-based Context Switching  1 2 3 4 5 6 7 8 9 10
4 x Process Creation  1 2 3
4 x System Call Overhead  1 2 3 4 5 6 7 8 9 10
4 x Shell Scripts (1 concurrent)  1 2 3
4 x Shell Scripts (8 concurrent)  1
2 3
   BYTE UNIX Benchmarks (Version 5.1.3)
   System: SteelblueWatchful-VM: GNU/Linux
   OS: GNU/Linux -- 3.10.0-862.14.4.el7.x86_64 -- #1 SMP Wed Sep 26 15:12:11 UTC 2018
   Machine: x86_64 (x86_64)
   Language: en_US.utf8 (charmap="UTF-8", collate="UTF-8")
   CPU 0: QEMU Virtual CPU version (cpu64-rhel6) (6000.0 bogomips)
          x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET
   CPU 1: QEMU Virtual CPU version (cpu64-rhel6) (6000.0 bogomips)
   CPU 2: QEMU Virtual CPU version (cpu64-rhel6) (6000.0 bogomips)
   CPU 3: QEMU Virtual CPU version (cpu64-rhel6) (6000.0 bogomips)
   17:28:54 up 44 min,  1 user,  load average: 0.08, 0.35, 0.53; runlevel 3
Benchmark Run: Mon Nov 26 2018 17:28:54 - 17:57:00
4 CPUs in system; running 1 parallel copy of tests
Dhrystone 2 using register variables       33135598.7 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     4178.8 MWIPS (9.9 s, 7 samples)
Execl Throughput                               1788.5 lps   (30.0 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        276782.2 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks           72740.5 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks        902700.5 KBps  (30.0 s, 2 samples)
Pipe Throughput                              417238.7 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                 117789.7 lps   (10.0 s, 7 samples)
Process Creation                               5879.5 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                   4841.9 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                   1764.2 lpm   (60.0 s, 2 samples)
System Call Overhead                         364011.2 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0   33135598.7   2839.4
Double-Precision Whetstone                       55.0       4178.8    759.8
Execl Throughput                                 43.0       1788.5    415.9
File Copy 1024 bufsize 2000 maxblocks          3960.0     276782.2    698.9
File Copy 256 bufsize 500 maxblocks            1655.0      72740.5    439.5
File Copy 4096 bufsize 8000 maxblocks          5800.0     902700.5   1556.4
Pipe Throughput                               12440.0     417238.7    335.4
Pipe-based Context Switching                   4000.0     117789.7    294.5
Process Creation                                126.0       5879.5    466.6
Shell Scripts (1 concurrent)                     42.4       4841.9   1142.0
Shell Scripts (8 concurrent)                      6.0       1764.2   2940.3
System Call Overhead                          15000.0     364011.2    242.7
System Benchmarks Index Score                                         708.9
Benchmark Run: Mon Nov 26 2018 17:57:00 - 18:25:09
4 CPUs in system; running 4 parallel copies of tests
Dhrystone 2 using register variables      130800937.9 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                    16760.9 MWIPS (9.9 s, 7 samples)
Execl Throughput                               8961.3 lps   (30.0 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        572573.3 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks          151797.3 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks       2074209.0 KBps  (30.0 s, 2 samples)
Pipe Throughput                             1614398.9 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                 451224.2 lps   (10.0 s, 7 samples)
Process Creation                              26267.3 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                  14794.9 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                   2003.8 lpm   (60.0 s, 2 samples)
System Call Overhead                        1278013.0 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0  130800937.9  11208.3
Double-Precision Whetstone                       55.0      16760.9   3047.4
Execl Throughput                                 43.0       8961.3   2084.0
File Copy 1024 bufsize 2000 maxblocks          3960.0     572573.3   1445.9
File Copy 256 bufsize 500 maxblocks            1655.0     151797.3    917.2
File Copy 4096 bufsize 8000 maxblocks          5800.0    2074209.0   3576.2
Pipe Throughput                               12440.0    1614398.9   1297.7
Pipe-based Context Switching                   4000.0     451224.2   1128.1
Process Creation                                126.0      26267.3   2084.7
Shell Scripts (1 concurrent)                     42.4      14794.9   3489.4
Shell Scripts (8 concurrent)                      6.0       2003.8   3339.7
System Call Overhead                          15000.0    1278013.0    852.0
System Benchmarks Index Score                                        2158.5
发表于 2018-11-26 18:57:47 | 只看该作者
听说这个测试对ovz更友好,我记得我有个OVZ小鸡可以跑1000/4000的分
GMT+8, 2026-4-23 20:30 , Processed in 0.057954 second(s), 9 queries , Gzip On, MemCache On.
