查看: 2761|回复: 9
[美国VPS] 开通快一个月才知道 10O开到钻石盘了?
发表于 2018-10-14 14:32:01 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Register values returned from SMART Status command are:
ERR=0x00, SC=0x00, LL=0x00, LM=0x00, LH=0x00, DEV=0x00, STS=0x00
SMART Status not supported: Invalid ATA output register values
SMART overall-health self-assessment test result: PASSED
Warning: This result is based on an Attribute check.
General SMART Values:
Offline data collection status:  (0x84)        Offline data collection activity
                                        was suspended by an interrupting command from host.
                                        Auto Offline Data Collection: Enabled.
Self-test execution status:      (   0)        The previous self-test routine completed
                                        without error or no self-test has ever
                                        been run.
Total time to complete Offline
data collection:                 (16200) seconds.
capabilities:                          (0x7b) SMART execute Offline immediate.
                                        Auto Offline data collection on/off support.
                                        Suspend Offline collection upon new
                                        command.
                                        Offline surface scan supported.
                                        Self-test supported.
                                        Conveyance Self-test supported.
                                        Selective Self-test supported.
SMART capabilities:            (0x0003)        Saves SMART data before entering
                                        power-saving mode.
                                        Supports SMART auto save timer.
Error logging capability:        (0x01)        Error logging supported.
                                        General Purpose Logging supported.
Short self-test routine
recommended polling time:          (   2) minutes.
Extended self-test routine
recommended polling time:          ( 167) minutes.
Conveyance self-test routine
recommended polling time:          (   5) minutes.
SCT capabilities:                (0x303f)        SCT Status supported.
                                        SCT Error Recovery Control supported.
                                        SCT Feature Control supported.
                                        SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   172   171   021    Pre-fail  Always       -       4375
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       27
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   009   009   000    Old_age   Always       -       66928
10 Spin_Retry_Count        0x0032   100   253   000    Old_age   Always       -       0
11 Calibration_Retry_Count 0x0032   100   253   000    Old_age   Always       -       0
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       25
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       24
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       2
194 Temperature_Celsius     0x0022   118   103   000    Old_age   Always       -       29 (Min/Max 29/32)
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   200   200   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       0
问题来了,吊大的指导下,怎么换个新硬盘?
发表于 2018-10-14 14:34:30 | 只看该作者
除非完全挂了,否则别想换硬盘了
发表于 2018-10-14 14:41:51 来自手机 | 只看该作者
IO多少?我的6w5的盘,raid 0能到240-250
 楼主| 发表于 2018-10-14 14:52:31 | 只看该作者
root@sd-28457:/home/root# hdparm -t --direct /dev/sda1
/dev/sda1:
Timing O_DIRECT disk reads: 198 MB in  0.76 seconds = 258.94 MB/sec
发表于 2018-10-15 09:12:40 | 只看该作者
/dev/sda1:
那还叫啥钻石盘?钻石盘都是IO 10左右的
发表于 2018-10-15 09:46:49 | 只看该作者
我的10欧只能做raid 1,等于1tb,有个硬盘有坏道,哭了
发表于 2018-10-15 14:07:00 | 只看该作者
表示有点看不懂,能解释一下吗老板
 楼主| 发表于 2018-10-15 18:36:52 | 只看该作者
通电8年的不算钻石盘?
发表于 2018-10-15 19:00:07 | 只看该作者
饺子同学 发表于 2018-10-15 18:36
通电8年的不算钻石盘?
正是壮年
GMT+8, 2026-4-24 00:19 , Processed in 0.063628 second(s), 10 queries , Gzip On, MemCache On.
