查看: 5688|回复: 27
[不限流量] 上了良心云的车(补跑分截图)
发表于 2018-10-18 13:34:35 来自手机 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
上了良心云的车,2h8g5m1449  发现并没有什么卵用,幸亏用的新QQ号买的,过后还指望卖掉
补了个跑分,我不懂是网上一键的你们看看把
QQ图片20181019082629.png (97.45 KB, 下载次数: 2) QQ图片20181019082641.png (113.23 KB, 下载次数: 2)
   BYTE UNIX Benchmarks (Version 5.1.3)
   System: VM_0_11_centos: GNU/Linux
   OS: GNU/Linux -- 3.10.0-862.el7.x86_64 -- #1 SMP Fri Apr 20 16:44:24 UTC 2018
   Machine: x86_64 (x86_64)
   Language: en_US.utf8 (charmap="UTF-8", collate="UTF-8")
   CPU 0: Intel(R) Xeon(R) CPU E5-26xx v4 (4788.9 bogomips)
          Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET
   CPU 1: Intel(R) Xeon(R) CPU E5-26xx v4 (4788.9 bogomips)
   07:28:04 up  5:14,  2 users,  load average: 0.22, 0.06, 0.06; runlevel 3
Benchmark Run: Fri Oct 19 2018 07:28:04 - 07:56:48
2 CPUs in system; running 1 parallel copy of tests
Dhrystone 2 using register variables       34113571.2 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     3735.7 MWIPS (13.6 s, 7 samples)
Execl Throughput                               3132.5 lps   (30.0 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        603357.6 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks          157228.6 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks       1869097.1 KBps  (30.0 s, 2 samples)
Pipe Throughput                              845757.8 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                 180070.1 lps   (10.0 s, 7 samples)
Process Creation                               8736.4 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                   6583.9 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                   1348.1 lpm   (60.0 s, 2 samples)
System Call Overhead                         832497.6 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0   34113571.2   2923.2
Double-Precision Whetstone                       55.0       3735.7    679.2
Execl Throughput                                 43.0       3132.5    728.5
File Copy 1024 bufsize 2000 maxblocks          3960.0     603357.6   1523.6
File Copy 256 bufsize 500 maxblocks            1655.0     157228.6    950.0
File Copy 4096 bufsize 8000 maxblocks          5800.0    1869097.1   3222.6
Pipe Throughput                               12440.0     845757.8    679.9
Pipe-based Context Switching                   4000.0     180070.1    450.2
Process Creation                                126.0       8736.4    693.4
Shell Scripts (1 concurrent)                     42.4       6583.9   1552.8
Shell Scripts (8 concurrent)                      6.0       1348.1   2246.8
System Call Overhead                          15000.0     832497.6    555.0
System Benchmarks Index Score                                        1088.7
Benchmark Run: Fri Oct 19 2018 07:56:48 - 08:25:32
2 CPUs in system; running 2 parallel copies of tests
Dhrystone 2 using register variables       67791254.4 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     7462.0 MWIPS (13.6 s, 7 samples)
Execl Throughput                               6526.2 lps   (30.0 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks       1039736.7 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks          278244.9 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks       3242825.4 KBps  (30.0 s, 2 samples)
Pipe Throughput                             1678546.0 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                 347775.7 lps   (10.0 s, 7 samples)
Process Creation                              21165.7 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                   9944.3 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                   1377.4 lpm   (60.0 s, 2 samples)
System Call Overhead                        1504074.4 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0   67791254.4   5809.0
Double-Precision Whetstone                       55.0       7462.0   1356.7
Execl Throughput                                 43.0       6526.2   1517.7
File Copy 1024 bufsize 2000 maxblocks          3960.0    1039736.7   2625.6
File Copy 256 bufsize 500 maxblocks            1655.0     278244.9   1681.2
File Copy 4096 bufsize 8000 maxblocks          5800.0    3242825.4   5591.1
Pipe Throughput                               12440.0    1678546.0   1349.3
Pipe-based Context Switching                   4000.0     347775.7    869.4
Process Creation                                126.0      21165.7   1679.8
Shell Scripts (1 concurrent)                     42.4       9944.3   2345.3
Shell Scripts (8 concurrent)                      6.0       1377.4   2295.7
System Call Overhead                          15000.0    1504074.4   1002.7
System Benchmarks Index Score                                        1956.2
发表于 2018-10-18 13:35:45 | 只看该作者
价格真的很好.这要是阿里云这配置不得 3500/年 ?
 楼主| 发表于 2018-10-18 13:37:00 来自手机 | 只看该作者
不指望,挣钱只求回本,买来新鲜新鲜。。本人没有项目。过了新鲜劲就没啦。。。
发表于 2018-10-18 13:37:57 | 只看该作者
土豪,真土豪
紫薯布丁
发表于 2018-10-18 13:56:55 | 只看该作者
都是大佬哦,有钱的世界看不懂了
发表于 2018-10-18 13:58:44 | 只看该作者
都是冲动消费,又没需求。。
发表于 2018-10-18 14:01:50 | 只看该作者
发表于 2018-10-18 14:07:31 | 只看该作者
冲动是魔鬼
发表于 2018-10-18 14:21:39 | 只看该作者
先自己爽下吧,过段时间再出掉
GMT+8, 2026-4-14 13:07 , Processed in 0.076162 second(s), 10 queries , Gzip On, MemCache On.
