查看: 5502|回复: 21
hiformance新开出来的7.5刀款硬盘惨不忍睹
发表于 2018-9-11 11:46:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
10GB变成2.5
Superbench.sh -- https://www.oldking.net/350.html
Mode  : Standard    Version : 1.1.1
Usage : wget -qO- git.io/superbench.sh | bash
CPU Model            : QEMU Virtual CPU version (cpu64-rhel6)
CPU Cores            : 1 Cores @ 3695.998 MHz x86_64
CPU Cache            : 4096 KB
OS                   : Debian GNU/Linux 9 (64 Bit) KVM
Kernel               : 4.9.0-4-amd64
Total Space          : 2.5 GB (0.9 GB Used)
Total RAM            : 492 MB (31 MB Used 262 MB Buff)
Total SWAP           : 511 MB (0 MB Used)
Uptime               : 0 days 0 hour 20 min
Load average         : 1.06, 1.09, 0.80
ASN & ISP            : AS8100, QuadraNet
Organization         : QuadraNet
Region               : California
I/O Speed( 1.0GB )   : 9.1 MB/s
I/O Speed( 1.0GB )   : 13.5 MB/s
I/O Speed( 1.0GB )   : 15.0 MB/s
Average I/O Speed    : 12.5 MB/s
Speedtest.net    37.96 Mbit/s      17.92 Mbit/s        27.134 ms
Fast.com         0.00 Mbit/s       9.0 Mbit/s          0.000 ms
Hangzhou  CT     2.70 Mbit/s       21.38 Mbit/s        171.605 ms
Shanghai  CU     13.11 Mbit/s      15.26 Mbit/s        164.147 ms
Xi'an     CU     15.51 Mbit/s      25.46 Mbit/s        272.65 ms
Chengdu   CM     1.43 Mbit/s       0.62 Mbit/s         0.000 ms
Kunming   CM     19.80 Mbit/s      4.14 Mbit/s         205.245 ms
Finished in  : 14 min 38 sec
Timestamp    : 2018-09-11 11:42:43 GMT+8
Share result:
· http://www.speedtest.net/result/7625176604.png
发表于 2018-9-11 11:47:44 | 只看该作者
很早之前买了个,ip地址到处需要人机验证,弃了
发表于 2018-9-11 11:48:20 | 只看该作者
发表于 2018-9-11 11:48:57 | 只看该作者
买了一直改不了密码,都没登上去呢...
发表于 2018-9-11 11:49:54 | 只看该作者
which: no dmidecode in (/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/root/bin)
CPU Model            : Intel(R) Xeon(R) CPU E3-1241 v3 @ 3.50GHz
CPU Cores            : 2 Cores @ 3500.166 MHz x86_64
CPU Cache            : 8192 KB
OS                   : CentOS 7.5.1804 (64 Bit) OpenVZ
Kernel               : 2.6.32-042stab133.2
Total Space          : 20.0 GB (1.0 GB Used)
Total RAM            : 4096 MB (62 MB Used 1021 MB Buff)
Total SWAP           : 1024 MB (0 MB Used)
Uptime               : 0 days 0 hour 31 min
Load average         : 0.34, 0.14, 0.04
Region               : California
I/O Speed( 1.0GB )   : 1.0 GB/s
I/O Speed( 1.0GB )   : 1.2 GB/s
I/O Speed( 1.0GB )   : 1.3 GB/s
Average I/O Speed    : 1194.7 MB/s
发表于 2018-9-11 11:57:19 | 只看该作者
IO 个位数 厉害  钻石盘了
发表于 2018-9-11 12:25:24 | 只看该作者
怼啊,换位置,可能就能换到5L的IO,然而不会持久
发表于 2018-9-11 12:31:15 | 只看该作者
5楼那是OVZ的最好也别碰,他家KVM的钻石盘IO直卡咽喉一招毙命限死机子性能,就靠配置看上去不错价格又低才能忽悠到人,实际中看不中用,自行脑补一下电脑的硬盘变为手机存储卡的那个速度。
发表于 2018-9-11 12:46:29 来自手机 | 只看该作者
nijia 发表于 2018-9-11 12:31
5楼那是OVZ的最好也别碰,他家KVM的钻石盘IO直卡咽喉一招毙命限死机子性能,就靠配置看上去不错价格又低 ...
ovz为何不能碰?
GMT+8, 2026-4-16 15:47 , Processed in 0.063694 second(s), 8 queries , Gzip On, MemCache On.
