查看: 1812|回复: 1
[疑问] 刚禁止ping一会就给我抢修了。。。
发表于 2018-10-11 18:00:39 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
刚刚把服务器禁止ping,过了一会就登录不上去了,看了下邮箱直接给我抢修了,这么溜的吗。。。
Dear Customer,
The intervention on ns*******.ip-*-**-**.eu has been completed.
This operation was closed at 2018-10-11 11:20:58 CEST (UTC +02:00)
Here are the details of this operation:
Diagnosis interface boot (rescue)
Date 2018-10-11 11:14:30 CEST (UTC +02:00), antoine L made Diagnosis interface boot (rescue):
Here are the details of the operation performed:
The server has started (login is requested on the screen) but inaccessible
by the network (not pinging).
A restart on the OVH Kernel ('netboot') does not correct the
problem.
Actions:
Rebooting the server to rescue mode (Linux)
result:
Boot OK. Rescue mode accessible.
recommendations:
Software configuration to be corrected by customer
If you need any further information regarding this intervention, please do not hesitate to contact our technical support.
Best regards,
Dear Customer,
The intervention on ns******.ip-*-**-**.eu has been completed.
problem.
Actions:
result:
recommendations:
SAS OVH - https://www.kimsufi.com/en/
2 rue Kellermann
BP 80157
59100 Roubaix
Dear Customer,
Your server has been started in 'Rescue' mode. This has either been requested by you in the OVH manager or a technician has had to do this because of an error that needs to be resolved in Rescue mode.
This mode means that a basic Linux/BSD system has been launched on your server through the network. This is not the system installed on your server.
A web interface is available for you to carry out diagnosis on your server (hard disk, raid, ram, CPU) and to browse your file systems using the following details:
  - https://*.**.**.***:444
  - user: ****
  - password: ************
You may connect to your server through SSH with the following details:
  - IP: *.**.**.***
  - user: ****
    Password:   ****
You can now carry out the maintenance required to the repair your server.
For example, you can:
        - check and update your network configuration files,
        - check and decontaminate your firewall if required,
        - check and update your GRUB (or to configure another Netboot via the network)
        - launch a manual check of your file systems,
        - carry out backup or restoration of data,
        - etc.
If you think you have identified and fixed the problem and wish to boot from
the OS installed in your server, you must configure the 'Netboot' in the OVH Manager to the HD or to an OVH-certified kernel:   http://help.ovh.ie/KernelNetboot
You may then soft-reboot your server (avoid reboots via Manager).
For further information, check our guide:
http://help.ovh.ie/RescueMode
Best regards,
这是诊断的网站
禁止ping都不可以的吗
发表于 2018-10-11 18:03:46 | 只看该作者
那就关闭监控,ping不通检测是否机器挂了,这是最快,最简单的做法了。
GMT+8, 2026-4-28 05:32 , Processed in 0.066691 second(s), 10 queries , Gzip On, MemCache On.
