查看: 3012|回复: 9
[Windows VPS] gomezpeer再见了
发表于 2018-9-9 20:43:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Dear Peerzone Customer,
This is an important update for all Peerzone users.
Peerzone was launched a decade ago to help corporations understand and monitor web application performance across the internet. The Internet has rapidly evolved and the technologies and approaches for monitoring have also changed. We are therefore announcing the retirement of Peerzone.
On October 1, 2018, the Peerzone system will be retired and all measurements will be stopped on Peer software. Active Peers will continue to receive payments through end of September 2018 per our terms of service. Thereafter all Peer software should be uninstalled . Please note that we will not be accepting new Peer registrations and will not be activating Pending Peers effective immediately.
To uninstall the Peerzone Peer, run "Add or Remove programs" on your Peer machine, select the Dynatrace Peer, select "Uninstall" and follow on-screen instructions.
As we highly value your participation over the years, we want to ensure this process is as smooth and easy as possible for you; any additional questions you have regarding this can be directed to Peerzone Support. Our Peerzone team will be available from now through end of October 2018.
Thank you for your support and participation!
Best Regards – The Peerzone Team.
尊敬的客户Peerzone,
这是所有Peerzone用户的重要更新。
Peerzone推出十年前,以帮助企业了解和监控整个互联网web应用程序的性能。互联网已经迅速发展以及技术和方法,监测也发生了变化。因此,我们宣布Peerzone退休。
在2018年10月1日,Peerzone系统将退役,所有的测量将在对等软件被停止 。活动节点将继续通过端接收支付2018年9月的每我们的服务条款。此后所有对等软件应该被卸载。请注意,我们将不接受新的同伴注册并不会立即激活等待同伴有效。
要卸载Peerzone同行,同行的机器上运行“添加或删除程序”,选择的dynaTrace同行,选择“卸载”,然后按照屏幕上的说明。
正如我们高度重视,多年来您的参与,我们要确保这个过程的顺利和容易尽可能为您;您对此还有其他疑问,可以直接到Peerzone支持 。我们Peerzone团队将可从现在到2018年十月底。
谢谢您的支持和参与!
最好的问候 - 的Peerzone团队。
发表于 2018-9-9 20:49:19 来自手机 | 只看该作者
妈耶。又黄了一家
发表于 2018-9-9 21:13:38 来自手机 | 只看该作者
前方高能,注意ks大佬们要开始抛货了
发表于 2018-9-9 21:13:48 | 只看该作者
之前买号的人不知道赚回本没
发表于 2018-9-9 21:25:58 | 只看该作者
换alexmaster一个月,已经到账5刀,gomezpeer弄了半年都没激活,颗粒无收
发表于 2018-9-9 21:30:37 来自手机 | 只看该作者
打车出几个激活号。
发表于 2018-9-9 21:39:04 | 只看该作者
还好没花钱收号……
发表于 2018-9-9 22:22:05 | 只看该作者
我草,挂了几个月 没激活 白挂了
发表于 2018-9-9 22:43:00 | 只看该作者
这个白漂站还能倒闭?
GMT+8, 2025-12-26 16:01 , Processed in 0.122340 second(s), 10 queries , Gzip On, MemCache On.
