查看: 1638|回复: 0
whmcs群发邮件报错请教
发表于 2018-9-11 15:28:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
如题whmcs群发邮件报错,报错如下希望有大佬指点一下。正常发邮件并没有问题
exception 'PDOException' with message 'SQLSTATE[42S22]: Column not found: 1054 Unknown column 'blindcopyto' in 'field list'' in /www/wwwroot/***.****.com/vendor/illuminate/database/Connection.php:441
Stack trace:
#0 /www/wwwroot/***.****.com/vendor/illuminate/database/Connection.php(441): PDO->prepare('insert into `tb...')
#1 /www/wwwroot/***.****.com/vendor/illuminate/database/Connection.php(706): Illuminate\Database\Connection->Illuminate\Database\{closure}(Object(Illuminate\Database\MySqlConnection), 'insert into `tb...', Array)
#2 /www/wwwroot/***.****.com/vendor/illuminate/database/Connection.php(669): Illuminate\Database\Connection->runQueryCallback('insert into `tb...', Array, Object(Closure))
#3 /www/wwwroot/***.****.com/vendor/illuminate/database/Connection.php(442): Illuminate\Database\Connection->run('insert into `tb...', Array, Object(Closure))
#4 /www/wwwroot/***.****.com/vendor/illuminate/database/Connection.php(398): Illuminate\Database\Connection->statement('insert into `tb...', Array)
#5 /www/wwwroot/***.****.com/vendor/illuminate/database/Query/Processors/Processor.php(32): Illuminate\Database\Connection->insert('insert into `tb...', Array)
#6 /www/wwwroot/***.****.com/vendor/illuminate/database/Query/Builder.php(2055): Illuminate\Database\Query\Processors\Processor->processInsertGetId(Object(Illuminate\Database\Query\Builder), 'insert into `tb...', Array, 'id')
#7 [internal function]: Illuminate\Database\Query\Builder->insertGetId(Array, 'id')
#8 /www/wwwroot/***.****.com/vendor/illuminate/database/Eloquent/Builder.php(1382): call_user_func_array(Array, Array)
#9 /www/wwwroot/***.****.com/vendor/illuminate/database/Eloquent/Model.php(1617): Illuminate\Database\Eloquent\Builder->__call('insertGetId', Array)
#10 /www/wwwroot/***.****.com/vendor/illuminate/database/Eloquent/Model.php(1617): Illuminate\Database\Eloquent\Builder->insertGetId(Array, 'id')
#11 /www/wwwroot/***.****.com/vendor/illuminate/database/Eloquent/Model.php(1586): Illuminate\Database\Eloquent\Model->insertAndSetId(Object(Illuminate\Database\Eloquent\Builder), Array)
#12 /www/wwwroot/***.****.com/vendor/illuminate/database/Eloquent/Model.php(1477): Illuminate\Database\Eloquent\Model->performInsert(Object(Illuminate\Database\Eloquent\Builder), Array)
#13 /www/wwwroot/***.****.com/admin/sendmessage.php(0): Illuminate\Database\Eloquent\Model->save()
#14 {main}
Next exception 'Illuminate\Database\QueryException' with message 'SQLSTATE[42S22]: Column not found: 1054 Unknown column 'blindcopyto' in 'field list' (SQL: insert into `tblemailtemplates` (`type`, `name`, `subject`, `message`, `fromname`, `fromemail`, `copyto`, `blindcopyto`, `updated_at`, `created_at`) values (product, Mass Mail Template,邮件标题,
邮件内容
, ******, smtp邮箱, , , 2018-09-11 15:18:30, 2018-09-11 15:18:30))' in /www/wwwroot/***.****.com/vendor/illuminate/database/Connection.php:713
Stack trace:
#0 /www/wwwroot/***.****.com/vendor/illuminate/database/Connection.php(669): Illuminate\Database\Connection->runQueryCallback('insert into `tb...', Array, Object(Closure))
#1 /www/wwwroot/***.****.com/vendor/illuminate/database/Connection.php(442): Illuminate\Database\Connection->run('insert into `tb...', Array, Object(Closure))
#2 /www/wwwroot/***.****.com/vendor/illuminate/database/Connection.php(398): Illuminate\Database\Connection->statement('insert into `tb...', Array)
#3 /www/wwwroot/***.****.com/vendor/illuminate/database/Query/Processors/Processor.php(32): Illuminate\Database\Connection->insert('insert into `tb...', Array)
#4 /www/wwwroot/***.****.com/vendor/illuminate/database/Query/Builder.php(2055): Illuminate\Database\Query\Processors\Processor->processInsertGetId(Object(Illuminate\Database\Query\Builder), 'insert into `tb...', Array, 'id')
#5 [internal function]: Illuminate\Database\Query\Builder->insertGetId(Array, 'id')
#6 /www/wwwroot/***.****.com/vendor/illuminate/database/Eloquent/Builder.php(1382): call_user_func_array(Array, Array)
#7 /www/wwwroot/***.****.com/vendor/illuminate/database/Eloquent/Model.php(1617): Illuminate\Database\Eloquent\Builder->__call('insertGetId', Array)
#8 /www/wwwroot/***.****.com/vendor/illuminate/database/Eloquent/Model.php(1617): Illuminate\Database\Eloquent\Builder->insertGetId(Array, 'id')
#9 /www/wwwroot/***.****.com/vendor/illuminate/database/Eloquent/Model.php(1586): Illuminate\Database\Eloquent\Model->insertAndSetId(Object(Illuminate\Database\Eloquent\Builder), Array)
#10 /www/wwwroot/***.****.com/vendor/illuminate/database/Eloquent/Model.php(1477): Illuminate\Database\Eloquent\Model->performInsert(Object(Illuminate\Database\Eloquent\Builder), Array)
#11 /www/wwwroot/***.****.com/admin/sendmessage.php(0): Illuminate\Database\Eloquent\Model->save()
#12 {main}
GMT+8, 2026-4-16 00:49 , Processed in 0.062688 second(s), 9 queries , Gzip On, MemCache On.
